Speaker Wire help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old Today, 03:27 PM - Thread Starter
Liked: 0
Speaker Wire help
Sorry for the newb question but here it is:
I bought a house that has in-wall speakers for its home theater setup (surround). I'm assuming the in-wall speaker wire is 14 awg (or possible 12 awg)..now should I also run 12/14 awg from the wall plate to my receiver? Or would 16awg/18awg be better? Should it always match when possible? As you can tell, I'm not really speakeducated.
Thanks in advance.
Ginuwine84 is online now
post #2 of 4 Old Today, 04:09 PM
bluewizard's Avatar
Quoted: 865 Post(s)
Liked: 326
14 ga covers a vast majority of circumstances.
To some extent, it depends on the wire length, but I suspect unless you have very unusual circumstances, 14ga would be fine, and is reasonably priced.
Steve/bluewizard
bluewizard is online now
post #3 of 4 Old Today, 04:18 PM - Thread Starter
Liked: 0
Steve/bluewizard
Thanks Steve.
The wire length would be about 3/4 feet from plate to receiver. Would that make a difference?
Thanks again.
post #4 of 4 Unread Today, 05:41 PM
bluewizard's Avatar
Quoted: 865 Post(s)
Liked: 326
Originally Posted by Ginuwine84 View Post
Thanks Steve.
Thanks again.
No, around 50ft total per speaker is where problems begin.
Here is a chart of excepted wire lengths for various gauges and varions speaker impedance.
FYI: % Signal Loss for Speaker Wire Length
Generally, 5% loss is acceptable, but I've calculated lower percentages. It is actually quite easy to achieve low percentage of losses with common wire lengths.
Steve/bluewizard
Steve/
Reply Speakers
speaker wire
