Klipsch Reference Premiere 7.2 System Official AVS Forum Review - AVS Forum | Home Theater Discussions And Reviews
 60Likes
post #1 of 129 Old 07-21-2015, 11:35 AM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 6626 Post(s)
Liked: 11400
Mark Henninger takes on the task of testing a sizeable speaker system that promises high sensitivity and fidelity. Does it deliver?
Klipsch is among the best-known American speaker brands, specializing in high-sensitivity horn-loaded designs. The Reference Premiere series replaces Klipsch's Reference II series and features performance-enhancing improvements, including a newly designed horn made of molded rubber. The series—introduced at CES 2015—is the top of the Reference lineup. In fact, the company says Reference Premiere speakers are the core of its business.
In a pair of recent reviews, I covered the capabilities of the Klipsch RP-280F tower speakers and the R-115SW subwoofer. Those components were just a part of a complete 7.2-channel surround system Klipsch sent me. This review is about the whole 380-pound package.
When the speaker system arrived at my studio, its sheer size presented a challenge. I work out of a Philadelphia row house, and the AV studio is on the third floor. The subs in particular weigh 75 pounds each, so I called a friend to help lug them up the stairs.
When I first set up the system, I had to chuckle because it barely fit in my 11-foot-wide room. I had just a few inches to spare after placing the subs, towers, and center channel up front. Aesthetically, it's garnered the most compliments of any system my friends have seen—the copper-colored aluminum woofers look stylish when exposed. This a system you'll want to keep the magnetic grills off.
Features
The complete 7.2 Reference Premiere system used in this review consists of four different speaker models plus twin 15" subwoofers. One of the unifying elements of the main speakers is the use of a Tractrix horn-loaded titanium-dome tweeter and aluminum woofers. The new tweeter design combines a round throat with a square mouth, which is supposed to improve imaging. Klipsch says the rubber used to make the horn reduces resonances that can result in a harsh sound.
Here's a close look at Klipsch's new tweeter.
The review samples' MDF cabinets came in an ebony wood finish; there also is a cherry option. Chamfered front baffles help reduce diffraction effects and provide a nice aesthetic touch when the grills are off. Magnetic grills—used on all the speakers—attach and detach easily.
The system features RP-280F towers for the front left and right channels. This 2-way speaker features a Tractrix horn-loaded 1" titanium-dome tweeter and two 8" aluminum-cone woofers. Each one weighs 62.5 pounds and measures 10.5" (W) by 43" (H) and 18.3" deep.
Klipsch lists a frequency response from 32 Hz to 25 kHz (+/-3 dB) for the RP-280F. Rated sensitivity is 98 dB/W/m, and each speaker can handle up to 150 watts of continuous power (600 watts peak) with 8 ohms nominal impedance. The crossover frequency is 1750 Hz, and the speaker supports bi-amping as well as bi-wiring. The tuned Tractrix port vents to the rear.
The RP-450C center channel is a 2.5-way ported speaker. It sports a Tractrix horn-loaded 1" titanium-dome tweeter and four 5.25" woofers. Two of the woofers—the one directly to the left of the tweeter and the one on the far right—handle midrange duties between 500 Hz and 1500 Hz. The other two woofers cut off at 500 Hz, and arrangement meant to reduce lobing artifacts. The center weighs 35.7 pounds and measures 31.13" (W) by 6.81" (H) and 14.51" deep.
The RP-450F center has four woofers, two cut off at 500 Hz and two play up to 1500 Hz.
The frequency-response spec for the center is 58 Hz to 25 kHz (+/-3 dB). Rated sensitivity is 97 dB/W/m, and each speaker can handle up to 150 watts of continuous power (600 watts peak) with 8 ohms nominal impedance. The crossover frequencies are 500 Hz and 1500 Hz. Again, the tuned Tractrix port vents to the rear.
A pair of RP-250S surround speakers handled the side-surround duties. These speakers are markedly different from the rest of the Reference Premiere line in terms of design. They are sealed, and they feature two identical sets of drivers in each speaker. Two sets of 1" titanium-dome tweeters and 5.25" aluminum-cone woofers are mounted at a 90-degree angle from each other. The result is 180-degree horizontal coverage, which in many cases is perfect for surround-sound envelopment.
The front and rear of the RP-250S.
Klipsch rates the RP-250S's frequency response from 58 Hz to 24 kHz (+/-3 dB). Rated sensitivity is 95 dB/W/m, and each speaker can handle up to 100 watts of continuous power (400 watts peak) with 8 ohms nominal impedance. The crossover frequency is set at 1500 Hz.
For rear surrounds, I used the RP-160M monitors, a bookshelf-style speaker more in line with the rest of the Reference Premiere design. It's a 2-way ported design that relies on a Tractrix horn-loaded 1" titanium-dome tweeter paired with a 6.5" aluminum woofer. A RP-160M weighs 19.9 pounds and measures 8.81" (W) by 16.67" (H) and 12.86" deep.
Here's a look at the front and back of the RP-160M. You can see the Tractrix horn and the Tractrix port.
The frequency response of the RP-160M is specified from 45 Hz to 25 kHz (+/-3 dB). Sensitivity is 96 dB/W/m, and it can handle up to 100 watts of continuous power (400 watts peak) with 8 ohms nominal impedance. The crossover frequency is 1500 Hz, and the tuned Tractrix port vents to the rear.
The R-115SW sub is a 75-pound bass-making beast, and for this review, I used two. Each sub boasts a 15" aluminum driver and 400 watts of power (800 watts peak). It's a vented design with a front-facing slot-style tuned port. The rated frequency response extends from 18 Hz to 125 kHz (+/-3 dB), and Klipsch claims a peak output of 122 dB. It measures 19.5" (W) by 21.5" (H) and 22.3" deep.
Setup
I used the system as my primary surround system for almost two months. I positioned the speakers as I normally do—the front left and right speakers were placed so the front baffle was 30" from the side walls and 40" from the front wall, while the subs went in the front left and right corners.
The center channel rested on a 14-inch-tall TV stand with the TV on top of that. The side surrounds were wall-mounted on each side of my sofa; the tweeters were 42 inches from the floor, and each surround was 5'6" away from the sweet spot. The rear surrounds were 5 feet away from the sweet spot and located behind the couch. Each rear speaker rested on a 32-inch stand, putting it at approximately the same height as the side surrounds. The rears were 3 feet away from the wall, and 5 feet away from each other.
I used a Pioneer Elite SC-85 AVR as a pre-pro for the whole review, and a Crestron Procise ProAmp 7x250 7-channel amplifier provided power. I had miniDSP's DDRC-88A Dirac Live processor handle room correction for a 7.1 speaker configuration. (I used a simple passive splitter to feed both subs.) My sources included an Oppo BDP-103 Blu-ray player, a Roku 3 streaming box, and a DIY PC running Windows 8.1.
After placing the speakers, my next task was to create a profile using Dirac Live. You can read more about that process in my review of the miniDSP DDRC-88A DL processor here. One of the great things about Dirac Live is that it lets you choose how much of the audio spectrum gets processed. I used the feature to create two separate room correction presets for the review.
The first preset was optimized to apply a traditional house curve, with a slight downward tilt from bass to treble. The second profile restricted room correction to 180 Hz and under. I chose that frequency because I calculated it to be the point below which my room's standing waves dominate frequency response at the listening position. This point is known as the Schroeder frequency, and it normally occurs between 100 and 200 Hz, depending on the room's reverberant characteristics.
When I restricted room correction to below the Schroeder frequency, the "character" of the speakers was more evident. That character is partly a function of the speaker's dispersion and distortion characteristics interacting with the room—the space within which a speaker operates always affects the way it sounds. Using room correction and EQ throughout the entire audible frequency range helped remove the effect of the room. I expect many home-theater surround systems implement room correction, which is why I performed a significant amount of my listening with Dirac Live processing the entire signal, not just the bass.
One final setup note: I prefer room correction and symmetrical arrangements with subs up front regardless of whether or not I am reviewing a system. It saves space and looks good, and it practically eliminates any risk of localizing a sub when using a high crossover such as 100 Hz or 150 Hz. However, that arrangement only works if you have a processor that is effective at dealing with dips and humps in the bass-response curve as measured from the listening area.
Performance
This is a kick-ass home-theater surround system. I already covered the capabilities of the towers and the subs in prior reviews. When incorporated into the full 7.2 system, those components performed extremely well and provided the brute strength needed to give movie soundtracks physical heft. The rest of the speakers in the system exhibited a similar level of smooth, dynamic, precise, clear sound I heard coming from the towers.
The most notable characteristic of the Reference Premiere system is the quality of the treble. Whatever Klipsch did in redesigning its tweeter, the result is silky smooth highs without any loss of detail.
Thanks in part to the horn-loaded tweeters, Klipsch's Reference Premiere speakers feature high sensitivity for a consumer-oriented speaker. A mere 3 dB increase in sensitivity translates to needing only half as much amplification to get to the same output level. That means you can use a modestly powered AVR to drive the system and still achieve impressive output levels. Most speakers with regular dome tweeters require heftier external amplification to reach the same output levels the Klipsch achieve. For multi-channel home theaters based on an AVR, that's a good thing because you'll have more headroom during intense scenes, especially when there are many surround effects.
Because of the high sensitivity and high output capability of the Klipsch system—especially the RP-280Fs—I was able to run it with the Pioneer Elite SC-85's built-in amps, and in my room (which measures 11' x 20' x 9'), I had all the power I needed to get up to reference levels. However, the SC-85's built-in MCACC Pro room correction does not come close to Dirac Live in terms of sound quality or customizability. So I connected the MiniDSP DDRC-88A and profiled the speaker system using Dirac. You can read more about that process in the DDRC-88A review.
Dirac Live processing requires external amplification, and I used the Crestron ProAmp 7x250 for that purpose. Unlike the SC-85, it easily exceeds the power requirements of all the speakers in the system—even with all channels driven simultaneously.
Using the Dirac preset that restricts processing to 180 Hz and under, I cranked up the system for a stress test—reproducing the deep bumping and thumping sounds in the movie Gravity. During its more intense action scenes, Gravity's mix uses every speaker to its maximum capacity. I have the Atmos version of the Blu-ray, which the SC-85 decoded into an excellent 7.1 presentation.
Aside from the RP-280F towers, the RP-450C center is the star of the show. I'm not a huge fan of center-channel speakers because they are typically not able to keep up with high-quality left and right main speakers. In addition, a horizontal array of woofers often results in lobing issues. Nevertheless, the Klipsch center, with its 2.5-way configuration, not only sounded clear and precise, it managed to keep up with the powerful towers. As far as center speakers go, it's quite large. It's the only center channel I've reviewed that allowed me to literally rest the TV on top of it. But the size seems to pay off because it's performance is notably good.
In movies with good mixes, the soundfield generated by the Reference Premiere speakers was always enveloping. Furthermore, it was capable of rendering objects in precise locations. While watching Gravity, I was able to track each sound effect precisely as Sandra Bullock struggled with her predicament. The key is that all the speakers managed to disappear—even without using room correction. That's a major benefit of speakers with controlled directivity; the treble doesn't interact with the room as much. The only exception was the center speaker. Because of its lower height, it would draw my attention on occasion.
As nice as the soundfield was with Dirac Live processing only the bass region, using room correction for entire audible spectrum took the speaker system to a higher level of transparency. Crucially, it eliminated the apparent offset of the center channel. The character of the speakers didn't change much—it sounded quite neutral without EQ—but with full Dirac processing, all the speakers completely disappeared, leaving an even more holographic soundstage.
When it comes to movies, I covered a wide range of genres in the two months I used the system. I especially love space movies and sci-fi in general. Jupiter Ascending, Interstellar, Gravity, Chappie, Star Wars: A New Hope, Guardians of the Galaxy—all of them absolutely rocked.
The system also handled upmixed music well. I use the AVR's Dolby Surround feature when I listen to electronic music, and it really complimented albums from artists like Bassnectar, The Orb, Air, Dub Syndicate, Renegade Soundwave, Waterjuice, and Boards of Canada. Moreover, when I listened to acoustic recordings, be it jazz, classical, or folk, there was a tangible sense of a front stage with musicians on it and room ambience coming from the surrounds.
So far, I've heaped nothing but praise on this system. You might be wondering, what are its weaknesses? I'm not willing to say that sound quality is one of them. Frankly, Klipsch delivers exactly what I'd expect if I plunked down five grand for such a system: power, precision, nuance—it's all there. Yes, I've heard more refined speakers, but the Klipsches serve up sound with more gusto and still have enough refinement to put a smile on a skeptical audiophile's face.
I can criticize the binding posts. The nuts are made with plastic, as are the binding-post backplates, and they feel a bit cheap compared to metal binding posts I've seen on other speakers at the Reference Premiere line's price points. Granted, you never see them, and I'm sure it does not affect the speaker's performance one iota.
I can't say I have any other issues with fit or finish worth mentioning, at least not relative to the cost of the speakers. Yes, pricier speakers often come with fancier real-wood veneers or glossy paint jobs, but they often don't sound better than these do. The new tweeters are that good! There is a real sense of value to the system, thanks to the quality of the sound it creates.
As for the subs, I already covered their performance in my review. Still, it's worth noting that they did offer enough headroom to handle everything I threw at them. They are big subs with genuine room-shaking output that drops right into the infrasonic realm. I found that with Dirac Live processing, the bass in the system was extremely tight and crisp. More importantly, Dirac worked with the subs to reduce the effect of standing waves, and the reward was very even bass throughout the listening area.
Conclusion
Frankly, I never thought I'd be this enthusiastic about a mainstream Klipsch speaker system. Overall, Klipsch's system pulled off a performance that left my jaw on the floor more than a few times. Did you read the Thiel TT1 review I wrote a few months back? Those $6000/pair speakers were great performers. However, I could not wait to get those out of my system and put the Klipsch Reference Premiere RP-280Fs in—I enjoyed listening to the Klipsch towers quite a bit more. Whereas the Thiels never provoked goose bumps, the Klipsch system had my arm's hairs standing on end several times the first day I set them up.
In terms of performance, I think the Klipsch towers have as much or more to offer home-theater aficionados and music lovers alike, and at about one quarter the price. Make no mistake; the towers anchor the system with their prodigious output. Fortunately, the rest of the speakers keep up with them, making the system a very compelling offering. Indeed, it's probably the most dynamic and impactful surround system I've auditioned thus far—it can definitely shake your booty.
I should note that the Klipsch RP-160Ms are extremely good speakers in their own right. If you shrink the system down to 5.1 with just one sub and put the RP-160Ms up front, the result is still a killer system. Whereas the full 7.2 rig runs $5300, the aforementioned 5.1 system would run $3050. However, it's definitely a few notches below the 7.2 configuration I tested in terms of ultimate capability. I know money does not grow on trees, but the combo of big gun RP-280Fs and dual R-115SW subs really make the system something special.
For 2-channel music fans, it's worth noting that the RP-280Fs are extremely good at that task. This 7.2 system can easily perform double-duty as a pure 2-channel rig, or a 2.2-channel system if your AVR or pre/pro supports it. The towers are fantastic speakers, but the RP-160M bookshelf-style speakers are also great—I appreciated the opportunity to use them in a 2-channel configuration. Don't discount Klipsch for critical music listening; these speakers deliver a proper 2-channel experience.
The RP-450C center channel easily keeps up with its powerful peers. Furthermore, the wide-dispersion RP-250S surrounds really did their job with great competence—when I used the system in 5.1 mode, without the RP-160 rear channels, they provided a great sense of envelopment and kept up with the mighty front stage when things got loud.
There's a good reason it took me two months to get through this review—it's that I did not want to disassemble the system when I was done. I'm confident many of you can relate to what it's like to get your surround speakers dialed in just right. You don't want to give it up! Alas, with these words my time with the Klipsch Reference Premiere system ends. For movies, it's the most competent 7.2 surround system I've had the pleasure of testing to date. It made the Pioneer Elite 5.1.4 Atmos-compatible system I reviewed back in February seem like a toy. Indeed, if I had to choose between the two systems, I'd give up Atmos in a heartbeat for the superior overall audio performance of the Klipsch system.
While the Reference Premiere system genuinely blew me away, it has some very stiff competition coming up in the review queue. Because of advances in computer simulation and modeling as well as materials, today's speakers truly are better than ever. For Klipsch, incorporating those improvements puts it in the elite ranks of companies that make speakers capable of playing at reference levels without causing listener fatigue. This system can do precisely that, and a whole lot more, which is why it earns my highest recommendation.
REVIEW SYSTEM
Sources
DIY PC (Windows 8) running Tidal, Spotify, and iTunes
Amplification and Processing
Pioneer Elite SC-85 receiver
MiniDSP DDRC-88A Dirac Live processor
Speakers and Subwoofers
Klipsch RP-280F towers
Klipsch RP-450C center
Klipsch RP-160M bookshelf speakers
Klipsch RP-250S surround speakers
Klipsch R-115SW subwoofers (2)
Cables
Monoprice 12-gauge OFC speaker cables
Mediabridge Ultra Series subwoofer cable
Mediabridge Ultra Series HDMI cables
Monoprice Premiere Series XLR cables
TV
Samsung PN64F8500 64" plasma TV
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #2 of 129 Old 07-21-2015, 12:27 PM
javanpohl's Avatar
Quoted: 696 Post(s)
Liked: 379
Although it seems to be a rarity in this day-and-age, if you have pre-amp outputs AND inputs, can't you use it in an all-in-one receiver?
javanpohl is offline
post #3 of 129 Old 07-21-2015, 12:40 PM
BornSlippyZ's Avatar
Quoted: 1851 Post(s)
Liked: 1573
I am looking to upgrade my Klipsch center channel (RC3) and I think I the RP 450C will fit the bill.
Thanks for the review!
BornSlippyZ is offline
post #4 of 129 Old 07-21-2015, 12:47 PM
javanpohl's Avatar
Quoted: 696 Post(s)
Liked: 379
Great review! I've been drooling after Klipsch for a while now and this has got me even more so. But, man, I really wish Klipsch would create a bookshelf system somewhere in between their tiny 1x0 line and their THX system. It's like if you require a satellite system, with them you either can get a $1,500 system or a $15,000 system. Someday I guess I'll find room for towers.
post #5 of 129 Old 07-21-2015, 12:51 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11400
The RP-160M is tiny? It struck me as quite substantial and capable for a bookshelf speaker.
imagic is offline
post #6 of 129 Old 07-21-2015, 02:33 PM
kamouflage's Avatar
Quoted: 145 Post(s)
Liked: 97
Thanks for the review! I haven't been a fan of Klipsch in the past but that is not hearing their nicer line of speakers. I'm always interested in listening to something new. Never know, might even sway me away from my dream speakers and for a lot less money too.
PSN ID: javant86
Xbox Live: PikturePerfekt
kamouflage is offline
post #7 of 129 Old 07-21-2015, 02:41 PM
Blacklightning's Avatar
Quoted: 487 Post(s)
Liked: 325
+1
I would love to see a THX style LCR using the drivers from the Premiere Bookshelf, this way you could have another option for a center channel at this level. It seems like they had to do a few funny things to make there center channel bareable.
javanpohl likes this.
Blacklightning is offline
post #8 of 129 Old 07-21-2015, 02:47 PM
R Harkness's Avatar
Quoted: 2133 Post(s)
Liked: 1846
Good stuff. I often really enjoy speakers that employ horn loading well. They often have the dynamic "jump" effect of realism.
I'm getting darned intrigued about that Dirac processing.
R Harkness is offline
post #9 of 129 Old 07-21-2015, 03:23 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11400
Just a brief update... I sent a message to Klipsch to make arrangements for sending the system back, and my contact asked if instead I wanted to review the RP-140SA Elevation Speaker. I have two pairs on the way ASAP, so I'll be able to speak to how a variation of this system does in a 5.1.4 Atmos configuration.
imagic is offline
post #10 of 129 Old 07-21-2015, 03:41 PM
javanpohl's Avatar
Quoted: 696 Post(s)
Liked: 379
Comparatively
post #11 of 129 Old 07-21-2015, 03:50 PM
torii's Avatar
Quoted: 1567 Post(s)
Liked: 854
comments like this leave me thinking the sound of the system doesnt perform they way I like speakers to perform.
I like to have all my speakers disappear and just hear the sounds in space without saying in my mind they came from this speaker or that.
but your review leaves me wanting to demo this system. I always like klipsch when I was younger. They play loud with little power.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #12 of 129 Old 07-21-2015, 03:55 PM
Serenity_now's Avatar
Quoted: 49 Post(s)
Liked: 45
@imagic
Hey Mark, did you find any issues with overloading the room too easily? It looks like the towers would load the room on their own, plus those huge subs.
Anyone else look at the system pick and scratch their head?
JimSatala77 likes this.
Serenity_now is offline
post #13 of 129 Old 07-21-2015, 04:07 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11400
Originally Posted by Serenity_now View Post
@imagic
Yes and no. Without any EQ at all, there would be too much bass. But if you EQ the bass for good response in the listening area, definitely not. What you get is lots of headroom and extension.
morbidcorpse likes this.
imagic is offline
post #14 of 129 Old 07-21-2015, 04:45 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Great review, Mark! I greatly appreciate AVS's commitment to reviews of all these wonderful products.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #15 of 129 Old 07-21-2015, 06:21 PM
DigitalAV's Avatar
Quoted: 68 Post(s)
Liked: 30
Great review!
Would you still be able to use Dirac Live somehow (perhaps for just the 5.1 floor channels) in the 5.1.4 Atmos/DSU test?
Also, if possible, may I demand a Pepsi-challenge* of Atmos using the RP-160Ms (direct) vs. RP-250Ss (dispersion) as surrounds? I understand the RP-140SA elevation speakers in the rear need to lie atop the RP-160Ms, but I was thinking those could still stay in place and act as "stands" for the elevation speakers while only using the RP-250Ss as side-surrounds in a 5.1.4 Atmos/DSU test.
*Dang it, that reference means I'm officially old!
imagic and HT-Eman like this.
DigitalAV is offline
post #16 of 129 Old 07-21-2015, 06:41 PM
kopkiwi's Avatar
Quoted: 113 Post(s)
Liked: 72
Great review. Surprised how much more you like them over the Theils, didn't expect that if I'm honest.
Been looking at moving to Klipsch and selling my Wharfedale Jades to go down their Atmos set up route. This review only makes that decision a little easier.
kopkiwi is offline
post #17 of 129 Old 07-22-2015, 08:23 AM
eng-399's Avatar
Quoted: 1757 Post(s)
Liked: 3057
eng-399 is offline
post #18 of 129 Old 07-22-2015, 08:32 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11400
Originally Posted by eng-399 View Post
Mark do like these a lot more than the berry's that is being talked about in the speaker forum that you started over there. Just wondering.... Nice write up on these btw.
The RP-160M offers many of the same qualities—non-fatiguing highs from a horn—and better imaging, but at a somewhat higher price and with less peak output. As with the Behringers, using a sub is a good idea. The RP-280F outright beats the B215XLs IMO, with or without subs. Without subs, no competition whatsoever, Klipsch wins by a mile. Add subs and it is a much closer comparison but you can use a much wider range of crossover setting with the Klipsch towers including something low like 50 Hz that won't work with the Behringers. But, RP-280F is triple the price and not exactly wall-mountable.
eng-399 likes this.
imagic is offline
post #19 of 129 Old 07-22-2015, 10:30 AM
geocab's Avatar
Quoted: 53 Post(s)
Liked: 65
Thanks for the review. Anxiously awaiting the 5.1.4 impressions....
geocab is offline
post #20 of 129 Old 07-22-2015, 10:41 AM
RochRx7's Avatar
Quoted: 44 Post(s)
Liked: 42
Beautiful review.. the speakers seem to be the perfect blend of sound and aesthetics.
This system is now my next life goal.. thanks again Mark!
Denon X4100W | Chane A5rx-C | Klipsch RW12d
RochRx7 is offline
post #21 of 129 Old 07-22-2015, 04:15 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Mark, the SC-85 is a beefy AVR. It's version of MCACC is competent as well. I would liked to have seen you use this as the sole source for your review.
jhughy2010 is offline
post #22 of 129 Old 07-22-2015, 04:42 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11400
Did you see my recent DDRC-88A review? Overall, MCACC does not do as good a job as Dirac Live does. As far as the amps go, I don't think it would have made any difference unless I clipped the SC85, which in my space would mean playing the system dangerously loud.
But, here's the deal. A pair of RP-280FAs are on their way to me right now. For the 5.1.4 review I have planned, I'll use nothing but the SC-85 and MCACC.
morbidcorpse and jhughy2010 like this.
imagic is offline
post #23 of 129 Old 07-22-2015, 06:23 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Yes that was a great review Mark. I only ask because I thought you had mentioned you were going to only use the SC-85 for this review. I'll be looking forward to the 5.1.4 review.
post #24 of 129 Old 07-22-2015, 07:00 PM
dprice18af's Avatar
Quoted: 81 Post(s)
Liked: 73
Mark, how does the R115SW compare to the SVS PB/PC2000?
dprice18af is offline
post #25 of 129 Old 07-22-2015, 07:07 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11400
Before I send them both back, I'll specifically do a PC-2000 vs. R-115SW comparison. Without doing that, I can only say they are fairly similar, but the PC-2000 is lighter and takes up less space whereas the Klipsch looks absolutely badass.
imagic is offline
post #26 of 129 Old 07-22-2015, 10:27 PM
dprice18af's Avatar
Quoted: 81 Post(s)
Liked: 73
Thanks Mark! I look forward to hearing your results. The Klipsch does look awesome. Love the copper.
post #27 of 129 Old 07-23-2015, 01:19 AM
Quoted: 859 Post(s)
Liked: 189
Hi Mark
I'm currently using the Klipsch RS-62 II speakers for my surrounds... but I'm thinking about going with the RB-81's instead since direct firing would be more ideal for Atmos? Have you heard either of those speakers in action?
Aras_Volodka is offline
post #28 of 129 Old 07-23-2015, 03:51 AM
Quoted: 431 Post(s)
Liked: 346
I love the Klipsch sound and look, just wish this sub could compete more with the ID players like HSU, Rythmik and PSA becaseu form a cosmetic integration it is killer with the rest of the Klipsch line. Would love to see numbers on data-base.com
LG 65C7P
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #29 of 129 Old 07-23-2015, 09:30 PM
Lobo44's Avatar
Quoted: 132 Post(s)
Liked: 38
Great review and it sure helped out this rookie. Question for me is do Klipsch speakers still suck? I have an old system that is going to slowly get replaced so a review of this type has me looking at Klipsch again. The system I have as well as placement problems don't work well together but by the review it seems Klipsch is on the right track.
I don't have the coin to throw $7k at speakers or the required space as well. Do I wait for Klipsch to hopefully put some of this tech into their lower lines or move on to something else?
Denon 4520CI / HK AVR-80:HK ADP303 AC-3
Klipsch SW15-II Sub / Klipsch Sub-12
Klipsch 2.1 Bookshelf
Klipsch 3650C Surround
Energy RVS Center
Samsung LN46A650A1F
Lobo44 is offline
post #30 of 129 Old 07-23-2015, 10:29 PM
meenoo5's Avatar
Liked: 3
Great review. How do the fronts compare to the flagship RF-7ii's is the question!
LR Klipsch RF7-II
C Klipsch RC64
Surrounds: KEF LS50
meenoo5 is offline
Reply Speakers
frontpage , Klipsch , reference premiere , rf-7 ii
