Frequency Response - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By TuteTibiImperes
post #1 of 4 Old 02-11-2017, 10:23 PM - Thread Starter
Liked: 0
Question Frequency Response
If a speakers "Frequency Response" is 85-5000 hz does that mean that the speaker blocks out the frequencies over and under that? Or do i need to set a high and lowpass filter around those frequencies? Thank you for any help.
Jake Adams 2 is offline
post #2 of 4 Old 02-12-2017, 12:55 AM
Quoted: 1225 Post(s)
Liked: 882
The frequency response of a full completed speaker is what it can reproduce, and is usually quoted with a +/- decibel rating, such as 55hz-20khz +/- 3db, meaning that within that range it won't deviate more than 3db in either direction. You don't have to use a filter if you want to run the speaker full range, but if you're adding a subwoofer for the low-end you'll likely want to have a high-pass for the speaker and a low-pass for the sub to properly blend them and relieve the speaker of reproducing the deep bass frequencies that the sub will carry.
The spec you listed however sounds more like it's for a driver than a finished speaker, I'm not aware of any speakers meant for home use that have such a limited range. If you're talking about a speaker driver that you're going to be using in building a finished speaker you'd need to have some sort of crossover at least at the top end to roll it off before cone breakup occurs, and another crossover at the low-end if you're going to integrate another driver to handle lower frequencies in your design.
dsrussell likes this.
TuteTibiImperes is online now
post #3 of 4 Old 02-12-2017, 05:15 AM
Bill Shenefelt's Avatar
Quoted: 86 Post(s)
Liked: 39
If it is in an enclosure it is probably a small tv or computer speaker meant for minimal sound volume or fidelity. Fine for the voice end of a sound system but not very good. About telephone sound quality..If it is a bare speaker it is a midrange and would require a higher frequency and a lower frequency speaker to produce any kind of fidelity.
Bill Shenefelt
http://sheneskillies.com
william.shenefelt@verizon.net
Bill Shenefelt is online now
post #4 of 4 Old 02-12-2017, 10:30 AM
bluewizard's Avatar
Quoted: 1888 Post(s)
Liked: 1173
You said Speakers, but did you mean Speaker or did you mean Driver, as in a Bass Driver or a Midrange Driver?
And what other drivers are in the system?
How is the speaker being used? Stereo? Part of a Multi-Driver Speaker System? PA? Musical Instrument?
If that is a guitar speakers that is abut right. If that is a Bass Driver for a Stereo Speaker, it must be relatively small.
The application matters. If this is a single driver stand alone speaker, then it can be used as is. If this is one driver of a multi-driver speakers, then you need some type of Crossover or filter.
You simply haven't given us enough information for us to make a determination.
Also, speaker ratings and crossovers are not Brick-Walls. At the rated frequencies, the drivers starts to fade out. They roll-off, they don't just end.
Steve/bluewizard
bluewizard is offline
Reply Speakers
car audio , frequency response , speakers , stereo
