First Setup B&w 684 s2 vs 684 s1 - AVS | Home Theater Discussions And Reviews
post #1 of 10 Old 05-15-2015, 03:08 AM - Thread Starter
Liked: 0
Hey guys I'm trying to figure my first audio set up for music, mostly rock, Johnny Cash, dire straight, the Eagles, tool, rage etc.
Any who I was going to get wharfedale 10.7, but am now leaning towards b&w 684 s2, I can't listen to either the storeroom only has the b&w 684 s1 which I did quite like.
Can Anyone give me advice between the two series? I noticed whathifi rated the s1 better what are your guys opinions?
I can get the s1 cheaper
thanks!
MattVivian is offline
post #2 of 10 Old 05-15-2015, 03:16 AM - Thread Starter
Liked: 0
Also I will be getting the marantz sr5009 amp,
For an idea of prices the wharfedale diamond 10.7 are nz1500 b&w 684 s2 are nz1700 and the b&w 684 s1 are nz1200.
post #3 of 10 Old 05-15-2015, 04:27 AM
Transmaniacon's Avatar
Quoted: 794 Post(s)
Liked: 635
I would at least try and listen to the S2, so you can know for sure. From what I have read the S2 series has some nice upgrades over the first generation, but I haven't been able to hear them yet.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | BIC F-12
Transmaniacon is offline
post #4 of 10 Old 05-15-2015, 04:38 AM
crn3371's Avatar
Quoted: 111 Post(s)
Liked: 68
I've been quite happy with my 684 s1's, but I agree with Transmaniacon, it would be nice to hear the s2's too. You should be getting a price break on the s1's though, which might help with the decision making process.
crn3371 is offline
post #5 of 10 Old 05-15-2015, 11:33 AM - Thread Starter
Liked: 0
Yeah I think I am going to ask the store if they can get the s2 in aswell for me to listen either way I will be buying one or the other.
I get abit confused on the upgrades from s1 to s2 the s2 has smaller speakers and is 2 way compared to the s1 which has bigger speakers and is 2.5 way?
I guess bigger isn't always better though?
I assumed that bigger speaker would put out more noise?
Has anyone heard both series?
post #6 of 10 Old 05-15-2015, 12:01 PM
Quoted: 794 Post(s)
Liked: 635
Yeah the new 684 is slimmer, the 683 is the bigger tower. You might could find a good deal on the first gen 683, which I think would be a better choice than the new 684 since it has a dedicated mid-range driver.
post #7 of 10 Old 05-15-2015, 01:49 PM
Liked: 4
The S2s do sound great but you're probably going to be able to get a great a better price on the S1s if budget is an issue
LFM07 is offline
post #8 of 10 Old Today, 01:07 AM - Thread Starter
Liked: 0
Of the 2 versions which do you think sounds the best? Primary for music?
I have tag mixed reviews on the s2 that is all and unfortunately I cant listen I would rather spend the extra if the s2 is THAT much better.
post #9 of 10 Unread Today, 07:28 AM
callas01's Avatar
Quoted: 192 Post(s)
Liked: 130
the 684 S2 was a little more transparent, but the S2 severely lacks bass. The 684 S1 would be more satisfying overall to me, because it can reproduce a fuller range of frequencies. When I heard the 684 S2, they didn't play the kick drum or synthesized bass or bass guitar as well as I would have liked to play music in a 2.0 setup. If you're going to use a subwoofer to augment the low-end then the S2s more open sound might be better for you.
I have not heard the Wharfedales, so I cannot compare.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF2 MK4, Oppo BDP-103,
NaimUniti 2, Marantz SR7007, 55" Panasonic Plasma
callas01 is online now
post #10 of 10 Unread Today, 02:31 PM
postrokfan's Avatar
Quoted: 208 Post(s)
Liked: 954
If the store can get the S2s in that would be great. The best way to decide is to hear both speakers. The 684S2 has quite a few upgrades and the tweeter is much improved IMHO. However, I agree with callas that the bass is quite lean with the S2. The S2s and a quality subwoofer would be a very nice combination.
HT: CM9 S2 FR/FL, CMC2 S1, CM5 S1 surrounds, ASW610; Yamaha rx-a2030; Parasound 2100; Parasound 275; Oppo BDP-93; ATV
2 Channel: Ascend Acoustics Sierra-1 NrT FR/FL, ASW608; Parasound Halo P5; Parasound Halo A23; Rega RP1; Marantz CD5004
postrokfan is online now
Reply Speakers
