passive speakers question - AVS | Home Theater Discussions And Reviews
post #1 of 7 Old Today, 11:05 AM - Thread Starter
Liked: 0
Hi
Sorry for the basic question.
I have been given a DARE passive speaker model VS400.
From research I have figured out that I need a Speakon cable to connect to the speaker. I want to connect the speaker to my hifi (denon) AMP.
What I can't figure out is:
- Is that possible? I have read I need a power AMP. Is the denon hifi type amp ok to use in theory?( I still need to work out the watts part, but I will do that once I understand more)
- One end of the cable goes into the speaker (speakon), the other into my AMP. What's the name of this cable that I should buy?
Mesh
mesh44 is online now
post #2 of 7 Old Today, 11:11 AM
Bill Fitzmaurice's Avatar
Liked: 2054
You need to either buy or make a cable with the correct Speakon at one end and the appropriate connector, or bare ends, at the other to go to your Denon.
Bill Fitzmaurice is online now
post #3 of 7 Old Today, 11:27 AM
Gooddoc's Avatar
Quoted: 1110 Post(s)
Liked: 613
I saw a pic of the back of that speaker and there are two speakon connectors on the back(if you have the same one). You should make sure it is not an active speaker (no crossover) before you hook it up.
Gooddoc is online now
post #4 of 7 Old Today, 02:39 PM - Thread Starter
Liked: 0
Gooddoc - you are right there are two speakon connectors on the back. But you have totally lost me when you say crossover. How can I figure out if it's active? All other active speakers images I have seen seem to have lots of other dials/switches at the back.
post #5 of 7 Old Today, 02:46 PM
Gooddoc's Avatar
Liked: 613
If you put a dmm on each one and test the ohms they will be the same if it has a crossover. If it is a different ohm reading between the two then it is an active speaker with no crossover
post #6 of 7 Unread Today, 03:16 PM
Liked: 2054
If it's a typical pro sound speaker they're parallel wired, for daisy chaining. You'd seldom, if ever, find dual Speakons for the purpose of bi-amping. For that use 4 pole Speakons are employed.
post #7 of 7 Unread Today, 03:20 PM
Gooddoc's Avatar
Liked: 613
Ah, thanks Bill.
Reply Speakers
