Keep this in mind if you consider filling speaker stand poles with sand - AVS Forum
post #1 of 5 Old 10-15-2014, 04:55 PM - Thread Starter
Sasha M's Avatar
Plenty of advice out there to fill speaker stand poles with sand to increase their weight and dampening.
If you have bolts connecting top and bottom plates to the poles, consider what happens when send gets into the thread.
If you ever need to disassemble your stands to move or ship them, like I just did, the sand will make them pretty much impossible to disassemble. I just twisted the bolt off in halves, that's how well the send gripped it in the pole.
Sasha M is online now
post #2 of 5 Old 10-15-2014, 09:57 PM
SyntheticShrimp's Avatar
Quoted: 84 Post(s)
Liked: 97
Good advice. Also worth mentioning is an experiment where I filled one stand with sand and left another with no sand. I then played a sine wave at the resonant frequency of my stands and listened with a stethoscope. The resonance didn't appear to be attenuated in the sand filled stand.
SyntheticShrimp is online now
post #3 of 5 Old 10-15-2014, 10:28 PM
Don Borvio's Avatar
Well, then may I suggest using a sealant like blue Loctite on the bolts on assembly (or disassemble before putting in the sand)? It will hold the nut in place but not super-permanently and protect the gap from sand.
Don Borvio is offline
post #4 of 5 Old 10-16-2014, 02:52 AM
Dolus's Avatar
1) I thought stands were filled with sand to make them heavier so when the speakers were attached the centre of mass was lower making it more difficult for the speaker to move in the opposite direction to the cone. (For every action there is an equal and opposite reaction).
2) When I filled two speaker stands with sand, (from the pet shop, because it was completely dry unlike sand from a builders merchant which contains moisture), I inserted a plastic bag taller than the stand, (much like putting a bin liner in a waste bin.), filled with sand then folded the top in.
Dolus is offline
post #5 of 5 Old Today, 03:20 PM - Thread Starter
Sasha M's Avatar
Yes - when I searched for sand-filling forum posts before starting this thread, I found someone's suggesting using plastic bags a few years ago. Not at the time I filled mine though, so hopefully this will increase awareness and serve as a good advice to anyone who may come across it in the future.
Reply Speakers
User Tag List
