What speakers do YOU own? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 1300 Old 01-15-2004, 06:41 AM
racecar's Avatar
Sonus Faber
Main-Grand Piano Home
Rear-The Wall
Center-Solo
REL
Sub-bass-Storm III
racecar is offline
post #362 of 1300 Old 01-15-2004, 07:39 PM
worldcat's Avatar
Aerial 9's!!!!
worldcat is offline
post #363 of 1300 Old 01-16-2004, 08:40 AM
Stryf3's Avatar
Got a new Yamaha NS-C444 for Christmas, so....
Yamaha NS-777
Yamaha NS-C444
Yamaha YST-305
RCA Bookshelf (from RadioShack with dipole tweeters) for surround.
I just made you up to hurt myself....
Stryf3 is offline
post #364 of 1300 Old 01-16-2004, 12:59 PM
Abeyta's Avatar
M&K 5.1
Fronts: S-150's
Center: S-150AC
Surrounds: S-150AC
Sub: MX150mkII
and saving for 2 more S-150AC's for surround backs.
Abeyta is offline
post #365 of 1300 Old 01-16-2004, 06:41 PM
snakama's Avatar
PSB Image
5T
9C
2B
HKsub 12
snakama is offline
post #366 of 1300 Old 01-17-2004, 09:03 PM
snakebite55's Avatar
Jeez what happened to all those people like me who bought Diva's by Swan a few years ago. Guess they all upgraded or something.
5.1
2.1
R3
C3
HSU VTF-2
Denon 3801
Mike
snakebite55 is offline
post #367 of 1300 Old 01-18-2004, 12:39 AM
DeletedUserPost's Avatar
All speakers-Klipsch RB-75
Subwoofer Klipsch RW-12 (X2)
see for yourself
http://www.geocities.com/figarou_dvd
DeletedUserPost is offline
post #368 of 1300 Old 01-18-2004, 12:13 PM
LCSeminole's Avatar
Quoted: 92 Post(s)
Liked: 74
Fronts: Klipsch KLF-20's
Center: Klipsch KLF-C7
Surrounds: 4 Klipsch RB-5II's
Subwoofers: Velodyne CHT-15, Cerwin Vega SUB-150
Emotiva XMC-1/XPR-2/XPR-5/DC-1
Samsung UN65KS9800, Oppo UDP-203
Furman PL-PRO DMC 20A, Monster Power HTS-5000
SVS Dual PB12-Plus Subwoofers
Klipsch Legend KLF-20 & KLF-C7(Crites Tweeter/Midrange Diaphragms & Crossovers)
Klipsch Reference RB-5II x 4(Side/Rear Surrounds)
LCSeminole is offline
post #369 of 1300 Old 01-18-2004, 12:22 PM
Tarron_D's Avatar
Fronts: JBL S38II's
Rears: K05B50's from Speakerpage.com
Center: No center currently
Sub: Adire Rava
Amp: JVC Rx-778V
Tarron_D is offline
post #370 of 1300 Old 01-18-2004, 12:44 PM
hoyalawya's Avatar
Quoted: 208 Post(s)
Liked: 62
Fronts: JBL S38II
Center: JBL S Center II
Surrounds: JBL S26
Sub: SVS 20-39 PCi
Just ordered 2 pairs of JBL S38II to replace the S26 and finish the 7.1 setup.
hoyalawya is offline
post #371 of 1300 Old 01-18-2004, 01:39 PM
Gx35's Avatar
Fronts: B&W DM 601 S3
Rears: B&W DM 600 S3
Sub: DIY (Sonotube - Dayton Titanic 10" sealed)
Gx35 is offline
post #372 of 1300 Old 01-18-2004, 05:47 PM
Sweet Spot's Avatar
So far, I appear to be the only person with these speakers. And I wonder what that says about them. Probably nothing I imagine, but I found it interesting to note a bunch of posts back that someone said that no one ever mentions Paradigm, when basically, that name sticks out all over the place, along with all the other usual suspects.
Mains: Energy C3's
Rears: Energy CR3's
Still need to buy the center and sub. Center will obviously be Energy. Sub is undecided. And I'm geared towards buying the Outlaw 950/7100 Combo. At the moment I'm using a pair of Rat Shack Optimus speakers being powered by an Onkyo TX-SV 515 Pro receiver. I refuse to hook the Energy's up yet. Not till I get my new pre/pro or w/e.
I'll definetely upgrade the mains when I move out of my NYC studio apt.
Sweet Spot is offline
post #373 of 1300 Old 01-18-2004, 09:27 PM
scooterdog's Avatar
Liked: 37
Klipsch La Scala ( Mains)
Custom Built Center Using All Klipsch Drivers
RFC5 Rear Surround Center
Klipsch RSS6 Surround Side (a)
Klipsch RSS .5 Surround Side (B)
Klipsch KSW 12 Subwoofer
My Home Theater Page http://www.geocities.com/scooterb4u/ScootersHT.html
scooterdog is offline
post #374 of 1300 Old 01-18-2004, 09:57 PM
Az Barber's Avatar
Who built your center? Which mid horn is that? Does the shape of the horn color the sound any differently than the horns in the mains?
The reason I ask is that I'm in a very similar situation. My mains are very similar to the Klipschorn and use the same drivers. I'm currently using the Klipsch center, but I think a larger center would sound better next to the larger mains. I also want a vertical speaker to prevent lobing. Do you mind me asking the budget for the center speaker?
Az
Az Barber is offline
post #375 of 1300 Old 01-18-2004, 10:52 PM
Stryf3's Avatar
Man this thread is long, and boring. Too little new happening here.
Stryf3 is offline
post #376 of 1300 Old 01-19-2004, 06:14 AM
windmiller's Avatar
Fluance SX-HTB 5 speaker setup...and I love them!!!
windmiller is offline
post #377 of 1300 Old 01-19-2004, 01:17 PM
scooterdog's Avatar
Liked: 37
AZ
I built the center myself. the cabinet is 42"w x 13,5"h x 15"d. Cabinet is made out of 3/4" marine grade oak plywood with complete internal bracing and wired with 12 gauge monster cable. I am using 2-Klipsch KV1089 10" woofers out of a Klipsch RF7, T35 horn tweeter(aka Klipsch K77), and a Klipsch K52 midrange horn with the 90°x60° Tractrix® Horn out of a Klipsch KLF30. Crossover is a 3-way, 2nd order (12dB) crossover with a 3 octave spread between crossover points. I used Metallized polypropylene capacitors in critical midrange and tweeter signal paths. 18 gauge inductors are used to keep DC resistance to a minimum. crossover points are 700/5600. There are 2- 4" flared ports in the rear of the cabinet
The only part I did not due myself was the front motorboard. I had a cabinet shop do the special rabbiting bscause of the shape of the woofer flange. I wanted to make sure everything was completely flush.
The trick is to make sure that the internal cabinet is braced very good, which I have done. I added 2 smaller horizontal braces. Once I install the acoustic foam to the inside this should do it. I would have prefered to use solid oak but the cost is so high and very hard to find in anything over 12"wide. I am not a big fan of MDF. It is discusting to work with and makes a mess. Yes it is pretty dead cabinet
This center sounds excellent. Measurments are 38hz to 17.5Khz 100db 1 watt input.
The off axis sound is exceptional!
post #378 of 1300 Old 01-19-2004, 03:42 PM
translog's Avatar
WP6 - Fronts
Watch Centre
Watch Left side -right side
Watch Left Rear - right rear
ML all front end
Lexicon MC12 - surround - passes threw ML 32 for fronts.
Halcro DM58 for L/R Fronts
ML 436 Mono for Centre
ML 335 for the Left side and right rear
ML 335 for the Right side right rear
Yeah baby...
When the puck drops, be there !
translog is offline
post #379 of 1300 Old 01-19-2004, 05:26 PM
Az Barber's Avatar
Thanks for the info Scooterdog.
Az
post #380 of 1300 Old 01-23-2004, 08:10 PM
bbeeson's Avatar
Canton L800 for L/R
Canton CL400 center
Canton M10 for surrounds
all in Silver Lacquer. and a Velodyne DD10 to boot. Not only do they completely rock, but its gorgeous too!
bbeeson is offline
post #381 of 1300 Old 01-27-2004, 08:05 PM
bborzell's Avatar
Quoted: 26 Post(s)
Liked: 58
L/R Front - Energy RefConns
L/R Rear - Energy Pro 22s
Center - HTD Level 3
Center Rears - TBD
Sub - NHT (forgot the model) Everything is packed up for a move
...Bob
2nd round OPPO BDP-83 EAP Selectee
bborzell is offline
post #382 of 1300 Old 01-27-2004, 10:47 PM
goombawa's Avatar
Quoted: 46 Post(s)
Fronts: Vienna Acoustics Weberns
Sub: Hsu STF-1
When the credit card cools down I'll get a 3rd webern for the center channel. Then, after another cooling period, I'll get 2 Bergs for the rears and be done with it. Finally.
Sidenote: Still not sure if I should get the Vienna Acoustics Subson sub...but at twice the price of the stf-1 and the fact that I can't crank my system too loud (live in an apt) I think I'm good to go with the stf-1.
goombawa is offline
post #383 of 1300 Old 01-27-2004, 11:02 PM
egcarter's Avatar
Little Room:
5.1 System
L/R Front: Polk LSi15
Center: Polk LSi/C
Surrounds: Polk LSi/Fx
Big Room:
7.1 THX Ultra2
Front L/C/R: Jamo D7LCR
L/R Surround: Jamo D7SUR
L/R Rear: Jamo D7LCR
Sub: Velodyne DD18
Eric
egcarter is offline
post #384 of 1300 Old 01-28-2004, 08:25 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Mains B&W 804's
Center B&W HTM1
Rears B&W 804's
Sub Velodyne 15" Servo
William is offline
post #385 of 1300 Old 01-29-2004, 01:30 AM
dommo's Avatar
LR Jamo D830
d8 center
d8 surrounds x4
martinlogan decent sub
dommo is offline
post #386 of 1300 Old 01-29-2004, 08:33 AM
jseahawk's Avatar
Athena S.5
jseahawk is offline
post #387 of 1300 Old 01-29-2004, 09:08 AM
KingKong954's Avatar
B&W DM 602 S3 L/R
B&W LCR60 Center
B&W DM 601 S3 surround L/R
HSU STF-2 Sub
KingKong954 is offline
post #388 of 1300 Old 01-29-2004, 09:41 AM
Mike7200's Avatar
Def Tech BP10B mains
Def Tech Procenter C2
Hsu STF-3 sub
Added 3/10/04:
Def Tech BP2X surrounds (4)
Deleted 3/10/04:
Bose double cubes for surrounds and rear surrounds
(Hope to become pure Def Tech by the end of the year)[color=crimson]
Mike7200 is offline
post #389 of 1300 Old 01-29-2004, 10:01 AM
zangler's Avatar
B&W CM4's mains
B&W CMC Center
In Ceiling rears
Denon 2803
zangler is offline
post #390 of 1300 Old 02-01-2004, 08:41 AM
fizbin's Avatar
L/R, Surround L/R: Onix Rocket RS 750
Center: Onix Rocket RSC 200
Subs (2): SVS 25-31 PC+
'Awesome' is overused but appropriate.
fizbin is offline
Reply Speakers
