KEF Introduces LS50 Wireless Active Speakers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #31 of 190 Old 10-17-2016, 07:01 AM
Mikenificent1's Avatar
Quoted: 95 Post(s)
Liked: 31
Originally Posted by wse View Post
I use 7 LS50 in Home Theater setting in a 12 x 13 x9 feet room!
I cross them over at 80HZ and sit about 7 feet away from the front and two feet away from surround and back and the sound is amazing
So for those who say the LS50 doesn't work for HT makes me laugh
Now going back to my question could the new wireless ones be used as surround? I love the fact that they have great amplification integrated in them less boxes.
In fact I could see a system where one could use seven of them with a nice prepro like the Marantz 8802. Too bad they dont' have XLR
I'm not sure if the 8802 is truly balanced so maybe just use AES/EBU to RCA cables to each speaker. What sub(s) are you using with the LS50's? How does the sound compare to your main system?
Mikenificent1 is online now
post #32 of 190 Old 10-17-2016, 09:57 AM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 806
Exclamation
Originally Posted by KenM10759 View Post
I don't believe anyone is contending that the LS50 won't work in HT. My suggestion is that it's hard to place them in some applications, especially if you don't have room behind them. Being a rear-ported speaker which really does benefit to a great degree from placement in relation to walls and corners, there may be better choices.
If a couple yours are placed close to walls (and probably are given the smaller room), you're likely not getting the full value of what they are capable of doing. I'm sure they sound great, just betting there's more in them than you're getting from some of them.
Probably, but from 2 feet away they sound amazing!
wse is offline
post #33 of 190 Old 10-17-2016, 09:59 AM
wse
wse's Avatar
Liked: 806
Question
Originally Posted by crn3371 View Post
Depends on what you're after. $700 is about half of what I paid to amplify my LS50's, plus $200 for a DAC module.
What amp do you use?
wse is offline
post #34 of 190 Old 10-17-2016, 10:11 AM
Elpee's Avatar
Quoted: 69 Post(s)
Liked: 25
It comes out just in time. I'm looking for 4 ceiling speakers for my Atmos/ DTS:X system...
Elpee is offline
post #35 of 190 Old 10-17-2016, 10:24 AM
drewTT's Avatar
Quoted: 797 Post(s)
Liked: 814
Nice. I really enjoyed the LS50s in my desktop setup.
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | roon
drewTT is offline
post #36 of 190 Old 10-17-2016, 12:26 PM
wse
wse's Avatar
Liked: 806
Wink
Two Snap AV ES-SUB-TRP10-500-BLK
https://www.snapav.com/shop/en/snapa...-trp10-500-blk
https://www.snapav.com/wcsstore/Exte...TRP_Manual.pdf
Might replace them with https://elac.com/product-category/debut-subwoofers/ I like their auto EQ
The AVR I use is Marantz SR-7009
wse is offline
post #37 of 190 Old 10-17-2016, 12:46 PM
wse
wse's Avatar
Liked: 806
Now I wonder how they will compare to these
http://www.dynaudio.com/professional-audio/lyd/lyd-8/
A pair would $1578 instead of $2500
Now it is true that the KEF LS50 active has
- 230-watt x2 amplification in a bi-amp dual mono configuration: LF: 200W HF: 30W
- 2.4GHz/5GHz Dual-band Wi-Fi,
- Bluetooth 4.0 with the aptX codec
- Up to 192kHz USB Type B
- Up to 96kHz TOSLINK Optical
- RCA Analog
- Subwoofer output
http://www.kef.com/uploads/images/LS...et_EN_path.pdf
http://www.kef.com/uploads/images/LS...9_20160905.pdf
wse is offline
post #38 of 190 Old 10-17-2016, 01:01 PM
KenM10759's Avatar
Quoted: 1537 Post(s)
Liked: 815
Isn't the list price of the new LS50 active $2200, not $2500? That's the price my dealer gave me, and I hadn't even asked.
It doesn't appear that Lyd-8 has a built-in DAC. The Dynaudio Xeo-2 might be a closer comparison, though I don't understand that speaker having equal power amps for LF and HF.
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Ortofon 2M Red, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #39 of 190 Old 10-17-2016, 03:52 PM
Tank_PD's Avatar
Quoted: 135 Post(s)
Liked: 72
I had just assumed the LYD-8 required ADC in order to apply all the trim settings.
I have a KEF X300A and adjusting the volume is mainly the setting on the computer. I'd like a physical knob. Would you use the LYD-8 with a dac/preamp? Or would I be stuck with software volume only? It doesn't look like the LYD-8 has any volume control.
At least the wireless KEF LS50 has a remote w/ volume buttons. The streaming options are pretty light on details though --I'm concerned they dropped Airplay.
Tank_PD is offline
post #40 of 190 Old 10-17-2016, 04:18 PM
KenM10759's Avatar
Liked: 815
AirPlay streams iTunes, doesn't it? Perhaps they considered the high licensing fees of Apple and decided to forgo it as it's not the high quality audio those speakers thrive on.
I'd be streaming Tidal Hi-Fi and my own library of FLAC files through a Bluesound Node 2 if (when) I get a pair.
post #41 of 190 Old 10-17-2016, 09:01 PM
callas01's Avatar
Quoted: 956 Post(s)
Liked: 584
The LYD is a lower cost professional active studio monitor with analog input only and I believe the volume is controlled either be the mixing board or laptop you're using.
The Xeo2 $1500 or Xeo 4 $2400 (including the hub) would be direct competition. FWIW the Xeo 2 won Best Active Speaker of the year for What Hi-Fi.... If that matters any.
Will be interesting to hear them compare the LS50 to the Xeo2 when the time arrives.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
post #42 of 190 Old 10-17-2016, 10:18 PM
Tank_PD's Avatar
Quoted: 135 Post(s)
Liked: 72
There is more than enough quality in ALAC ripped from CDs.
Tank_PD is offline
post #43 of 190 Old 10-18-2016, 04:44 AM
KenM10759's Avatar
Liked: 815
I know nothing about AirPlay and it's data rates other than to notice it seems to be waning in popularity as aptX Bluetooth becomes more universally accepted. And of course Wi-Fi is ubiquitous at this point in time. I'm OK with that because I don't own any Apple products and plan to own none. I do not dispute the quality of ALAC files ripped from a CD, and most DAC devices will process those files. So educate me, is AirPlay more than just a form of wireless data streaming and also has a user interface?
The newer AV receivers and pre-processors from a lot of manufacturers also seem to be abandoning AirPlay. Why is this?
post #44 of 190 Old 10-18-2016, 09:44 AM
Liked: 6
I remember a receiver review a few years back at the Secrets of Home Theater website that noted that the Airplay functionality in the receiver had pretty high THD vs. the other inputs. I don't know if it is endemic in the standard or was a function of implementation.
I am cross shopping the KEFs against Dynaudio. I bought my Dad some Xeo 3s a couple years back and was really impressed with the sound quality, though the hub was a bit of a PITA.
If the KEFs review well, they are going on my Christmas list.
Angling for perfection with tangential success...
Absorbed & Diffused is offline
post #45 of 190 Old 10-20-2016, 02:03 PM
Nick V's Avatar
Quoted: 78 Post(s)
Liked: 72
I was in the market for a pair of passive LS50's, now here these active versions come to confuse things.
I have experience with active studio monitors in my Bedroom System (Tannoy Reveal 501a driven by a Cambridge DacMagic Plus), Computer System (M-Audio BX8 D2 driven by an LH Labs Geek Out Dac) and in my office system at work (Fostex PM0.4n driven by an LH Labs Geek Out) IMO they provide tremendous value at their price points, but the built in wireless streaming, internal DAC and DSP in these active LS50's really confuses things for me (especially because I already use Chromecast Audio throughout the house for wireless streaming).
The system where I'm in the market for LS50's is currently my main system. I have an LH Labs Vi DAC Tube DSD DAC on the way (if they ever ship) and I have an extensive collection of DSD music along with other high resolution music (both physical SACD's and DVD-Audio discs along with high resolution files). If I run the system through the analog inputs with an external DAC with the A/D then D/A conversion am I losing more that I'm gaining with the time alignment and DSP active crossover or am I still coming out ahead? It appears to me that these speakers are really designed to be used with the DAC that's built-in as an all-in-one type of system.
Would it make sense to still go with the Active LS50's in my system, or do the passive versions make more sense? Which would perform better? I was going to buy 3 passive LS-50s for the L/C/R in a hybrid 2-channel/home theater system.
My System:
80Wpc Blue Circle BC-24 amp with increased internal power supply capacitance (increased by 200% for the tube stage and 150% for the output stage)
Preamp (w/ HT Bypass for 2-channel music) - Wyred4Sound STP-SE
HT receiver - Anthem MRX 300
Subwoofer - Mirage BPS 400 (Dual opposed 12" beast)
Streaming - Chromecast Audio
Main System: Vizio 70" P-Series 4K TV. KEF LS50 Speakers. Mirage BPS 400. Anthem MRX-300. Wyred4Sound STP-SE. Blue Circle BC 24. Cambridge DACMagic +. Oppo BDP-83. Sound Application CF-X. GIK Panels
Living Room: Vizio 55" M-Series 4K HDR TV. GoldenEar 3D Array X. Rythmik L-12. Denon AVR-X3200. Oppo BDP-83
Studio: KEF Egg Wireless Speakers. Totem Kin Subwoofer. Yulong P-18 Power Conditioner. GIK Panels
Nick V is online now
post #46 of 190 Old 10-21-2016, 09:27 AM
Ppuno's Avatar
The pre order is up on the KEF website for $2199.99!
Shipping starting December.
Ppuno is offline
post #47 of 190 Old 10-24-2016, 04:31 AM
Sallex's Avatar
Quoted: 14 Post(s)
I just love my passive LS50s. This active version is really interesting though. I would have loved to exchange my passive LS50 fronts and my Hegel amp and connect these to the pre out on my receiver, but I guess I'm out of luck with the aux connection?
Sallex is offline
post #48 of 190 Old 10-24-2016, 05:14 AM
KenM10759's Avatar
Liked: 815
By "aux connection" I assume you mean a 3.5mm stereo socket. What device is it that you currently use in an Auxiliary connection that you couldn't supplant with the aptX Bluetooth or other digital or analog input those speakers offer?
post #49 of 190 Old 10-24-2016, 05:32 AM
Sallex's Avatar
Quoted: 14 Post(s)
I meant that it would be nice to use these speakers in a HT setup with a receiver and exchange the passive front speakers and my integrated amp that drives the front speakers. But I guess that's not possible.
Sallex is offline
post #50 of 190 Old 10-24-2016, 05:48 AM
KenM10759's Avatar
Liked: 815
Why wouldn't you be able to use the pre-outs from your receiver to the analog input of the LS50 wireless speakers? I'm sure there's a way. You might have to get a specific cable, but that's fairly cheap.
post #51 of 190 Old 10-24-2016, 07:50 AM
wse
wse's Avatar
Liked: 806
Exclamation
The have L&R RCA Analogue inputs. So yes theoretically then can be used in a Home Theater setting.
https://www.kefdirect.com/media/wysi...et_EN_path.pdf
That would be a great way to have no amplifier
https://www.kefdirect.com/media/wysi...9_20160905.pdf
wse is offline
post #52 of 190 Old 10-25-2016, 04:43 AM
Sallex's Avatar
Quoted: 14 Post(s)
Thanks, it sounds like I could use them as fronts in a HT setup then? I would like to use the amp section from the Kefs instead of the avr amp, as I'm doing today with the Hegel, to get superior sound when compared to avr only. And of course use the Kefs only when listening to music either from PC or streaming. If this is possible then I will invest for sure.
Sallex is offline
post #53 of 190 Old 10-25-2016, 07:24 AM
wse
wse's Avatar
Liked: 806
Wink LS50 Active for Home Theater!
My understanding is that it is possible use the RCA connection to your AVR
Here is what I heard: "In regards to using the LS50 Wireless for home theater, if your AVR had outputs for RCA they could be used. The master LS50 W in the pair has RCA inputs for L and R so if you had RCA outs on your AVR for each channel this could potentially be done."
In addition "One speaker is the master unit with all the inputs. The master unit connects to the secondary unit with a Cat6 Cable.
Each individual speaker has 230 watts of power:
- 30watts class a/b amplifier for its tweeter, and
- 200watt class D amplifier for its mid-bass drivers."
wse is offline
post #54 of 190 Old 01-05-2017, 10:02 AM
Quoted: 192 Post(s)
Liked: 93
The licensing fees for Airplay are not high and AptX also has a licensing fee. Lots of low end speakers and other devices have airplay built in. The least they could do is AAC over bluetooth which would be compatible with idevices and would be a smart move. Bluesound should also have Airplay built in for that matter.
SoCalCyclist is offline
post #55 of 190 Old 01-11-2017, 03:06 PM
Quoted: 192 Post(s)
Liked: 93
My Kef LS50 wireless arrive Friday :-)
KenM10759 likes this.
post #56 of 190 Old 01-11-2017, 04:15 PM
KenM10759's Avatar
Liked: 815
Nice! It seems earlier than promised, so keep us posted. I suggested to them they should have added MQA decoding to the DAC, perhaps there can be a firmware upgrade in the future.
post #57 of 190 Old 01-11-2017, 04:16 PM
Quoted: 192 Post(s)
Liked: 93
Sure will. I am also interested in MQA now that it is in Tidal and not sure how I will do it.
I'm getting them from a dealer but the KEF web site shows them in stock right now too.
post #58 of 190 Old 01-12-2017, 06:11 AM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1391
It seems like Wisa as a wireless audio standard is totally dead. Every single manufacturer seems to be doing it via Bluetooth and/or Wifi or their own concoction. Sad.
(low energy!! haha)
RLBURNSIDE is offline
post #59 of 190 Old 01-12-2017, 06:36 AM
KenM10759's Avatar
Liked: 815
(low energy!! haha)
I have no clue what that "Wisa" is but will argue that Bluetooth and Wi-Fi are both very common, widely accepted and commonly used. I don't see many audio products deviating from those lately. What's the issue?
post #60 of 190 Old 01-12-2017, 06:49 AM
KenM10759's Avatar
Liked: 815
Cool that you're getting them from a dealer. I appreciate supporting the brick & mortar places so they're still there when we want to audition different products.
I had also gone to KEF Direct and notice the page for LS50 Wireless had changed from "Pre-Order" to "In Stock." What a sharp contrast to so many others. In my case, it's NAD who announces something they should have had 6 months ago, takes another 9 months or more to ship it, then has to send out firmware updates so it'll work.
KEF USA has been outstanding. I contacted them yesterday via the "Contact us" on their US non e-commerce website. When I bought my R500 as floor demo units (from my local dealer, of course) a little over a year ago, one of the little rubber center plugs from the locking knobs on the leveling spikes of the plinth was missing. The dealer had made me aware of it, and being a demo pair I accepted that little issue for the discount I got. Well, KEF is sending me a replacement plug, gratis. They responded within an hour or two by calling me to ask my mailing address. This is a company I continue to admire and want to do business with, the level of support is exemplary. And the products and pretty darn good!
hpp8140 likes this.
Reply Speakers
