Atmos setup 7.1.2 or 5.1.4 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which atmos setup
5.1.2 27 18.75%
7.1.2 38 26.39%
7.1.4 79 54.86%
Voters: 144. You may not vote on this poll
 14Likes
post #1 of 41 Old 12-31-2014, 01:07 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 1277 Post(s)
Liked: 314
Which would be a better setup in your opinion?
7.1.2 or 5.1.4 or 7.1.4 (not sure my AVR could handle it)
I listened to an AVS podcast a while back and the guest said that 7.1.2 would be a better option than 5.1.4
JOe K
tjcinnamon is offline
post #2 of 41 Old 01-01-2015, 10:37 AM
Quoted: 995 Post(s)
Liked: 525
7.1.2 seems to make the most sense, just because it most rooms I think it will be really hard to have surrounds at or slightly above ear level on 4 sides. So most people set up their rooms with the rear surrounds elevated.
Now, if 5.1.4 works with the elevated rears used as height speakers, that may make some sense too.
tjcinnamon likes this.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #3 of 41 Old 01-01-2015, 01:14 PM - Thread Starter
tjcinnamon's Avatar
Liked: 314
So the back two would be hooked into a which port of the AVR? Rear channels or Atmos height channel 2 or both?
post #4 of 41 Old 01-01-2015, 03:29 PM
Quoted: 995 Post(s)
Liked: 525
If you use them as surround back (7.1.2), then rear. If you use them as rear height (5.1.4), then Atmos height 2.
Serious Audio Blog
DS-21 is offline
post #5 of 41 Old 01-01-2015, 09:11 PM - Thread Starter
tjcinnamon's Avatar
Liked: 314
That might be a good way to test them out. I could start with 7.1.2 see how it sounds, then raise the heights above me to see how 5.1.4 sounds and then if its worth while go to 7.1.4
post #6 of 41 Old 01-06-2015, 12:36 PM
cholmes1's Avatar
Quoted: 58 Post(s)
Liked: 42
I am having a similar conundrum between 5.1.4 and 7.1.2 with my RX-A2040. That said I look forward to seeing more feedback on your question.
ATMOS Review "Of course the big new feature is Dolby Atmos and it didn't disappoint, delivering the most immersive surround experience we have had at home. We found that we preferred using the 5.1.4 configuration, as opposed to the 7.1.2 because the sense of immersion was greater and we didn't miss the two rear speakers. In fact the precision of the localisation of effects and the panning of sounds was quite remarkable, even with just five speakers. The level of bass was also impressive, although make sure you set your surrounds to small, unless you're using floorstanders, because Atmos will otherwise send an excessive amount of bass to them."
https://www.avforums.com/review/mara...r-review.10854
Different rec. than I have but their logic makes sense...
cholmes1 is offline
post #7 of 41 Old 01-06-2015, 03:12 PM
carp's Avatar
Quoted: 2880 Post(s)
Liked: 2168
Haha, I voted for 7.1.4 because I just couldn't help myself even thought I was recently at a blind GTG that compared different room auto eq's and my favorite was the Atmos and I didn't even realize it was 5.1.2 and the rear surrounds weren't playing.
All the other non Atmos (Audyssey xt32, ARC, YPAO, MCACC, Dirac) AVR's were in 7.1.
Here is the GTG thread:
Archaea's Auto room EQ/AVR comparison G2G - November 8, 2014 - Kansas City
carp is offline
post #8 of 41 Old 01-06-2015, 03:13 PM
carp's Avatar
Liked: 2168
I should make the obvious point though that I did not hear 5.1.4, 7.1.2, or 7.1.4 so no idea how those compare.
carp is offline
post #9 of 41 Old 01-06-2015, 03:14 PM
blu-dog-avs's Avatar
Quoted: 150 Post(s)
Liked: 123
No 7.2.4?
I think they've been touting dual sub placement, as well. Is that the first "upgrade" coming down the pike?
darthray likes this.
blu-dog-avs is offline
post #10 of 41 Old 01-22-2015, 09:23 AM
cholmes1's Avatar
Quoted: 58 Post(s)
Liked: 42
What do you mean by 'upgrade? ' As I understood, you could always add subchannels to any speaker placement. Are we not supposed to be able to use 2+ subs in our ATMOS setups.
Currently I have a 5.2.4 setup in my dedicated HT and it works well. I am using an A2040 if that matters
EDIT: Found this in the ATOMS White Paper "While manufacturers may decide to support more than one subwoofer output, Dolby Atmos technology generates a single low frequency effects (LFE) signal. Figures 5, 6,and 7 show the most common speaker layouts in a Dolby Atmos system for home theater."
Looks like have two LFE signals in my setup...
cholmes1 is offline
post #11 of 41 Old 01-22-2015, 11:28 AM
beastaudio's Avatar
Quoted: 4151 Post(s)
Liked: 3511
You don't. This likely won't change as the LFE signal is only up to 120hz, where directional cues are still virtually nonexistent. Bass is omnidirectional, therefore rendering two different LFE channels pretty much pointless. Now receivers have dual sub outs already, which can be EQ'd and time aligned separately, but both still share the same signal from the mix.
SandstormGT and cholmes1 like this.
beastaudio is online now
post #12 of 41 Old 01-22-2015, 01:04 PM
Moderator
rboster's Avatar
Quoted: 1237 Post(s)
Liked: 1367
My original set up was 7.1. When I decided to dip my toe into Atmos (due to those b#$%ds at the KC meet's results), I went the less expensive route of Denon 4100 plus a pair of in ceiling speakers. I love it....but now can really see how having two rear or mid ceiling speakers would really add to the overall experience with both Atmos and Dolby Surround (faux Atmos for non-atmos soundtracks). If I had stepped up to the next Denon, I could have had that option.
Just my two cents
Ron
carp and cholmes1 like this.
For Sale JVC DLA-X750R/RS500 Projector includes two lamps
http://www.avsforum.com/forum/252-fr...l#post54970964
rboster is online now
post #13 of 41 Old 01-22-2015, 01:15 PM
rfbrang's Avatar
Quoted: 230 Post(s)
Liked: 68
This is questionable for me, would like 9.1.4, but I guess... Front LCR, wides, surrounds, and our front uppers could be replaced with the X.X.4 scenerio???
Just got a Denon AVR 4520cl on clearence last month, so we can wait a few generations to see what shakes out.
Luckily, I wired the lower and upper position for a 7.1 system during our remodel because I was not sure if we would end up with towers or bipole surrounds. I guess the upper side and rear cables can get harvested for overhead atmos in-ceiling speakers in the future.
Our Old Space
New House
PSN: brotj7
rfbrang is online now
post #14 of 41 Old 01-22-2015, 02:51 PM
carp's Avatar
Liked: 2168
Just my two cents
Ron
So your Denon allows rear surrounds plus 2 ceiling speakers? It was interesting at Jonathan's, for the Atmos avr the rear surrounds weren't even on (they were on for all other AVR's) and I still preferred the cheap Atmos AVR to everything else.
So, IMO 5.1.2 is better than 7.1 but I'm wondering how 5.1.2 compares to 7.1.2 and if I'd even notice whether or not the rear surrounds are on.
carp is offline
post #15 of 41 Old 01-22-2015, 05:27 PM
justthinking's Avatar
Quoted: 376 Post(s)
Liked: 209
Anyone done a direct comparison of 5.1.2 vs 5.1.4?
justthinking is offline
post #16 of 41 Old 01-23-2015, 06:12 AM
cholmes1's Avatar
Quoted: 58 Post(s)
Liked: 42
I was able to hear nearly full ATMOS options (5.1.2, 5.1.4, 7.1.2, 7.1.4) at the 14' CEDIA show. The rep was very nice and quite bored as I was the first to arrive at their booth that morning.
Given that the demo was held in what amounted to a small black tent (8x8x8) it was far from ideal, but it was noticeable when the .2 shifted to .4 and vice versa. In terms of the 7 channel, it was nice and I certainly did hear them as they were about 10" from my mid-back, but in terms of sound enhancement, I felt the additional two speakers up high were 'worth more' than the 2 for rear surrounds.
Based on those impressions I bought a RX-A2040 and have it set up for a 5.2.4. The sub issues I will have to resolve somehow as I was informed (see above) that I can still use them I just have to time them and YPAO is not the best with bass. That said, I am very happy with the setup. My room dimensions are 18x14x8.5 with a beam separating the front heights from the rear heights if that matters.
What is really interesting is that in the 'ATMOS Fad or Future' thread (Atmos. Fad or future?) no one has yet to mention that you do not require a movie coded in ATMOS to enjoy the new speaker placement.
Hope this helps.
cholmes1 is offline
post #17 of 41 Old 12-27-2015, 04:57 PM
Sammy42C430's Avatar
OK, I'm about to decide between 7.1.2 vs. 5.1.4 as well!
There doesn't appear to be a clear majority or winner based on the little feedback I've been able to find. I mean, there's got to be more of this question in the upcoming year because it's pretty much limited by the receiver option in the market too. I'm getting the Yamaha A2050.
Here's what I gather and my own interpretation of folks having heard both.
Folks that favour 7.1.2 are basing it off existing/legacy content, and it sounds awesome versus 5.1.4.
Folks that favour 5.1.4 are basing it off specific Atmos content for this setup and it sounds much more immersive than having only 2 ceiling speakers vs. 4.
Seeing that Atmos separate the objects to front ceiling and rear ceiling sound, I'm leaning toward 5.1.4 as I'm speculating the more Atmos soundtracks that come out in the future, it'll continue to sound better. If I've 2 less rears, it's okay, but I've got two more celing to compensate too.
With 7.1.2, it seems like missing out on half the Atmos object sounds (getting only front half and not rear half).
I know 7.1.4 is ideal, but it's a different kind of receiver all together.
I need to decide since I'm contracting folks to build the room and basement and pull wire. Once it's pulled, I don't think I'm going to be moving/adding ceiling speakers... it'll be set for a long while!
Sammy42C430 is offline
post #18 of 41 Old 12-27-2015, 05:49 PM
AllenA07's Avatar
Quoted: 701 Post(s)
Liked: 572
I would recommend pulling wire for 7.1.4 now,maybe even more channels. Wire is cheap and this would be the easiest time to do some future proofing.
AllenA07 is offline
post #19 of 41 Old 12-27-2015, 06:14 PM
ALtlOff's Avatar
Quoted: 1218 Post(s)
Liked: 616
Personally I think it's entirely room dependant, but I'd choose 5.1.4 using heights as one of the .4 over 7.1.2 with elevated rears.
Shadowed likes this.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #20 of 41 Old 12-27-2015, 09:51 PM
sdurani's Avatar
Quoted: 5130 Post(s)
Liked: 3612
By that logic, 5.1.4 will be like missing out on half the surround channels (getting only the side half and not the rear half). Fortunately, it doesn't worth that way. Movie soundtracks can scale to your speaker layout, with no information missing.
Given the choice, I would go with 7.1.2 because it provides more even coverage than 5.1.4. Aside from the L/C/R speakers, you have a pair of speakers anchoring sounds to your sides, a pair of speakers anchoring sounds behind you, and a pair of speakers anchoring sounds above you.
Sanjay
sdurani is online now
post #21 of 41 Old 12-28-2015, 07:10 AM
That's true! Silly me for not even having considered this at all yet. Will pull the wire for 7.1.4, regardless if I go 5.1.4 or 7.1.2.
Ceiling is only 8ft high.
It's open concept, so I've got only two walls in this corner - TV wall in front where the KEF LCR is and a left wall, where the right wall is a bit further away than this "room". This "media room" is planned to be about 12ft x 13ft. The actual back wall is about 40ft away in the back.
It's why I'm doing the Atmos and surround speakers only in-ceiling. From what I've researched, surrounds need to be elevated anyway, so what's another couple of feet
Although I could probably convince the wife to accept a design with speaker stands all around, logistically, I also prefer the wire being run via ceiling than under the wood flooring.
Ah, okay, perfect. Not losing any sound information is great. With this knowledge, then I'm leaning even more toward 5.1.4 than 7.1.2. My reasoning...
If we don't lose the sound, I am thinking placing the side speakers about 110 to 120 degrees from the TV listening position instead of 90 degrees to the side. Then it's still slightly located in the rear carrying all the sounds, even though not its own discrete channel.
In 7.1.2, having only 2 Atmos speakers and pretty much have to place these two speakers directly above the viewers trying to provide both the front/rear effect vs. having 4 Atmos speakers where I would have the front and rear Atmos discretely separated. The surround speakers carry both side/rear channels, so if it's slightly angled to side and rear, it compromises to be able to provide effective immersion.
Comes down to legacy and existing movie soundtracks are designed for 7.1 vs. what I speculate future soundtracks will have more creative and dedicated Atmos content, so it's why compromising the side/rear surrounds instead of compromising the Atmos.
Actually, as part of this exercise, researching further into Atmos, it's completely different algorithm and design from the legacy discrete channel design. It's object based and truly 3D sound. Actually, I'll stop writing there... as it'll get off topic into how the channels are used now vs. TrueHD, so probably a another thread for that.
post #22 of 41 Old 12-28-2015, 07:35 AM
sdurani's Avatar
Liked: 3612
Even Atmos mixes have most of the sound around you rather than above you. You're going to compromise spatial resolution and coverage for 99% of the sound to improve it for 1% of the sound.
Sanjay
post #23 of 41 Old 12-28-2015, 09:17 AM
yosh7's Avatar
Quoted: 137 Post(s)
Liked: 161
There should be some additional voting options.
I vote 9.4.4 or 9.4.2. (LCR, WIDES, SURROUNDS, SURROUND BACKS/4 SUBS/2 OR 4 HEIGHTS)
yosh7 is offline
post #24 of 41 Old 12-28-2015, 10:28 AM
deadheadmike's Avatar
I am using 4 Klipsch up firing and also additional Polk front/rear height angled down. Whatever one set up lacks the other makes up for it. My system is set up for both Atmos & Auro 3d
A little overkill but I have a 33 speaker set up-- Marantz 8802a w/ 6 amps
deadheadmike is offline
post #25 of 41 Old 03-26-2016, 10:37 AM
tulsabrown's Avatar
Quoted: 22 Post(s)
If you're using a 5.1.4 vs a 7.1.2 when you play a 7.1 soundtrack isn't your receiver then dropping you back to a 5.1 track and not using the height speakers?
I have a lot more 7.1 soundtracks than I do Atmos.
tulsabrown is offline
post #26 of 41 Old 03-26-2016, 12:08 PM
ALtlOff's Avatar
Liked: 616
No, the height information/objects are separate from what's going on in the bed layer of speakers. A 7.1 soundtrack played through a 5 channel bed simply places the sounds that would be going to the Rears into the Surrounds, that all.
My Build Thread:
ALtlOff is offline
post #27 of 41 Old 03-26-2016, 01:39 PM
tulsabrown's Avatar
Quoted: 22 Post(s)
But isn't that still just 5 speakers operating and 4 laying dormant for the vast majority of most users uses?
post #28 of 41 Old 03-26-2016, 02:28 PM
ALtlOff's Avatar
Liked: 616
If your using standard processing such as Dolby Digital/ TruHD or DTS Neo/MA then yes, but most immersive audio users will apply their preferred upmixer when playing non native content (DSU or Neural-X) so that the height layer of speakers are still used.
hatlesschimp likes this.
My Build Thread:
ALtlOff is offline
post #29 of 41 Old 03-27-2016, 01:29 AM
tulsabrown's Avatar
Quoted: 22 Post(s)
That makes sense, thank you.
post #30 of 41 Old 11-05-2016, 08:23 AM
Quoted: 34 Post(s)
Liked: 0
In my particular circumstance I am unable to place neither the side or rear surround speakers symmetrically. Looking at the rear wall, I have a sliding glass door on the right wall near the back corner and to the left of the rear wall the kitchen opening. I am able to place one side surround speaker on the left wall (looking toward rear of room), but not on the other side where the slider is located. Worse, the space between the sofa arms and the side walls on either side is less than 3 feet so I can't even position them on the floor.
In a 5.1.4 setup, can I place both side surround and the four Atmos speakers on the ceiling? Imagine a circle around the sofa, the middle being the center of seating position, the right/left surround speakers at 90 and 270 degrees, the Atmos at 45, 135, 225 and 315 in plan view; all pointed using directional speakers at about 45 degrees to the sweet spot.
The room is 13'-6" wide x 18'-6" long x 8'-0" high, projection on the narrow side.
techjoy is offline
Reply Speakers
