Does my NAD T758 be a fit for Vienna Acoustics? - AVS | Home Theater Discussions And Reviews
post #1 of 2 Unread Today, 08:14 PM - Thread Starter
jrlvnv's Avatar
I have the option to upgrade my Tannoy's and get a pair Vienna Mozart Grand's (just pay the difference)... I have read that the Vienna's are 4ohms but my NAD supports 8ohms. I honestly have no idea what all that means but I am worried that it would not be a "correct" fit. What do some of you guys think?
jrlvnv is offline
post #2 of 2 Unread Today, 11:16 PM
RayGuy's Avatar
Quoted: 189 Post(s)
Liked: 145
Here's a quote from the ad for this receiver on Amazon:
7 x 60W Minimum Continuous Power into 4 / 8 Ohms, all channels driven simultaneously 20Hz - 20kHz
So, no problem. Read the manual so you know what your receiver is capable of and is set up correctly for a 4 ohm load.
RayGuy is online now
Reply Speakers
