I hope I'm in the right forum.
I just purchased a new home and I'm in the process of setup a movie room/man cave. I currently have an old Kenwood 5.1, Klipsch Quintet II's, and Yamaha YST-SW315 sub that I purchased back in 2004-2005 timeframe. I have set aside $2K to spend on setting up a new home theater system and I have to say there are so many speaker systems and brands out there that I don't know where to start. I'm looking for a 7.1 system and would like the capability to use Dolby Atmos at some point. I don't think I need to replace the Yamaha sub. I'd rather save that and spend towards the other speakers.
My room size is 14x14 with hardwood floor that I plan on placing a rug or something to reduce echo. I have a Blu-ray player and digital cable box that I'll be using in the mix, both HDMI. Hopefully this is enough information to get started.
Thanks for the help.
