Need some speaker stands for my room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-29-2016, 07:27 PM - Thread Starter
Julio Castrejon's Avatar
Quoted: 120 Post(s)
I don't want to spend too much on a pair of speaker stands, but I want something good.
Please view my picture to see why I need a pair of speaker stands.
My desktop is exactly 30 inches high, so my speakers almost sit at ear level, but barely hanging on my desktop. I need more room! Since my brother is finally moving out, I will now have more room to spare and I can finally get some speaker stands.
I was thinking of getting these:
http://www.amazon.com/BF31-B1-Speake...A33ZFW15ZO0RKP
They are about 30 inches high which will match the same height as my desktop, and I was wondering if these are alright? Should I get something a little higher like 34" to 36" to match my ear level?
I want to get good speaker stands, but also spend no more than $100 for them.
My speaker dimensions are W 8 3/8" X H 12 5/8" X D 13"
I'm not sure if a 5" X 5" platform will hold it well.
Julio Castrejon is offline
post #2 of 13 Old 05-29-2016, 07:52 PM
darthray's Avatar
Quoted: 939 Post(s)
Liked: 892
The advantage you would get by using those stands, is it give you more freedom to space them further apart, a plus for better stereo separation.
I think the platform would be sufficient, as long you do not have kids or pets to knock them over.
Using something similar to this product would help the speaker from moving due to vibration.
http://adhesives-equipment.com/partn...ck/article.php
So, I would go for it at this price
Ray
darthray is offline
post #3 of 13 Old 05-29-2016, 08:13 PM
Zorba922's Avatar
Quoted: 2212 Post(s)
Liked: 1567
There's absolutely nothing wrong with those Sanus MDF stands...I used to use that exact 31" pair for my Ascend 340 speakers many years ago and they were super sturdy.
Currently I'm using a pair of 24" ones directly on top of my desktop since it's a standing desk, and with the stands the tweeters on my monitors are exactly at ear level. When I was in grad school, the desk in my dorm room had a built-in hutch where I had the monitors (I was sitting then) and I much preferred having the tweeters a good 12-18" ABOVE my ear level rather than having them flat on the desk since the desk would totally kill the sound.
However, a cheaper experiment I would try first is using some thick rubber wedge doorstops you can buy at Home Depot to angle the speakers upwards from your desk, towards your ear level...if needed you could combine the doorstops with foam yoga pads for extra elevation (2-pack of yoga pads go for under $10 on Amazon).
Or you could get angled speaker pads if you want a neater-looking solution:
http://www.amazon.com/Adam-Hall-SPAD...s=speaker+pads
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 13 Old 05-30-2016, 06:34 PM - Thread Starter
Quoted: 120 Post(s)
Alright, thanks. I'll get them for sure. I'll post pictures of how it looks after.
post #5 of 13 Old 05-30-2016, 06:43 PM
Alanlee's Avatar
Quoted: 206 Post(s)
Liked: 104
Consider building your own speaker stands.
7.4.4 system with Denon 5200 (Height 1, Height 2), Emotiva XPA-5 (front, center), NAD 275 (front, middle Surround), NAD 275 (Rear Surround), All Klipsch speakers: Cornwall (front), 2 Heresy (center), 2-kg-1.5 (front surround), 2-kg-1.5 (middle surround), 2 RS-7 (rear surround), 4 KSW 15 (sub), 2 SA-2 height-1, 2 SA-2 height-2, Oppo 103, Mac Mini (network), Apple TV (DNLA), Roku 4, 3TB My Book (DNLA), Dell PC (Network), Vizio UM-P702uiB3, Logitech Harmony Companion, X-box one s
Alanlee is online now
post #6 of 13 Old 07-20-2016, 08:53 PM - Thread Starter
Quoted: 120 Post(s)
Well It's finally here, and finally setup!
post #7 of 13 Old 07-20-2016, 08:56 PM
torii's Avatar
Quoted: 781 Post(s)
Liked: 397
nice looking stands...point the speakers at your ears, see if it sounds better or worse
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is offline
post #8 of 13 Old 07-20-2016, 09:16 PM
chuccck's Avatar
Quoted: 119 Post(s)
Liked: 70
Those like like the Sanus NF30C I just got. Are the stands in your picture the same you linked earlier?
chuccck is offline
post #9 of 13 Old 07-20-2016, 09:19 PM - Thread Starter
Quoted: 120 Post(s)
Yeah, I'll try that next time I listen to music critically. I can honestly say that it sounds much better than before specially since the sound is more isolated now and no longer resonating on my desk. I'm getting a new dresser soon which is much more narrower, so I should have even more space soon.
I'm not completely happy with the Yamaha though. I like that it sounds very clean with amazing accurate sound, but they are not very musical. I'm thinking of putting my Onkyo TX-SR313 back or sacrifice my main 5.1 setup by putting the Anthem MRX 300 back.
post #10 of 13 Old 07-20-2016, 09:21 PM - Thread Starter
Quoted: 120 Post(s)
I got these ones instead:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I got it for $86 shipped before I went up again. It's actually a solid piece of hardwood and not hollow. It was worth spending the extra because the real wood matches the decor.
post #11 of 13 Old 07-20-2016, 09:24 PM
chuccck's Avatar
Quoted: 119 Post(s)
Liked: 70
Yep same as mine. I used the rubber corner feet instead of the metallic pins.
chuccck is offline
post #12 of 13 Old 08-27-2016, 05:41 PM - Thread Starter
Quoted: 120 Post(s)
Once again, I upgraded my entire stereo setup.
Anthem MRX 300
Paradigm Studio 10 V5
The difference in sound quality is just unbelievable. It's simply amazing.
post #13 of 13 Old 08-27-2016, 08:31 PM
Zorba922's Avatar
Liked: 1567
Anthem MRX 300
Well, you did upgrade from those plastic Aiwa shelf stereo speakers after all. Enjoy!
Zorba922 is offline
Reply Speakers
