In ceiling Dolby Atmos Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 08-31-2014, 07:40 PM - Thread Starter
chuna's Avatar
Quoted: 21 Post(s)
Hi all,
I am in the market for Dolby Atmos in ceiling speaker. I know Pioneer make Atmos speakers but looking for some advice on these.
Cheers
chuna is offline
post #2 of 23 Old 08-31-2014, 08:03 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 148
I don't think you need a specific type of speakers for Atmos unless you are going to get those modules that sit on top of regular speakers. I'm going to use a regular pair of in-wall speakers, but I have joists that I can reinforce with MDF and build a box around the speaker, just like you would do with in-wall speakers.
It should be a simple matter of driver-matching with your main speakers and surrounds. All of my speakers have 1" tweeters and 6.5" mids, so I'm choosing the same drivers in a MTM/D'Appolito array.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 23 Old 08-31-2014, 09:09 PM
sdurani's Avatar
Quoted: 4923 Post(s)
Liked: 3355
Try to find in-ceiling speakers that have a tilt built in, so they can be mounted forward and rearward of the listening position and still be pointing at the listeners.
Sanjay
sdurani is offline
post #4 of 23 Old 08-31-2014, 09:11 PM - Thread Starter
chuna's Avatar
Quoted: 21 Post(s)
Means I have to buy new ones. Hope we start to see in ceiling Atmos soon..
chuna is offline
post #5 of 23 Old 08-31-2014, 09:21 PM
sdurani's Avatar
Liked: 3355
I thought you said you were...
Are you in the market for in-ceiling speakers or do you already own some?
No such thing. You can use any in-ceiling speakers.
Sanjay
sdurani is offline
post #6 of 23 Old 08-31-2014, 09:25 PM - Thread Starter
chuna's Avatar
Quoted: 21 Post(s)
I thought you said you were...Are you in the market for in-ceiling speakers or do you already own some? No such thing. You can use any in-ceiling speakers.
I am moving houses. I can either move the new ones to my new place or keep the old ones there and buy new ones. Havent decided yet. The questions what Atmos modules are available now for in ceiling speakers?
chuna is offline
post #7 of 23 Old 08-31-2014, 09:28 PM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
My understanding is they need to be timber matched. I have episode 500's for sides and rears and plan on using in ceiling. Since theater is aimable.
Cksqurd is offline
post #8 of 23 Old 08-31-2014, 09:28 PM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
It definitely seems like concentric drivers will be indicated since listeners will likely be in an oblique plane with respect to the sound source.
SyntheticShrimp is offline
post #9 of 23 Old 08-31-2014, 09:59 PM
westmd's Avatar
Quoted: 820 Post(s)
Liked: 282
There is a dedicated Dolby Atmos thread. http://www.avsforum.com/forum/showth...3#post27036193
Loads has been discussed also on in ceiling speakers. It would be too much to repeat eveything here so I would just read what has been written there so far and also ask any questions there!
westmd is offline
post #10 of 23 Old 08-31-2014, 10:24 PM
Quoted: 241 Post(s)
Liked: 210
I can see how what I posted would look like simple speculation on what dolby would suggest. It isn't. It's a recommendation, based on basic loudspeaker science, that I would be happy to defend to anyone.
post #11 of 23 Old 08-31-2014, 11:01 PM
sdurani's Avatar
Liked: 3355
You keep confusing 2 different things. "Atmos modules" are small upfiring speakers that sit on top of your regular speakers and reflect off the ceiling (virtual heights). There's no such thing as Atmos ceiling speakers. Any in-ceiling speakers will do.
Sanjay
sdurani is offline
post #12 of 23 Old 08-31-2014, 11:14 PM - Thread Starter
chuna's Avatar
Quoted: 21 Post(s)
I realize that but some modules come build into the speaker like the Pioneer ones.
chuna is offline
post #13 of 23 Old 08-31-2014, 11:20 PM
sdurani's Avatar
Liked: 3355
What does that have to do with in-ceiling speakers? Just to clarify, are you looking for Atmos-enabled upward-firing speakers (like the Pioneer ones) or in-ceiling speakers? You keep bringing up height modules, not sure why.
Sanjay
sdurani is offline
post #14 of 23 Old 08-31-2014, 11:24 PM - Thread Starter
chuna's Avatar
Quoted: 21 Post(s)
Sorry my bad, Im looking for these: Atmos-enabled upward-firing speakers. I currently have Krix floor standing speakers all fronts. The surrounds are all in ceiling. Hope that makes sense. I want a 7:1:4 setup.
chuna is offline
post #15 of 23 Old 08-31-2014, 11:30 PM
sdurani's Avatar
Liked: 3355
Onkyo and DefTech make some. Atlantic Technology announced some this week:
http://www.atlantictechnology.com/fi...2614-2-lrz.pdf
Might not be worth it if your surrounds are already in-ceiling (no separation from the height speakers).
Sanjay
sdurani is offline
post #16 of 23 Old 08-31-2014, 11:39 PM
Spizz's Avatar
Quoted: 195 Post(s)
Liked: 81
Timber matched, 90 degree dispersion I thought were the requirement for Ceiling Atmos speakers.
Spizz is offline
post #17 of 23 Old 08-31-2014, 11:43 PM - Thread Starter
chuna's Avatar
Quoted: 21 Post(s)
Is it better to not go with in ceiling speakers in this case? My home theater is being built but havent fully decided what to do with the surrounds in ceiling or not. Seems like may be a bit more complicated?
chuna is offline
post #18 of 23 Old 09-01-2014, 08:28 AM
sdurani's Avatar
Liked: 3355
There's no such thing as Ceiling Atmos speakers. As for those requirements, haven't seen anything from Dolby nor elsewhere with those specifications. Timbre matching can be done with equalization (like Audyssey) and the amount of dispersion needed depends on how large the seating area is and how far the speakers are.
Sanjay
sdurani is offline
post #19 of 23 Old 09-01-2014, 08:32 AM
sdurani's Avatar
Liked: 3355
Surround speakers are for hearing sounds around you. Height speakers are for hearing sounds above you. How are you going to separate sounds around you vs sounds above you when ALL those speakers are in the ceiling?
Sanjay
sdurani is offline
post #20 of 23 Old 09-01-2014, 12:41 PM
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 422
this....people have to think about what they are doing and apply logical common sense
plus confusion on the terminology - "Atmos speakers", "Atmos modules" and "in-ceiling speakers".
the sooner people figure out what each means, the faster people can give meaningful answers
Steve
ss9001 is offline
post #21 of 23 Old 09-01-2014, 01:04 PM
g_bartman's Avatar
Quoted: 157 Post(s)
Liked: 132
I'm going to do Atmos in my house which should be built by December1. I decided to go with MertinLogan ml67's on clearance from Amazon through Audio Advisor. They are aimable which helps. I know 180 degree timbre matched is the standard but there is no such thing in my case. Hoping the outcome will be at least acceptable.
g_bartman is offline
post #22 of 23 Old 09-01-2014, 03:30 PM
Spizz's Avatar
Quoted: 195 Post(s)
Liked: 81
Okay. Then you need speakers that meet the Dolby requirements in order to be effectively used as Ceiling speakers. As for those requirements, that is what I have gleamed from the Atmos threads here, and I'm sure from a news article from Dolby themselves.
Spizz is offline
post #23 of 23 Old 09-01-2014, 04:45 PM
sdurani's Avatar
Liked: 3355
Once you find the overhead locations for your height speakers, you need to stand on a stool under each spot so that your head is right below the ceiling. From there, you'll be able to see how wide your coverage are needs to be. Imagine your eyes are a spot light; how wide a cone do you need in order to light up all the seats?
If you need to cover a love seat, then the bookshelf speakers you mount on the ceiling don't need wide dispersion. If you're trying to cover two rows of four seats, then you'll need really wide dispersion. The dispersion characteristics should be based on actual coverage needed for all the seats in your HT, not some arbitrary number of degrees you saw at an AV forum.
Dolby hasn't written any news articles. They're due to release a white paper that talks about Atmos installs, but that hasn't come out yet.
Sanjay
sdurani is offline
Reply Speakers
