Floorstanding speakers to replace JBL Studio 530's - AVS | Home Theater Discussions And Reviews
post #1 of 6 Old 11-05-2014, 09:02 PM - Thread Starter
abajetta2's Avatar
Quoted: 36 Post(s)
Liked: 45
Currently i have the jbl studio 530 bookshelves and center up front and while these speakera sound amazing, they seem to have some nulls in the upper bass. I had the studio 580 floorstandings and they were great and i dont know why i sold them especially for how cheap i got them. But now the price of those has skyrocketed to $800ea which i dont really want to spend. I dont know what brands to look at now adays but am eye balling the KEF Q series speakers right now as well as some Focals. I listen to music mostly but do movies as well. I am also running a SI15 ht in a 8cuft box for bass...
abajetta2 is offline
post #2 of 6 Old 11-05-2014, 09:07 PM
wes182's Avatar
Quoted: 17 Post(s)
Maybe a nice pair of bookshelves augmented with a strong sub?
wes182 is offline
post #3 of 6 Old 11-05-2014, 09:18 PM
89grand's Avatar
Quoted: 172 Post(s)
Liked: 89
I'd take a serious look at their placement. Those speakers are very good, I use them myself including the center, and like you, use them mostly for music. If you don't have the means now, it's worth buying a measurement mic so that you can find out just how bad your room acoustics and/or placement might be.
Sure, it takes a bit under $100 for the mic, but that's cheaper than chasing different speakers when it may be your placement, or your room acoustics.
89grand is online now
post #4 of 6 Old 11-05-2014, 09:28 PM
zieglj01's Avatar
Quoted: 775 Post(s)
Liked: 709
The 580 are $579 each here >
http://www.amazon.com/JBL-Studio-580.../dp/B0060IG460
And, 3 other places
http://www.amazon.com/gp/offer-listi...&condition=new
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is online now
post #5 of 6 Old 11-05-2014, 10:12 PM
dsrussell's Avatar
Quoted: 929 Post(s)
Liked: 859
That's a highly regarded speaker, so no wonder you feel it sounds amazing. You may be sitting in a null area for certain bass frequencies, or the sub and speakers have a phase issue and cancellation problem. Did you do the subwoofer crawl test to find the best location of your sub? Did you listen to the 530s without the sub? Do you have capabilities on that sub to change the phase or set the crossover?
dsrussell is online now
post #6 of 6 Old 11-06-2014, 06:45 AM - Thread Starter
abajetta2's Avatar
Quoted: 36 Post(s)
Liked: 45
Yeah the subwoofer is ran off a iNUKE1000 DSP, but ive ran them without the subwoofer and there is no cancellation issues. I also had this setup in another room and had the same problem but when i had the studio 580 towers i did not...
All Day|Denon|Yamaha|Behringer|JBL|Klipsch|Stereo Integrity|Samsung|Every Day
Reply Speakers
Gear in this thread - 530's by PriceGrabber.com
