Hi everyone I am putting together a list for Santa and still looking for speakers, AVR and Blu-Ray player.
I have read on AVS that the 3.1 speakers produce most of the sounds so I need to focus on this objective within a $1,000 budget, but cheaper and good quality is better. Eventually I will get the remainder of the matching timber speakers that I have read about in 6-12 months so please do not recommend speakers that are not discontinued.
Speakers will be used for movies only. Wife (easy listening) and I (rock/rap) don't agree on most music so you get the point for only movies and staying happily married.
I am concerned by certain speaker designs that have woofers on the side because my walls are not a square and look like a letter "J" shown below, the 12' wall is the screen wall.
My stick design is not being saved as designed. So front screen wall is 12 feet, right wall extends 57" from the front, left wall is 15 feet and the back wall comes 44" from the left wall.
The open areas include the dining room and foyer. Even worse the ceiling slants down from left (10') to right (8'). Wish I had a design program. I am attaching a photo of the foyer back side of the room with Picasso print and also front of the room with 57" wall to the right. Thanks in advance.
