LCR Help!! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Zorba922
post #1 of 3 Old 07-07-2016, 07:44 PM - Thread Starter
fonz5000's Avatar
Quoted: 119 Post(s)
Liked: 36
LCR Help!!
I am needing some help picking mostly the Center channel. I have to do In Wall for the Left and Right but can have a normal center. But what do I get ??? I would like to maybe spend around $400 for the center and around $200 for each Left and Right.
fonz5000 is offline
post #2 of 3 Old 07-07-2016, 08:03 PM
Zorba922's Avatar
Quoted: 3870 Post(s)
Liked: 2777
Pair of Hsu HIW-1 with HC-1 center speaker will fit that bill nicely.
http://www.hsuresearch.com/products/hiw-1.html
http://www.hsuresearch.com/products/hc-1.html
Blacklightning likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 3 Old 07-08-2016, 12:32 PM
Blacklightning's Avatar
Quoted: 487 Post(s)
Liked: 325
^ DONE^
Case closed
Blacklightning is offline
Reply Speakers
