Please help finish my theater room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-04-2016, 10:38 AM - Thread Starter
Liked: 0
I purchased a home which already had a theater room skeleton. I now have a projector, a screen, and have finished the floor. However I do not have the knowledge to finish out picking the speakers that would fit best or the receiver to utilize. The room has pre-cut holes as shown in the pictures with measured dimensions. The A/V receiver would be in a large closet on the other side of a wall.
ID:	1160858   Click image for larger version
ID:	1160866   Click image for larger version
ID:	1160874   Click image for larger version
ID:	1160882   Click image for larger version
jmanatt is offline
post #2 of 2 Old 01-04-2016, 03:45 PM
Quoted: 352 Post(s)
Liked: 105
If you are redoing the room, I would definitely do the wiring first before even thinking about what AVR or which speakers will be used.
Left/Right-Front : 4 banana plugs on each side (in case you want to bi-amp/bi-wire or setup front-height, it's there for you)
Center : 2 banana plugs
Left/Right-Rear : 4 banana plugs on each side (in case you want to have 2 surround-back, it's there for you)
Subwoofer : at least 2 out of 4 corners (in case you want to have .2)
Total number of banana plugs x2 (one set is placed close to your AVR)
If you're Atmos/DTS:X fan, then doing 2 or 4 more ceiling speaker, future proof
tinhvo is offline
Reply Speakers
