Klipsch Heresy III or Vandersteen 1ci - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Steve Crowley
  • 1 Post By jim_ma
  • 1 Post By psycholis
post #1 of 13 Old 03-25-2016, 06:17 PM - Thread Starter
benfica1's Avatar
Quoted: 14 Post(s)
Narrowed down my choices to these 2 speakers. Both made in the US. Looking at used. For anybody that has listened to both of these speakers, which is better for rock and blues for a medium sized room?
benfica1 is offline
post #2 of 13 Old 03-25-2016, 10:24 PM
RayGuy's Avatar
Quoted: 996 Post(s)
Liked: 878
Vandersteen ... if you have the room for them. They require very specific placement away from walls. If you have a cramped room, or WAF issues with speakers out into the room, then keep looking.
RayGuy is online now
post #3 of 13 Old 03-25-2016, 10:35 PM
Steve Crowley's Avatar
Quoted: 47 Post(s)
Liked: 73
I've had the Heresy's since late 70's. For rock they are a great little speaker. Very efficient and take little power to get loud. You will need a sub for anything below 50hz. I am using them now for my side channels as I picked up some LaScala's. Still need a sub if your going to watch movies though. Heard Vandersteens years ago, great speaker but required much more power.
Horn speakers tend to be bright but that's what tone controls are for. I don't think there bright at all as I play trumpet and Clark Terry never sounded so good on my LaScala's. I would listen to each with the same material and let your ears be the judge in the end. Make sure you use the same amp and source. Happy listening.
Rob-Houston likes this.
Klipsch so much it Hz
OTA all the way
79 LaScala's
78 Heresy's
Onkyo, Grommes
Thorens
Steve Crowley is offline
post #4 of 13 Old 03-26-2016, 04:55 AM
mmiles's Avatar
Quoted: 576 Post(s)
Liked: 255
I have owned the Heresy and Cornwalls back in the early 80's.
Great speakers.
Mike Miles
mmiles is online now
post #5 of 13 Old 03-26-2016, 07:18 AM - Thread Starter
benfica1's Avatar
Quoted: 14 Post(s)
WAF is an issue. Recommend any other speakers for rock in the $1000-$1200 price range?
benfica1 is offline
post #6 of 13 Old 03-26-2016, 07:23 AM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Paradigm? Again, you will more than likely need a sub to compliment them. I have 15 year old Monitor 9's and they rock great. And they are not bright like the Klipsch. I used to own Klipsch Forte II's btw. Glad I went with Paradigm.
Jeff
pronghorn/az is offline
post #7 of 13 Old 03-26-2016, 08:17 AM
jim_ma's Avatar
i heard the heresy iii a few weeks ago and was really impressed -- small footprint, intended to be near the walls, throws off a huge soundstage, beautiful sound. i heard them through a plininus 880 integrated (80w/chnl) and it didn't even break a sweat.
witchdoctor likes this.
jim_ma is offline
post #8 of 13 Old 03-26-2016, 09:15 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The PSB X2T are great speakers, and actually have a pretty fair amount of bass, while the Vandersteen 1 and Heresy have zip, zero, none.
You might be OK with no subwoofer with the X2T speakers, depending on how much bass you want; with the others a good subwoofer would be absolutely mandatory.
THe list price on the X2T is $1250 per pair.
commsysman is offline
post #9 of 13 Old 03-26-2016, 09:22 AM
witchdoctor's Avatar
Quoted: 754 Post(s)
Liked: 200
I vote Klipsch.
witchdoctor is offline
post #10 of 13 Old 03-26-2016, 09:18 PM
RayGuy's Avatar
Quoted: 996 Post(s)
Liked: 878
PSB and Paradigm, as recommended in the thread, are good choices. You might also look into ELAC and Chane for online retailers. If "pretty" is important, look at Emp Tek speakers ... nice looking and nice sounding.
Do yourself a big favor and go out and listen to as many speaker brands as you can ... once you understand what each offers, you will make a much better decision. Otherwise, you run the risk of buying something you want to trade in in six months or a year.
post #11 of 13 Old 03-27-2016, 06:20 AM
Class A's Avatar
Quoted: 433 Post(s)
Liked: 1727
Thumbs up
Heresy III's are very room friendly and you'll have a wide range of power to choose from. A 35wpc Prima Luna Integrated makes a great combo.
Class A is offline
post #12 of 13 Old 03-27-2016, 07:05 AM
psycholis's Avatar
Quoted: 67 Post(s)
Liked: 68
If you're looking at used anyway and want the same sound of the heresy but with more bass extension, consider the forte ii. Same basic layout as the heresy but in a floor stander with 15" rear firing passive radiator. They won't have the titanium drivers from the heresy iii but they are available for purchase to drop in directly.
Marantz SR-5007 Klipsch WF-35, RP-450C, WB-14 theater
Marantz 2325 Klipsch Forte ii stereo
SVS PB-2000
LG 55LN5600
Sony PS3, Xbox 360, Wii U
psycholis is offline
post #13 of 13 Old 04-02-2016, 11:31 AM
Quoted: 17 Post(s)
Liked: 4
I have Heresy 3 with a small JBL sub, Sansui AU 919 amp and Rega planet CD player. This combination is very hard to beat in the stereo world, very clean, true and dynamic sound. Klipsch and Vandersteen are very different technologies. If you prefer horn loaded sound which is similar to listening to life music go with Klipsch. If you prefer true, clean and easy going sound, go for Vandersteen.
vonamah is offline
Reply Speakers
