Need Help-B&W 684 S2 Theatre 5.1 - AVS Forum
post #1 of 2 Old Today, 07:41 AM - Thread Starter
jerry14's Avatar
Liked: 0
Now that i have my Sony VPL HW55 projector set up,i want nice set of speakers to go along with my projector.Iv been looking at B&W 684 S2 Theatre 5.1,and i realy liked them.But problems start at which AV receiver to go along with this 5.1 setup.?A lot of people said to me i would need a realy strong amp because they have 87 sensitivity and all the speakers are rated to play from 25-150w amplifiers.
Main question and i do want this to be simple,which AV receiver would work with these speakers?
Receivers that i looked are
ONKYO TX-NR636 160w at 6ohm
SONY STR-DN840 150w
SONY STR-DN1040 165w
or do i need something stronger.
I know a lot of people would say that i need a power amp beseide these,but com'on these are normal speakers like many out there,im shure that with mid-range receiver i could run these.So far i browsed a lot on net on forums,but havent seen an answer for 684 S2 theater av receiver choice.
Any help would be appreciated!
jerry14 is offline
post #2 of 2 Old Today, 01:32 PM
postrokfan's Avatar
Quoted: 106 Post(s)
Liked: 561
It's not just the sensitivity of the 684s2s but also the occasional impedance dips to 4 ohms. Overall, they should be considered 6 ohm speakers. The Onkyo should handle them just fine as will the newer Sony STR-DN1050. If you anticipate listening at high volume it might worth be considering an AVR with pre-outs to allow for the addition of an external amp.
postrokfan is online now
Reply Speakers
