Question on Def Tech StudioMonitor 65s - AVS Forum | Home Theater Discussions And Reviews
Old 06-22-2016, 09:10 PM - Thread Starter
hingerson's Avatar
Quoted: 71 Post(s)
Liked: 37
I live in a town home so I wonder if these would be overkill or just plain to loud? Also Would using them in just 2 channel even for movie's be pretty awesome?
hingerson is offline
Old 06-22-2016, 09:21 PM
lovinthehd's Avatar
Quoted: 4170 Post(s)
Liked: 4052
Loudness depends on the volume level you play back at. Your bass travels well through walls depending on construction, but I'd still prefer to add a sub and center beyond a 2.0 setup, even for just music but definitely for movies. Control of the volume is yours to manage....
lovinthehd is online now
Old 06-23-2016, 01:32 PM
ALtlOff's Avatar
Quoted: 857 Post(s)
Liked: 404
@lovinthehd is correct, volume itself is completely controllable, where you run into issues when sharing a wall or space is Bass.
If you like DefTech's, the 65's would be my first choice for a bookshelf in a No Sub application, they are very full sounding.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
