2.1 system with subwoofer - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 1 Post By lovinthehd
  • 1 Post By Kini62
  • 2 Post By GIEGAR
  • 1 Post By afrogt
  • 2 Post By hmcfly
post #1 of 28 Old 09-28-2016, 09:01 AM - Thread Starter
hmcfly's Avatar
Hi it's been awhile since I've been here. I'm building a budget 2.1 system, I got the Pioneer SP-FS52 speakers and was wondering if I need a subwoofer with it? I also am wondering about the placement of the subwoofer, does it need to be in the middle or can it be placed out to the side? Will you be able to hear the bass if it's out to the side. I have a Yamaha R-S500 reciever with 80 watts of power.
hmcfly is offline
post #2 of 28 Old 09-28-2016, 09:28 AM
GIEGAR's Avatar
Quoted: 837 Post(s)
Liked: 1427
Yes, the vast majority of speakers will benefit from the addition of a capable sub. The Pioneers are no exception.
Placement? In the middle, out to the side, halfway down the side wall, in the back corner... all are fine. The best spot for the sub is where it gives you the best combination of SPL and frequency response. Have a go at this and the sub will tell you what's the best of your available spots:
Additional reading: http://www.svsound.com/blogs/svs/753...ofer-placement.
GIEGAR is offline
post #3 of 28 Old 09-28-2016, 09:34 AM
Quoted: 99 Post(s)
Liked: 44
In my experience you don't need a subwoofer with the Pioneers, but it certainly helps. All depends on what your budget is.
A subwoofer will always help though because your main speakers are not capable of getting down low enough to give you the full range of sound. They only go down to 40Hz so you're missing any content below that and I doubt the Pioneers have much output at 60Hz and below anyways. You'd have to look at a frequency response chart, but I'd recommend getting a decent sub and crossing your system over at 80Hz.
AVR - Yamaha RX-V679 || Fronts - Bowers & Wilkins 684 S2 || Center - Bowers & Wilkins HTM62 S2 || Surrounds - Bowers & Wilkins 686 S2 || Subwoofer - SVS SB-2000 || TV - Vizio M50-C1
dbalkaran is offline
post #4 of 28 Old 09-28-2016, 09:55 AM
Ralarcon's Avatar
Quoted: 178 Post(s)
Liked: 147
If you really want to be budget conscious, consider this:
http://www.bestbuy.com/site/klipsch-...OCAaAm398P8HAQ
They are really good.
If you want to be somewhat budget conscious consider this;
https://www.amazon.com/MartinLogan-D...gan+dynamo+300
it is outstanding.
Good luck with your quest.
Cheers
Ralarcon is offline
post #5 of 28 Old 09-28-2016, 10:03 AM
pase22's Avatar
Quoted: 1368 Post(s)
Liked: 1144
A sub is definitely going to improve your listening experience. We would need you to provide us with a budget and room dimensions so that appropriate recomondations can be made.
Kef Q100 FL/FR,SL/SR, Kef Q200C, Bic F12 sub, Denon AVR-S710W, , Panasonic 50" Plasma, cable box, Xbox One, Toshiba laptop.
Bedroom: JBL Loft 50 FL/FR , Loft 20 center, JBLSP 150 sub, Pioneer VSX-830K, PS3, 32" Insigna LED.
pase22 is online now
post #6 of 28 Old 09-28-2016, 10:09 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
While your receiver has a sub pre-out it doesn't have bass management. You might look for a sub that has an actual crossover (i.e. not only a low pass filter but also a high pass filter for your speakers so as not to duplicate frequencies being reproduced).
GIEGAR likes this.
lovinthehd is offline
post #7 of 28 Old 09-28-2016, 10:30 AM - Thread Starter
hmcfly's Avatar
Ok you lost me on this. How do you tell about these filters? I'm sorry I very new to the new systems, do you have any in mind
hmcfly is offline
post #8 of 28 Old 09-28-2016, 10:32 AM - Thread Starter
hmcfly's Avatar
The room is about18x18 and I would not like to go over $200.
hmcfly is offline
post #9 of 28 Old 09-28-2016, 11:03 AM
lovinthehd's Avatar
Liked: 4783
Modern avrs have what are called crossovers, to set a frequency transition between sub and speaker (a combination of a low pass filter for the sub and a high pass filter for the speaker). Try this article http://audiophilereview.com/subwoofe...ubwoofers.html
Some subs can provide the high pass filter either by line level input and output (and your receiver can work with such) or with speaker level input and output (putting the sub in line with your speakers). Have to read the manual/specs to know what the sub has....
post #10 of 28 Old 09-28-2016, 01:06 PM - Thread Starter
hmcfly's Avatar
I found a subwoofer that pairs with my Pioneer speakers and it has a crossover dial it's the Pioneer SW-8MK2
I also found this one that also has a crossover dial Polk PSW110
These are ones that I can afford trying to stay under $200
hmcfly is offline
post #11 of 28 Old 09-28-2016, 01:18 PM
lovinthehd's Avatar
Liked: 4783
SW8MK2 may suffice in a small room for music, not much can be expected from an 8" sub generally. The dial is a low pass filter only it appears. It may have a fixed crossover on the high level inputs/outputs....but without a manual hard to know.
PSW110 also only has a low pass filter, no mention in its manual of any sort of high pass filter.
You may not mind the duplication of frequencies on the other hand....and at your budget your choices are very limited....
post #12 of 28 Old 09-28-2016, 01:38 PM
Kini62's Avatar
Quoted: 1746 Post(s)
Liked: 1558
IMO this sub would be much better than either of the two you mentioned and the price is right.
It does have a low/high cut switch and from the manual in the high position it looks to be at around 80hz. Plus with Amazon it's pretty hassle free if you don't like it.
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
lovinthehd likes this.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #13 of 28 Old 09-28-2016, 01:44 PM - Thread Starter
hmcfly's Avatar
Thanks I was also looking at the yamaha
hmcfly is offline
post #14 of 28 Old 09-28-2016, 09:19 PM - Thread Starter
hmcfly's Avatar
I'm giving up on the Pioneer and the Polk. My new one is KLIPSCH 10" Front-Firing 250w Peak Power Subwoofer (K100-SW). It has
Low pass crossover and phase control. The question I have is it runs fron 100w to 250, is my YamahaR-S500 with 80w going to be able to power it?
https://www.amazon.com/KLIPSCH-Front...ct_top?ie=UTF8
Also the Yamaha YST-SW216BL Subwoofer has a 45w to 100w.
hmcfly is offline
post #15 of 28 Old 09-29-2016, 04:05 AM
GIEGAR's Avatar
Quoted: 837 Post(s)
Liked: 1427
As with most subs, the Klipsch has an integral amplifier. Your Yamaha only needs to provide line-level signal to the sub, not power it.
Don't place too much emphasis the subs claimed power figures. Subs are a integrated system of amp, driver and cabinet. What you need to look for are the system results (not the inputs), including low frequency extension (-3dB) and SPL, if available.
dsrussell and sigpig like this.
GIEGAR is offline
post #16 of 28 Old 09-29-2016, 06:42 AM
afrogt's Avatar
Quoted: 1440 Post(s)
Liked: 983
You can do much better than those two subs for $200. Where are you located?
Afro GT
afrogt is offline
post #17 of 28 Old 09-29-2016, 06:49 AM
gregoryperkins's Avatar
Quoted: 509 Post(s)
Liked: 197
Once you've experienced a good sub, you'll regret all the money you wasted on cheap subs. I recommend waiting and getting something like an entry level svs. It blows away my Velodyne 12" and EMP 1010 (dual 10" drivers).
gregoryperkins is offline
post #18 of 28 Old 09-29-2016, 07:05 AM - Thread Starter
hmcfly's Avatar
Southern California 60 east of LA
hmcfly is offline
post #19 of 28 Old 09-29-2016, 07:33 AM
Quoted: 99 Post(s)
Liked: 44
The Pioneer is really not a bad sub for the money and he can always use it with a computer system later on. A decent sub is better than no sub. I've owned the Pioneer towers and the Pioneer sub before and they really do a nice job for what they are. If you expect audiophile grade sound out of them you'll be disappointed, but for their price point they sound excellent. I've found they can be re-sold pretty easily as well when you've saved up more and are ready to upgrade because the Pioneer name is more recognizable than most other brands of equipment among the general population.
post #20 of 28 Old 09-29-2016, 11:53 AM
afrogt's Avatar
Liked: 983
since you live in SoCal you do have Fry's fairly close by. They have the Klipsch 10" K-10SW for $174 thru Saturday and 12" K-12SW for $217 thru Thursday. both are better than the Klipsch KSW-10 you linked and also the Pioneer and Polk subs you mentioned.
I would get one of those if your budget is around $200.
Name:	Klipsch R-10SW.PNG
ID:	1691889   Click image for larger version
Name:	Klipsch R-12SW.PNG
cel4145 likes this.
Afro GT
afrogt is offline
post #21 of 28 Old 09-30-2016, 04:22 PM - Thread Starter
hmcfly's Avatar
I have one an hour away I'll go look thanks.
hmcfly is offline
post #22 of 28 Old 09-30-2016, 05:13 PM
afrogt's Avatar
Liked: 983
check to make sure they're in stock before you make that drive. They can reserve it for you.
www.frys.com
City of Industry and Anaheim have the R-10SW. the 12" sale is over now. It'll come back though.
Afro GT
afrogt is offline
post #23 of 28 Old 10-01-2016, 02:13 AM
pase22's Avatar
Liked: 1144
A sub for less than $200 most often leads to dissapointmement. There are better budget subs on the market, here is one to consider and currently on sale. It's a little over your budget but will actually save you money since you won't need to upgrade in 3-4 months.
https://www.amazon.com/Bic-Acoustech...rds=bic+pl-200
post #24 of 28 Old 10-01-2016, 04:57 AM
WLDock's Avatar
Quoted: 73 Post(s)
Liked: 106
There's always the used market...and the art of a little negotiating!
Outlaw Audio LMF-1 - $240 https://losangeles.craigslist.org/la...785374933.html
AV123 MFW15 - $200 http://santabarbara.craigslist.org/ele/5782451604.html
Adire Audio Rava - $250 https://losangeles.craigslist.org/la...797164432.html
WLDock is offline
post #25 of 28 Old 10-01-2016, 11:25 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
That LFM-1 would be a great sub, and $240 is a decent price. I used to have one. It will go very low and hit very hard when it needs to.
I'd avoid the MFW15. They had trouble with the amps. Might end up having to replace it. Don't know anything about the Rava.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #26 of 28 Old 10-01-2016, 02:59 PM
Quoted: 70 Post(s)
Liked: 6
If you read the online pdf manual for the SVS pb-1000, I believe it says there is a fixed low pass and high pass filter at 80hz.
raxxx is offline
post #27 of 28 Old 10-02-2016, 03:41 PM - Thread Starter
hmcfly's Avatar
Well thanks to all that answered my post.
I got a Klipsch R-10sw like Afrogt suggested and I very happy with it.
cel4145 and WLDock like this.
hmcfly is offline
post #28 of 28 Old 10-02-2016, 05:39 PM
WLDock's Avatar
Quoted: 73 Post(s)
Liked: 106
Enjoy it!
WLDock is offline
Reply Speakers
