I agreed to downsize my 5.1 surround speakers. Now what to buy? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Transmaniacon
post #1 of 21 Old 02-10-2015, 06:09 AM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
I made a compromise to sell off my paradigm FCR speakers. They are large floor type, and a massive center channel. monitor 7 series.
I need help with speaker selection for new FCR speakers. My issue is a large 120" projection screen that obstructs the center speaker. My screen is not acoustic transparent.
I think I have only 2 options.
1. 3 in ceiling speakers mounted just in front of the screen.
2. FR bookshelves sized speakers, and a center behind the screen. My thought on this is that the center can be adjusted too a higher volume to accommodate the screen barrier.
Has anyone had a satisfactory setup with one of these options?
The room is 14wx20l.
Powered by Onkyo sr605
12" powered paradigm sub
2-paradigm bookshelves for rr and lr.
jdmalibu is offline
post #2 of 21 Old 02-10-2015, 06:29 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
1. Front ceiling speakers are not going to work well, and should be seen as an absolute last resort.
2. If you don't have an AT screen, you can't put a speaker behind it, regardless of the volume.
I would go with some bookshelves on each side, and then get a center speaker stand to mount the center below the screen and tilted up.
If you like the Paradigm sound, consider some of them, a pair of Mini Monitors and a Center 3 would make for a nice sound stage. And seeing as you have a sub, there won't be much of a drop off in sound compared to towers.
hoyalawya and crazyrob425 like this.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 21 Old 02-10-2015, 11:20 AM
MarsianMan's Avatar
Liked: 33
Maybe time for an AT screen?
MarsianMan is offline
post #4 of 21 Old 02-10-2015, 12:21 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Consider the NHT Absolute Tower speakers for the front. They are very good speakers and will go down below 60 Hz; fine with your sub.
They are only 5.7" wide and 36" high, and you can use the NHT Classic 2 Center speaker for the center, below the screen.
commsysman is offline
post #5 of 21 Old 02-10-2015, 12:47 PM
losservatore's Avatar
Quoted: 2644 Post(s)
Liked: 2426
or get an smaller screen?
100" ?
a balance between screen size and audio setup ,if my screen is taking too much space to fit an audio setup I prefer to lost few screen inches and fit my audio setup.
losservatore is offline
post #6 of 21 Old 02-10-2015, 12:50 PM
drunkpenguin's Avatar
Quoted: 1350 Post(s)
Liked: 1367
How much space do you have from floor to screen?
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #7 of 21 Old 02-10-2015, 05:19 PM
wlhungdude's Avatar
Quoted: 189 Post(s)
Liked: 237
100" ?
this
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #8 of 21 Old 02-13-2015, 05:05 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
There is about 12" or more.
jdmalibu is offline
post #9 of 21 Old 02-13-2015, 05:07 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
Here is the wall, with screen up
The stereo equipment will be moved to a closet with rf blaster.
jdmalibu is offline
post #10 of 21 Old 02-13-2015, 05:07 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
And this is screen down
jdmalibu is offline
post #11 of 21 Old 02-13-2015, 05:14 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
So I guess if I did this I would keep my center, and place it on the floor. As far as the LRF I would replace with book shelves.
I added pictures below, I'm trying to reduce the cluttering look of these big speakers to compromise with my wife. The room is dual purpose.
jdmalibu is offline
post #12 of 21 Old 02-13-2015, 05:14 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
At least 12"' my center could be floor mounted
jdmalibu is offline
post #13 of 21 Old 02-13-2015, 05:15 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
12" or more
jdmalibu is offline
post #14 of 21 Old 02-13-2015, 05:19 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
100" ?
I just bought a screen, it does have enough space below for the center.
jdmalibu is offline
post #15 of 21 Old 02-13-2015, 05:22 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
I know, but I just purchased the one pictured below, I don't really want to do this right now.
jdmalibu is offline
post #16 of 21 Old 02-13-2015, 05:24 PM - Thread Starter
jdmalibu's Avatar
Quoted: 16 Post(s)
Slimmer is nice, maybe for FLR I could find something that inserts into the wall?
jdmalibu is offline
post #17 of 21 Old 02-13-2015, 05:46 PM
Liked: 1394
An AT screen is really the best option, can you still exchange the one you have? It would let you place a pair of bookshelves on that sill, and keep the center where it is, and you wouldn't see any speakers with the screen down. As is right now acoustics are not good with the current speaker positions, and having something behind a non AT screen is not going to work.
post #18 of 21 Old 02-13-2015, 06:08 PM
commsysman's Avatar
Liked: 569
Look at the PSB speakers that are for wall and ceiling installations.
Most wall/ceiling speakers are absolute trash; PSB makes only high-quality products.
post #19 of 21 Old 02-13-2015, 06:37 PM
zieglj01's Avatar
Quoted: 1672 Post(s)
Liked: 1569
That would be the better option
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #20 of 21 Old 02-13-2015, 06:43 PM
Liked: 2426
you can place the center on the floor and DIY something to tilt up the center.bookshelf will work better ,the ceiling speakers on that suspended ceiling will not sound good.
also some AM-40 Side Clamp for bookshelf speakers.
I think that he wants to keep the room as is.
post #21 of 21 Old 02-13-2015, 06:50 PM
AJInstitute's Avatar
Quoted: 79 Post(s)
Headphones.
Epic use of space. Where do you sit, chair or couch?
AJInstitute is offline
Reply Speakers
