looking for upgrade, but smaller in size - AVS Forum
Old Today, 11:24 AM - Thread Starter
french_guy's Avatar
Hi
I currently have Polk TSi300 towers, and CS2 center. Not using surround yet (but will do soon)
I was wondering what would be a good upgrade in sound quality but in a much smaller size (satellites or bookshelves at most)
My concern is for the center channel.....I think smaller is usually not better !
Any good idea, without breaking the bank ($500 for center and 2 fronts would be a max)
french_guy is online now
Old Today, 12:28 PM
postrokfan's Avatar
Quoted: 91 Post(s)
Liked: 478
http://emptek.com/r5ci.php
http://emptek.com/r5bi.php
$420+shipping.
$500 is a limited budget so many of your options will not constitute an upgrade but a lateral move. I think the above setup would actually be an improvement IMHO.
You might also consider the Ascend Acoustics HTM-200SE or CBM-170SE speakers and or these, http://www.hsuresearch.com/products/hb-1.html (center and book shelf speakers just a tad higher than your budget).
dsrussell likes this.
postrokfan is offline
