I have an Onkyo NR609 Receiver. A few years ago I bought 4 Monitor 40s two-way bookshelf speakers ( http://www.newegg.com/Product/Product.aspx?Item=N82E1688229020 ) and my center is the Polk Audio CS2 Series II Center Channel Speaker ( http://www.newegg.com/Product/Product.aspx?Item=N82E16882290212 ).
Recently, my L/R and Center speakers I believe are not working correctly. I see a tear in the center channel speaker and everything sounds hollow and when I run Audyssey it can't recognize my L/R speakers. I believe my two rear speakers which are monitors 40s as well are still in tact because they are recognized.
They are in their 5 year warranty, but I believe they won't fix them because they broke because music was blasted too loud on them.
What would you guys do? Would you move the rear monitor 40s up to the l/r and buy a new center speaker and two surrounds for the rear? If so what would you suggest for the rears to go with the 40s? I am assuming for the center I'd reorder the CS2.
Would you leave the monitor 40s as the rear surrounds and buy a new L/R and center speaker? If so what would you suggest?
Or would you try to get the speakers repaired somewhere? (I have looked around but can't find anywhere, so I am not sure about this one).
My budget is 300-400 dollars.
