Hi all, I'm looking for some advice on my upgrade
1) Your budget.
$1000-$1500. I'd like to stay closer to $1000 if possible.
2) Your listening interests: movies/gaming/music--and whether or not any of those are your primary concern.
For movies, mostly netflix and other 1080p sources (like PC).
For music, mostly electronics, rock, and sometimes pop. I care about good tight bass (doesn't need to be loud).
I don't play game on TV, but I might play some party games (which doesn't have that much focus on audio)
3) Your existing audio equipment (make/models) if any. Include comments about what you hope to improve upon.
TV: ----------------- Samsung UN65KS8000 (4k)
Front: -------------- 2 Energy C100
Center: ------------- Energy C-C50
Rear: --------------- Infinity Primus 150
Sub woofer: -------- Energy S10.3 (it's much better than I expected)
Receiver: ----------- Harman Kardon AVR 254 (no longer has the calibration mic)
Cable:-------------- 14AWG 100ft
4) The size of your room. Please also mention if there are adjacent open areas and how big they are (important for subwoofer choice).
around 16x16, but has a high ceiling (2 floors). Also connects (semi open) to a family room and a kitchen. Basically, it looks spacious.
5) Any placement restrictions.
The TV is gonna be a bit far from the sofa (from one end to the other end of the wall). TV wall mounted, but I can get a media center below that to house the AVR.
6) Any aesthetic or size concerns.
Nope.
7) Any equipment you are already considering (or would not consider).
Emptek R55Ti x2 (front)
Emptek R56Ci
Emptek R5Bi x2 (rear)
SVS SB12-nsd
Some Denon AVR. For some reason I like the Denon sound signature; but I haven't tried any high end AVR from them yet (nor from anyone). I have a Denon D2000 headphone, and I love it.
Considering:
AVR-S710W
AVR-S720W
AVR-S910W
AVR-S920W
AVR-X2200W
AVR-X3200W
I also would like to reuse the Harman Kardon if possible (maybe I can save some $$?).
8) Any particular audio sonic signatures you know you prefer (e.g., you are a basshead, you have a preference for bright treble, etc.)
I have the Denon D2000 and Fostex TH-X00 headphones. I absolutely love them both, if that helps explain my preference . My family tend to listen to audio in lower volume too. My parents like bass, but they always turn the subwoofer (Energy S10.3) down a bit because "too much bass can't handle".
9) Extra random questions
- Do I need a new receiver? The Samsung TV can upscale 4k well enough I think. It also has an optical audio out. I'm okay with buying a new AVR; just that I feel I don't need that. I like the idea of having Audysses calibration though
- Which speaker stand to get for the surround speakers?
- It's gonna be pretty hard to mount speakers on my living ceiling due to the shape of the house. How would I take advantage of Atmos in the future? Is there some type of stands I can use?
- Do you recommend getting 2 subs? If so, would double SVS SB12-nsd a good idea? Most likely I feel like I'll only use 1 sub though, since I mostly listen to stuffs with low volume.
- Does the 14AWG wire work with the new speakers, or should I get a different one?
- Recommendation for any other stuffs that I might need for a complete build.
Thanks a lot! I hope I can get some recommendations/advice soon so I can catch the shopping season deals
1) Your budget.
Nope.
Emptek R56Ci
SVS SB12-nsd
Considering:
AVR-S710W
AVR-S720W
AVR-S910W
AVR-S920W
AVR-X2200W
AVR-X3200W
