Matching wall-mount speakers for Mission 753s and 75C - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-21-2016, 10:47 PM - Thread Starter
rkheagle's Avatar
Liked: 0
Can anyone recommend some wall-mountable surround speakers to pair with my Mission 753s and 75C? I'm moving into a new house and putting in Atmos 5.1.4. I currently have an old Onkyo HTIB 7.1 set that has served me well, but I'm taking the opportunity to upgrade my system. Fortunately, my dad is a stereophile, and is giving me his old Mission 753s. I was also lucky enough to find a Mission 75C on eBay. My problem is now finding some wall-mountable surround speakers to match. From what I can tell, Missions (except the new M3 compact series) are only designed for floorstand or bookshelf. If it matters, I'm likely headed towards Polk MC80s for the in-ceiling and an Onkyo TX-NR1030 AVR. Any recommendations would be appreciated. Thanks!
rkheagle is offline
post #2 of 3 Old 05-22-2016, 11:48 PM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
Polk OWM 3 is often used as an inexpensive surround solution.
RayGuy is offline
post #3 of 3 Old 05-23-2016, 04:16 PM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
The 751 was a bookshelf version of the 753 – same tweeter, which is important for timbre matching the fronts and surrounds. See if you can snag a pair on ebay. There may be other compatible models as well – you’re looking for one with the same tweeter as the 753, and if possible the same woofer, or perhaps a smaller version of the same woofer.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
Reply Speakers
