Ceiling Speaker Installation Help - AVS | Home Theater Discussions And Reviews
post #1 of 1 Unread Today, 01:12 PM - Thread Starter
nosdude's Avatar
My theater has a coffered ceiling with 6-inches beams.
I just purchased two in-ceiling speakers, and i would like to know what your recommendation is between these two options.
Option 1:
Build a 6-inch plywood box that matches the existing coffer beams and install the speaker inside the box.
Option 2:
Install the speaker in the drywall inside the coffer. I'm just worried about heat in the attic. It's about 120 degrees up there around July/August.
nosdude is online now
Reply Speakers
