In another thread I mentioned how my subwoofer can get boomy at times, and sealing the ports was suggested... but unsure what is the best material to use for this.
I found some thick foam (used for blocking drafts under doors) in my spare room, but it probably won't be an exact fit for the ports. Is that good enough?
Or would thinner foam be better? I may have some shipping foam around here somewhere ... sort of thin though.
Is the idea to block the port completely or just semi-block it a little bit? And is there a chance of the subwoofer breaking by sealing the ports?
