Suggestions for Left, Right, Center speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-20-2016, 09:05 AM - Thread Starter
Liked: 0
Hello there,
Can someone suggest me a good speakers for Left,Right, Center that have smaller foot print(not more than 6 inches in width, I do have space ocnstraint here) Klipsch R14s were good for me but they were a little too big for my space.
This would be helpful in 5.1 setup that I am planning to have.
Taurus26 is offline
post #2 of 6 Old 01-20-2016, 09:10 AM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 757
Do you have a budget?
Afro GT
afrogt is online now
post #3 of 6 Old 01-20-2016, 09:22 AM - Thread Starter
Liked: 0
800 for the three of them, sorry for missing that initially.
Taurus26 is offline
post #4 of 6 Old 01-20-2016, 09:22 AM - Thread Starter
Liked: 0
Taurus26 is offline
post #5 of 6 Old 01-20-2016, 09:25 AM - Thread Starter
Liked: 0
For rears I do have Polk OWM3.
Receiver is Denon AVR-S710W 7.2
If you guys could suggest a sub under 300 that would be great too!
Taurus26 is offline
post #6 of 6 Old 01-20-2016, 10:03 AM
Zorba922's Avatar
Quoted: 2230 Post(s)
Liked: 1575
Sounds like you have a total budget of $1100 for 3 fronts and the sub? I'd spend a lot more on the sub and less on the speakers in that case.
If you can live with a 6.5" wide speaker, I'd take a look at this one, $428 shipped for 3 of them:
http://www.ascendacoustics.com/pages...00/htm200.html
If you can't, this $100/each:
http://www.nhthifi.com/products/1065...2-nht-pc-hi-fi
Or this $200/each, used vertically for L/R and horizontally for the center
http://www.nhthifi.com/products/1113...speakers#specs
All of the above are sealed designs which is what allows them to be so compact. Another advantage they have over the much more common rear ported design is that they can be placed flush against a wall if necessary.
If you go with the less expensive options, you'll be able to get a sub in the $400-600 range which would make action movies a lot more enjoyable (if you like action movies...if not, a cheaper sub would be fine).
Zorba922 is online now
Reply Speakers
