I just upgraded subs to the SVS Ultra and it's causing one of my front speakers to vibrate around on it's stand. Relocating my sub isn't much of an option so I'm looking for some way to adhere my speaker to it's stand without leaving any kind of residue on the bottom. Anyone had any luck using 2 sided sticky tape? Ideally I'd like to find some bumper or feet material that is sticky enough to keep it from sliding around but I have no idea what products would work.
Another possibility is clear Vinyl plastic sheeting which can be found at any Fabric store in various thicknesses. This in not thin poly drop cloth plastic, this is thicker.
I've used blu-tack and the one Craig uses and another....no issues with the piano black finish on my Ascends, and have used it with their more basic finishes, too and the stuff comes in handy for rattle abatement and hole stuffing (I used it on my subs to seal around the speakon connectors)....
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
