WDTV + 5.1 help (newb) - AVS Forum
post #1 of 1 Old 09-02-2014, 08:47 AM - Thread Starter
Liked: 0
Please see part 1 of this post http://www.reddit.com/r/hometheater/...parents_worth/
I decided to put the two big boston acoustics VR 950 in the front. Center Channel in the center. Two of the smaller boston acoustic speakers in the back.
I plan on buying a receiver and I’ll connect my cable to the avr and my wdtv.
I imagine the setup will be similar to connecting the two Andrew jones speakers to my lepai right? Just more cables going in different places.
Can anyone recommend a good cheap AVR for my needs? I plan on using hdmi for both audio and video for cable and the WDTV.
I play mostly blur ray rips mkvs on my wdtv and I have a 2tb external hd connected to my wdtv so hoping to use that to watch the blurays in 5.1
Anything I should know? Can I buy a cheap 5.1 AVR and hook it up and I’ll be all set? I’m brand new to all this. So I doubt it’s a simple as I am imagining it to be.
Dan Schmitt is offline
Reply Speakers
User Tag List
