Placement of front height AND front wides? - AVS Forum
post #1 of 1 Old 10-02-2014, 10:32 AM - Thread Starter
TH3_FRB's Avatar
Quoted: 54 Post(s)
Looking for some guidance on the appropriate locations if I were to run both heights and wides up front. My room is 21ft wide and currently wired for the 5.1 with the fronts in the corners - 21ft apart. I'm thinking it might be better in such a large room to bring the mains closer together and then utilize the current wiring in the corners to run wides at approximately the same height as the mains. Then I can also add heights up front but how far apart should thy be? Should the heights be somewhere between the mains and wides or spaced the same as the mains?
TH3_FRB is offline
Reply Speakers
User Tag List
