Doing it once it not likely to damage your system only way to tell is do some normal listening to TV or music and see if there is any sound difference. If your system sounds substansally different than you have damaged your speakers.
Thankfully, I had my cross over frequency set to 80 hz, with all speakers set to small. My understanding is this configuration protected the speakers from potential damage.
Also, I just tested the system with the elephant scene from LOTR-Return of the King at a very loud volume, and everything sounded as it should so I lucked out this time haha
If you have already run YPAO, and your speakers have been set to small (which I believe is the default), then all the frequencies below the configured crossover will be directed to the sub. So the speakers won't even "see" those test tones. As for the sub, most commercial subs should have fault protection circuitry which prevents it from playing signals which could potentially damage the driver/amp.
Thankfully, all my speakers were set to small and the AVR's cross over frequency was set to 80 hz. This means that the worst case scenario is a destroyed subwoofer since all sound below 80 hz is routed to the subwoofer. Would this be a correct interpretation?
tezster you mentioned that most commercial subs have fault protection circuitry. If my Synergy Sub-12 has this circuit and it was activated, would the subwoofer simply turn off?
You're absolutely right zieglj01! - should not have experimented on the system like that. The funny thing is that I actually have some cheap speakers lying around which are perfect for this type of testing haha...
Thanks for the feedback thus far - much appreciated!
Today, I played an ultra low bass frequency sweep (from 1 to 35 Hz) through my Klipsch system.
The AVR is the Yamaha rx v575. If I did damage the speakers, what would be the symptoms? Is it subtle or obvious?
if you want to really check things out try
audiocheck.net
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
