Help a newbie pick out a set up - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By gajCA
  • 1 Post By Doe Doe
  • 1 Post By Zorba922
  • 2 Post By Zorba922
post #1 of 25 Old 02-09-2017, 09:50 PM - Thread Starter
Liked: 0
Hi all, I've been reading the forum when researching speakers and whatnot but in a little bit of a dilemma. Recently, the Home Theater in a Box I have started having issues. The player powers on and off repeatedly becoming almost unuseable.
Model of the HTIB system is: Samsung HT-E6500W
First question is, would I be able to reuse the speakers if I simply purchase an AV Receiver? If not I would like help selecting pieces. I do not need a fancy 5.1 or greater set up right now as the speakers and whatnot would be in the family room, so no problem in starting with a simple set up then improving later. With all of that out of the way, lets move forward.
1) Your budget.
If possible, I would like to stay under $500
2) Your listening interests: movies/gaming/music--and whether or not any of those are your primary concern.
It would be used for everything, mostly tv and sometimes video games and music
3) Your existing audio equipment (make/models) if any. Include comments about what you hope to improve upon.
Currently I have the sub and speakers from the Samsung HT-E6500W that was mentioned above and would like to reuse them if possible. If not, look at number 7 too.
4) The size of your room. Please also mention if there are adjacent open areas and how big they are (important for subwoofer choice).
I am not sure on the size of the room, but it is fairly open and connects to the kitchen as well as the main entrance and stairs.
5) Any placement restrictions.
There is a fireplace and so far, the tv is not wall mounted so its on a stand. Also the couch is one of those one piece multisection couches.
6) Any aesthetic or size concerns.
Nothing too crazy or anything that I can think of, although my parents may not agree lol
7) Any equipment you are already considering (or would not consider).
Equipment I am currently considering is as follows:
AV Receiver: Yamaha RX-V381BL
Possible speakers: Polk T50 tower or maybe even Klipsh RC62II (from what i can tell they are not really matched together, but both do have decent deals going on them right now).
8) Any particular audio sonic signatures you know you prefer (e.g., you are a basshead, you have a preference for bright treble, etc.)
When it comes to listening to music, i do prefer some bass, but I also like to actually hear the vocals and not have them be drowned out by the bass. Plus a majority of the time, the system will be used for tv watching.
Please let me know if there is anything that I've missed. I do hope to get started on this asap.
rsbuttar is offline
post #2 of 25 Old 02-10-2017, 04:10 AM
MORT A POTTY's Avatar
Quoted: 36 Post(s)
Liked: 47
Your budget is super tight for a receiver and a set of speakers but here is what we can do...
http://www.pioneerelectronics.com/PU...eivers/VSX-531
Pioneer VSK-531. - $250
http://elac.com/product/debut-b5/?r=us
Elac B5 speakers. - $229 / pair.
If you can stretch it further, definitely look at the step up in speakers if you can but I'm respecting your budget.
MORT A POTTY is offline
post #3 of 25 Old 02-10-2017, 07:27 AM
Quoted: 183 Post(s)
Liked: 233
It's a little hard to tell from the Samsung site, but do your speakers have the typical binding posts/connectors on the back (one red, one black - or some combination)? If so, then the simple answer to your question is, yes - you could connect those existing speakers to a new receiver.
If they don't, then the easiest solution would probably be to get a new receiver and at least a 3.0 (your left, center, right channels) speaker setup.
You could save yourself some money and buy your receiver from accessoriesforless.com. They sell refurbished items. I've never bought a receiver from them, but have bought several speakers and they work just fine. Others in AVS have bought receivers from AFL.com and have reported similar findings.
Then you could use a little more money toward a better speaker setup. Keep in mind, if you have the means to go audition some (Best Buy Magnolia theater, local AV place, etc.) you can find what sounds best to your ear.
Also keep in mind, a complete setup can take time. You can always start with a solid 2.0 or 3.0. Then add a sub later. Then add surrounds after that. You definitely don't need to throw a complete system together, especially if you want to achieve good sound with a smaller budget.
Samsung 55" JS8500
7.1 Setup:
Onkyo TX-NR646, Chane A1.4 & A2.4 (LCR), Yamaha NS-IC600 surr, TDG Audio NFC-61 back surr, SVS SB-2000
Samsung K8500, Roku Premiere+ and Roku 2, Harmony 650
jfwilliams1 is offline
post #4 of 25 Old 02-10-2017, 09:39 AM
gajCA's Avatar
Quoted: 4297 Post(s)
Liked: 2748
With that budget you can get a 3.0 system from Philharmonic Audio for around $350 and a $150 5.1 refurb AVR from Accessories for less or a 3.0 system from Q Acoustics for around $320.
Page down to see the center channel:
http://philharmonicaudio.com/aa.html
Receivers, I'd stay away from Onkyo as it is the most unreliable brand according to AVS member experience.
http://www.accessories4less.com/make...ceivers/1.html
Q Acoustics.
https://www.qacoustics.com/bookshelf...aker-pair.html
https://www.qacoustics.com/home-thea...l-speaker.html
Geoff A. J., California
gajCA is offline
post #5 of 25 Old 02-10-2017, 09:44 AM - Thread Starter
Liked: 0
They do have the one red and one black cables that connect them to the receiver that it came with, so those should work with a new receiver, correct? was looking at the RX-V381BL for ~$179.
rsbuttar is offline
post #6 of 25 Old 02-10-2017, 10:02 AM
gajCA's Avatar
Liked: 2748
Those will definitely work as rears.
How are you setting up the rears?
Mine are on simple shelves at about ear height when standing toed in to the center of the room, (not pointed down), and work great.
My rears don't match my fronts brand wise though they are similar in design.
gajCA is offline
post #7 of 25 Old 02-10-2017, 10:18 AM
Quoted: 1174 Post(s)
Liked: 427
Took a quick look at a review of that htib model and I think it's only the other end (the end that goes into the htib receiver thingy) that is proprietary, right? It said something about little plastic connectors. So long as the speaker itself can accept regular wire, you should be good there.
I'd use a pair (or two pair) as surrounds in a budget setup. I think the included subwoofer is passive though, right? That isn't the best option.
If you re-use the speakers as surrounds, that means you need a new front three and ideally a sub. And yeah, that receiver should work fine for you.
The philharmonics that were already mentioned would fit your budget.
Or a dayton setup w/ subwoofer.
Doe Doe is offline
post #8 of 25 Old 02-10-2017, 11:40 AM
pase22's Avatar
Quoted: 1353 Post(s)
Liked: 1130
That receiver would work just fine. The problem is that you won't be able to use your sub with the Yamaha. You could start by getting the receiver and sub first. You can upgrade you front 3 later since just about any bookshelf speakers you get will need a helping hand from a sub.
This will put you a little over budget but is one of the best deals around right now.
SVS SB12-NSD
https://www.amazon.com/SVS-SB12-NSD-...ords=svs+nsd12
RSL Speedwoofer
https://rslspeakers.com/products/rsl-speedwoofer-10s/
Kef Q100 FL/FR,SL/SR, Kef Q200C, Bic F12 sub, Denon AVR-S710W, , Panasonic 50" Plasma, cable box, Xbox One, Toshiba laptop.
Bedroom: JBL Loft 50 FL/FR , Loft 20 center, JBLSP 150 sub, Pioneer VSX-830K, PS3, 32" Insigna LED.
pase22 is offline
post #9 of 25 Old 02-10-2017, 12:58 PM
Liked: 427
SVS SB12-NSD
RSL Speedwoofer
Instead of a big (or I should say pricey) sub like that, would he be better off just going with something like the three philharmonics + cheap 10" yahama sub (like one of these guys -- http://www.accessories4less.com/make...r-black/1.html). I think it includes a free sub cable too.
Just wondering, as quite often I see these expensive-ish subs recommended to folks even though they need new front speakers. Now a sub will make a big difference, but wouldn't a decent front three + okayish sub be a bigger difference?
Ideally one would go with expensive sub + still nice front speakers, just not sure if that will be in his budget.
Doe Doe is offline
post #10 of 25 Old 02-10-2017, 01:23 PM
gajCA's Avatar
Liked: 2748
Yeah, with his fixed budget he's going to have to forget the sub for now, so the Philharmonic Audios would be the better choice as they play quite a bit lower than the Q Acoustics.
dsrussell and mikeTRON250LM like this.
gajCA is offline
post #11 of 25 Old 02-10-2017, 03:56 PM - Thread Starter
Liked: 0
I know the budget is a concern, it was a rough number that i had thrown out since I would like to purchase all this myself and with school and the car not much is there for stuff like this hehe.
How would those polk's in the main post be to just start up? or even the Monoprice 5.1 system for $179.99?
rsbuttar is offline
post #12 of 25 Old 02-10-2017, 05:10 PM
Liked: 427
I can't speak of the polk towers as I haven't heard them before (although I can say the budget polk bookshelves stink), but I wouldn't lean towards the smaller 5.1 setups from monoprice (or any htib setups).
Reason being, you can use your existing speakers as surrounds just fine (or I assume so, if it has normal wiring). You just need three front speakers. I'd go with the three philharmonics at $335ish over the monoprice setup.
mikeTRON250LM likes this.
Doe Doe is offline
post #13 of 25 Old 02-10-2017, 05:35 PM
steve1106's Avatar
Quoted: 662 Post(s)
Liked: 389
I think I would pay the extra $20 a tower and jump up to the Polk TSX 330T (Amazon https://www.amazon.com/Polk-Audio-TS...s=polk+tsx330t ). The center would run you $118 https://www.amazon.com/Polk-Audio-TS...VWF99VN9YRZ7B8 . Drop down to the $229 Yamaha RX-V379 https://www.amazon.com/Yamaha-RX-V37...amaha+receiver and get the amazon credit card discount of 5% and you are around $530 not counting taxes (if you pay tax in your area).
I have a friend who has the Polk TSi300 https://www.amazon.com/Polk-Audio-TS...ds=polk+towers as fronts with a matching center and they sound great for the cost.
http://www.avsforum.com/forum/15-gen...eap-build.html
Epson HC3700/HC2000; Screen - 151.5" 16:9/TV or 143.5" 2.35:1/HT at a seating distance of 13/14 feet; Yamaha RXV675 for 7.4; Speakers - Infinity Primus; Subs - 3 Polk PSW10s, 1 BIC F12; Headphones - 4 JVC wireless; Sony 3D Blu-ray player/six pairs 3D glasses.
steve1106 is offline
post #14 of 25 Old 02-10-2017, 05:39 PM
Zorba922's Avatar
Quoted: 3838 Post(s)
Liked: 2754
Start with 3 front speakers and a subwoofer. Add the surrounds later, since they do so little of the output anyway...or save up for nicer fronts later ($200/pair range) and move the Daytons to surround duty then.
fronts: Dayton B652, $45/pair from Amazon
center: BIC FH-6LCR, $105 from Amazon or Walmart
Dayton Sub1200, $150 from Amazon or Partsexpress.com
Since you're going to do mostly TV watching, the center speaker is the most important factor. Some reviews of the BIC:
http://www.amazon.com/BIC-America-FH.../dp/B0015A8Y3E
Perhaps the most helpful user review here:
http://www.amazon.com/review/R1DYBWM...cm_cr_rdp_perm
Best of all, you can order one shipped free site to store for pickup. In the (unlikely) case that you don't like it, you'll be able to simply drop them off for an on-the-spot refund. Sot it's really a zero-risk proposition:
http://www.walmart.com/ip/BIC-FH6-LC...eaker/10298559
Get the receiver from accessories4less.com --- a certified refurb that is normally sold for $400 or above can be had for as little as $200. Yamaha is known for the best long term reliability, Denon is popular for their Audyssey auto-calibration tools (YMMV).
unretarded likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #15 of 25 Old 02-10-2017, 05:55 PM
Liked: 427
If he's going the dayton route, wouldn't the dayton airs be the model to go for?
Instead of the dayton/bic/sub setup, wouldn't a set of philharmonics + center still be considered better? Yeah, no sub and so on, but they get reasonably low for bookshelves. I haven't heard the philharmonics so am just relying on user reviews here, but I have heard cheap bookshelves before supposedly better than dayton airs... not sure if I'd love them as my fronts.
I see no reason why he couldn't use his existing speakers as surrounds and I think he already found a decent deal on a yahama avr.
Doe Doe is offline
post #16 of 25 Old 02-10-2017, 07:44 PM
Zorba922's Avatar
Liked: 2754
Strictly due to the OP's stated budget: The Philharmonics LCR would run something like $375 with shipping if memory serves ($225 for L/R, $150 for C with shipping) whereas the Dayton/BIC LCR would be more like $170 or $180 shipped. If he can afford the extra $$ for the Phils and still get the same sub and AVR then by all means why not? The Phils have possibly the most mid-bass of any $200-250/pair speakers but still would get squashed by the Dayton B652s with Sub1200 during HT usage.
The $20-30 price difference between the Dayton AIR vs Dayton B652 is also dependent on the OP's budgetary constraints.
Yes existing speakers could certainly be used as surrounds; I was suggesting a 3.1 setup only with his given budget.
Zorba922 is offline
post #17 of 25 Old 02-11-2017, 01:39 AM
Liked: 427
Hmm.. I forgot about shipping costs, which would put him over his $500 budget. I think I am so used to amazon prime and places like that, I just assume shipping is minimal, like $20 or less.
As for philharmonic vs dayton, I was wondering if philharmonic without sub > dayton with sub. If the philharmonics were a big enough upgrade over the daytons I'd think even without a sub they may be worth it ... but I never heard them. Guess you feel that the sub + dayton would be the better option.
Once you factor in sub + avr, $500 doesn't quite go as far as one would think. I'd suggest the OP look at the used market, but not sure if he'd want to go that route.
Doe Doe is offline
post #18 of 25 Old 02-11-2017, 08:25 AM
Zorba922's Avatar
Liked: 2754
Only for music listening. For HT, there's no substitution for a sub to get more of the LFE during big budget action movies and thrillers, even a cheap sub like the Dayton 1200.
Zorba922 is offline
post #19 of 25 Old 02-11-2017, 09:53 AM
gajCA's Avatar
Liked: 2748
For a super tight budget that simply won't budge I'm not sure you can do any better than this to be honest.
http://www.parts-express.com/b652-ai...oofer--300-697
http://www.soundandvision.com/conten...47xwemuLFCm.97
Sure the frequency response isn't as ruler flat as the Philharmonic Audios but for HT and Audyssey to help with the frequency response not bad at all really.
gajCA is offline
post #20 of 25 Old 02-14-2017, 11:59 PM - Thread Starter
Liked: 0
Hey guys, thank you all for the recommendations. I did look into some and also went to my local best buy to listen to some offerings that they have.
I liked the Klipsch bookshelf's they had, I believe they were the R-15M.
I was thinking of going with a 3.1 set up for now, even if I am a little over budget. But here are the speakers and whatnot that I was looking at.
L/R: Klipsch R-15M
Center: BIC Acoustech PLC-28II or Klipsch RC-52II
Sub: BIC America F12 (have read many great reviews for this as an entry level sub on here) or Dayton Sub1200 (as previously recommended)
I believe it puts me at roughly: $650/700 for the speakers/sub.
How would it be. As of right now I do not have a receiver, but am looking at something similar to the R-V381 (was unable to get it since I went out of town at the time of that promotion)
rsbuttar is offline
post #21 of 25 Old 02-15-2017, 10:54 AM
gajCA's Avatar
Liked: 2748
L/R: Klipsch R-15M
If you like Klipsch/BIC which are similar in design maybe three of these for $360; gives you a total of six 6.5" drivers.
http://www.parts-express.com/bic-for...eaker--303-438
gajCA is offline
post #22 of 25 Old 02-15-2017, 12:01 PM
Zorba922's Avatar
Liked: 2754
OP, these are also available from Walmart online which would give you maximum ease of return in case you don't like them, by dropping off in-store:
https://www.walmart.com/ip/BIC-FH6-L...eaker/10298559
(They go in and out of stock every couple weeks.)
Personally I'd just get one of the FH6 for your center, and with the $100 savings you can move up from the BIC F12 to the BIC PL200 subwoofer.
Zorba922 is offline
post #23 of 25 Old 02-15-2017, 12:28 PM
gajCA's Avatar
Liked: 2748
The Klipsch he wants have only one 5.25" driver vs two 6.5" drivers for the cheaper BIC LCR which can be used for a center and the left and right.
I'm going to guess the BICs aren't as bright/potentially shrieky as the BICs based on what you and others have said about them.
gajCA is offline
post #24 of 25 Old 02-15-2017, 03:22 PM
Zorba922's Avatar
Liked: 2754
I don't think the difference in driver size really matters though...I've run that BIC with my Wharfedales, the QA 3020 and C20, and the EMPTek R5Bi all of which have single 5.25" drivers, without any problems.
Yes the BICs have a bit of a roll-off at the top...not enough to be called "warm" by any means, but certainly enough to avoid the excessive treble that lower level Klipsch has long been accused of. However, as L/R mains the FH6 seems to be a mixed bag, with some people liking it and some saying that they sound a bit "thin" due to the sealed cabinet design which probably extends no further than 80-90Hz (their claimed 40Hz spec is a joke).
gajCA and unretarded like this.
Zorba922 is offline
post #25 of 25 Old 02-16-2017, 10:15 PM - Thread Starter
Liked: 0
Hmm, the FH6-LCR seems similar enough to flow well according to reviews I've read on it.
Also the subs, is the PL200 that much better for it? I was reading that its better for more open spaces as well so may lean towards that for the sub as well, but on the fence a bit too since the master bedroom has a wall connecting to the family room as well.
rsbuttar is offline
Reply Speakers
