Looks like PSA just released info on their new speaker line.
https://www.powersoundaudio.com/collections/speakers
MT-110 & MT-110c
("c" denotes horizontally oriented cabinet)
- 2 way, audiophile loudspeaker
- 1" titanium compression driver
- Cast aluminum exponential horn
- 10" high efficiency woofer
- Audiophile grade crossover completely designed in house
- Frequency Response = 70Hz - 20kHz
- Sensitivity = 95dB 1W/1M
- Size HxWxD = 17.5" x 11" x 14" (includes grill)
- Weight = 35lbs
- MSRP = $599
MTM-210 & MTM-210c
Package pricing will be determined soon. Pre-orders will start in approximately two weeks, with shipments expected to begin approximately 30-45 days later. All pre-order sales will be part of our Summer of Bass promotion, and will include free shipping both ways.
- Dual 10" high efficiency woofers
- Sensitivity = 98dB 1W/1M
- Size HxWxD = 28" x 11" x 16" (includes grill)
- Weight = 55lbs
- MSRP = $899
I answered some questions in Bold.Some questions I'm sure are going to be asked soon might as well get them on the first page.
What advantage do high efficiency, large woofer speakers have?
The ability to play very loud and clean with minimum amounts of power. The MTM-210 will be capable of 119-120 of output with only 120watts of amplification
Are these speakers bright, I heard horns are bright or annoying?
My understanding is wave guides are very smooth and flat, which should be good for both music and home theater.]
What amplification is recommended normal receiver, high end receiver, dedicated amps? How much power (watts) is a good minimum?
Any AVR with little as 50watts per channel will drive these speakers to very loud levels. 64watts a channel will drive the MTM-201 to 116db, or 113db with the 101.
Why is the frequency response only 70hz-20khz? Why not aim for a deeper response?
Majority of todays home theater systems utilize a subwoofer to handle the deep bass region. So there is not much need to build a speaker for deeper extension. Also by doing this increases the speakers efficiency and ability to play ultra clean at high output levels.
Can I cross these speakers over at 80hz?
Most definitely...that is the crossover THX recommends for the mains speakers anyway.
Can I run these speakers without a subwoofer?
Sure you can, there just will not be much deep bass output. Just gobs of tight midbass slam.
What PSA sub woofers(s)should I pair these speakers with?
Any model of PSA sub should work well with these speakers
What should I pick for my front three speakers (MT110 vs MT210)?
Looking at the specs, the MT110 should keep up with most peoples demands being reference capable with only 100watts of power, However for those that have multiple subwoofers and listen at extreme levels, the 201 should be considered.
Will you be offering stands sense these speakers are large and or heavy?
Good question! I hope a wall bracket would possibly be available for the 101's being utilized for surround duty.
That should get us started and some of the most basic questions out of the way.
I have my Jtr 228's all vertical. I just tilted the center that is about 3 inches off of the floor up a little. It sounds much better than when it was horizontal. There are articles that talk about lobing problems with WTW horizontal centers. It's not like it will sound bad horizontal though.Hey guys, I will be getting the MTM 210s for sure upfront and I wanted to orient the center vertically like the mains, the problem with the vertical center is the tweeter (horn) will be about 6" below the the mains tweeters, can I just tilt the stand back a bit to fire the horn about ear level or is it imperitive that all horns be the same height. Another question, I can have the center in a horizontal orientation which will place the tweeter (horn) in the same height plane as the mains. I know the best orientation (correct?) is to have the LCR all vertical? What orientation would produce the best dispersion with the center channel? TIA
Cheers Jeff
