Advice Needed: SVS Package vs KEF LS50 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 34 Old 03-05-2017, 06:37 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Hi, all. I'm finishing a basement and plan to set up a 5.1.2 system. Mostly for HT and a bit for non-critical music listening. The room is large but towers are out of the question (WAF).
So, I'm deciding between two potential setups:
1) SVS Ultra L/C/R with prime satellites and tbd ceiling for atmos
2) KEF LS50 L/R w q600 center. Surrounds could be q100s or the KEF on wall t101 (which I haven't heard and can't find in store). Same ceilings
The KEF system is a little more expensive but the price drop on LS50s has made it very close.
I'd like to hear from folks who run the LS50s for HT use. Thanks
ironmikey12 is offline
post #2 of 34 Old 03-05-2017, 06:42 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Also, bonus points if you can recommend a sub $700 receiver that can do 5.1.4!
post #3 of 34 Old 03-05-2017, 06:52 AM
Squirrel!'s Avatar
Quoted: 532 Post(s)
Liked: 290
Act fast:
http://www.accessories4less.com/make...eceiver/1.html
Main: Mitsubishi 73736 DLP|OTA|fireTV|Sony BDP-S1100|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 - DIY Class G 540w 12" Subs|2 Aura Bass Shakers|APC H15|Harmony 720|TP-Link Archer C7|Linksys SE2500|50+ OTA Channels
MBR: Vizio VF550M|OTA|fireTVstick 2|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Belkin Bridge|Harmony 550
Squirrel! is offline
post #4 of 34 Old 03-05-2017, 07:09 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thx. But isn't this still 7-channel (so only able to do the one atmos pair)?
post #5 of 34 Old 03-05-2017, 09:13 AM
Quoted: 177 Post(s)
Liked: 68
I've never heard the SVS, but I am a dealer of both KEF and Monitor Audio. For what you're describing I would actually look at the Monitor Audio Silver 1 http://www.monitoraudiousa.com/products/silver/silver-1 or the larger Silver 2 http://www.monitoraudiousa.com/products/silver/silver-2
Even the 8" Silver 2 is alittle lower cost than the LS50 and I think that, for mainly HT use, that would be a better speaker. Just something to consider.
PrestigeAudio is offline
post #6 of 34 Old 03-05-2017, 09:22 AM
Zorba922's Avatar
Quoted: 2452 Post(s)
Liked: 1728
I loved the LS50s for music. I would never use them for HT, even if they cost $500 a pair instead of $1500 a pair.
If the majority of your usage is HT, with just a little critical music listening, you do NOT need to spend SVS Ultra or LS50 money to get it.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #7 of 34 Old 03-05-2017, 11:00 AM
Quoted: 177 Post(s)
Liked: 68
So, to make sure I understand you correctly, in your opinion, the be all end all price point for premium, top shelf, it can get no better performance home theater speakers are $500 or less per pair? Regardless of room? And that just because a speaker is great for music it wouldn't be great for home theater use?
I'm trying to understand what you're saying here. The LS50 at $500 per pair ($250 each) would be a BAD speaker for movies? Compared to what other $250 speaker?
I would love to hear a more detailed explanation of your above post as it relates to the OP looking for high quality audio components.
post #8 of 34 Old 03-05-2017, 11:16 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
I'm curious as well. So, price being equal ($500/pair) would you choose svs prime over the ultra or ls50? If so, why?
post #9 of 34 Old 03-05-2017, 11:17 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thanks. No dealers close by... hmmm. They're incredible looking
post #10 of 34 Old 03-05-2017, 11:49 AM
Quoted: 177 Post(s)
Liked: 68
Even though I've enver heard them, I think that the SVS Ultra LCR would be the better speaker suited for a large room HT. They'll just move more air cleaner than the LS50, which is more of a finesse speaker in that regard with it's single 5 1/4" woofer.
I still like the Monitor Silver 2 with the 8" woofer and matching Silver Center.
Center: http://www.monitoraudiousa.com/produ.../silver-centre
Main L/R: http://www.monitoraudiousa.com/products/silver/silver-2
It just so happens that Monitor's 3 way in-ceiling CT256-IDC is one of the absolute finest ATMOS speakers for in-ceiling as well. This matches the Silver series sonically quite well and isn't ultra expensive. It's not cheap, but not nuts money, either: http://www.monitoraudiousa.com/produ...-200/ct265-idc
post #11 of 34 Old 03-05-2017, 12:16 PM
Zorba922's Avatar
Liked: 1728
I would take the $500/pair Ascend 340 over the LS50s for HT, any day of the week. The 340s have more detail, dynamics, a bigger soundstage, and higher sensitivity. I think most people would feel the same in a side by side comparison for HT.
Hell, I would take the $225/pair EMPTek R5Bi over the LS50 for HT when crossed over to a competent sub. The detail difference is not as obvious as with the Ascends vs LS50, but the much bigger soundstage would be, and I can think of any number of ways I'd rather spend the $1300 price difference.
For MUSIC, my personal preference would be for the LS50. For others, this is much more variable. Some people like neutral to bright sound signatures for both music and movies; for them, the "if a speaker is good for HT it will be good for music" cliche does apply. Not for those of us who prefer a warmer sound for music.
The SVS Ultras I haven't heard myself, but for HT I doubt the performance difference comes anywhere near the 100% price jump...maybe 10-20% tops and probably more noticeable during music listening than general HT.
Zorba922 is offline
post #12 of 34 Old 03-05-2017, 12:23 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thanks. The mini tower is probably a non-starter for the wife. Maybe I'll roll with the SVS primes which can be had for $199/ea in the outlet (at times).
post #13 of 34 Old 03-05-2017, 03:57 PM
Zorba922's Avatar
Liked: 1728
I've auditioned the SVS Prime bookshelves, they'll be ok for HT as long as the movie your watching doesn't have any music with horns or female vocals because they have odd treble peaks that are Klipsch-level screeching. Otherwise they're pretty dynamic and detailed.
The Ascend equivalent to the SVS Primes would be the CBM-170SE which is actually $350/pair new, and it's a much more neutral, accurate and well-behaved speaker. Its main challenge is WAF, because it does have a very peculiar square boxy shape that takes some getting used to (personally I like odd shaped things, like the now-discontinued Honda Element and Scion xB or Nissan Cube, but some people have strong reactions to them).
Better speakers that actually cost even less and have very high WAF would be the $250/pair Q-Acoustics 3020 and the $225/pair EMPTek R5Bi (those prices are for A-stock and include shipping). The QAs even have a white color option (albeit they charge you more for it), which would be the ultimate wife-pleaser, lol. As you might've guessed, I'm married too.
Zorba922 is offline
post #14 of 34 Old 03-06-2017, 06:25 AM
head_unit's Avatar
Quoted: 208 Post(s)
Liked: 121
...I'm finishing a basement...towers are out of the question (WAF).
So if you get the SVS or KEF, are you mounting them on the wall? Because I doubt your wife would look much more favorably on stand-mounted small speakers.
What she really wants is in-wall/in-ceiling. Depending what you mean by "finishing" that might be doable very well, or impossible-are you building walls?
I was quite surprised, on hearing the KEFs at a local dealer, to not like them so much. Oh, they were good speakers and all, but they didn't sing to me particularly. So in the end, with no dealers, be sure to be from somewhere returnable. That might argue in favor of getting the SVS, and if you don't like, see if someone sells the KEFs like that. Meanwhile Sound And Vision April 2017 just gave a super positive review to the RSL CG3 5.1 system, whose satellites are very compact and therefore maybe even more amenable to your wife.
It's also possible your wife *might* accept some really nice looking slim towers like an RBH Sound R55TiB or such.
head_unit is offline
post #15 of 34 Old 03-06-2017, 08:10 AM
Quoted: 177 Post(s)
Liked: 68
This happens to me when manufacturers send me stuff all the time. I've NEVER heard a Paradigm speaker I've liked and I have tried a ton. The B&W 600 series, to me, is gross. Others love them. That's part of the fun of the A/V hobby!
post #16 of 34 Old 03-06-2017, 08:45 AM
Squirrel!'s Avatar
Quoted: 532 Post(s)
Liked: 290
If I'm not mistaken, this receiver will do 5.2.4 or 7.2.2...you will need an amp for the last 2 channels and luckily for you, you have one already!
post #17 of 34 Old 03-06-2017, 12:35 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thanks - I'll check all of those out. I agree re Prime highs. I was a little annoyed by them when listening to the towers at a local store. Can't imagine that would improve as I listened over the course of a movie...
They will go on a pretty large built-in media center we're doing. So, basically, a true bookshelf. But because we are doing built-ins, we can't have towers in front (or stands).
It will -- you're correct. But I don't have an amp .
post #18 of 34 Old 03-06-2017, 03:52 PM
Squirrel!'s Avatar
Quoted: 532 Post(s)
Liked: 290
Ahhh...I thought you had an existing amp you were replacing. My bad.
eBay or Amazon for a cheap 2 shannel. Doesn't need to be fancy since it is just the Atmos part and it isn't like it is the front mains.
post #19 of 34 Old 03-06-2017, 04:36 PM
Zorba922's Avatar
Liked: 1728
Maybe give the EMPTek R5Bi a try then, they are rear ported but unlike other rear-porteds, have no problem with as little as 2-3 inches of rear clearance since they produce so little mid-bass to begin with...when blended with a good sub they blossom nicely though, amazing soundstage. Also, your wife will be quite pleased with the curved sides, shallow depth, and glossy finish!
Zorba922 is offline
post #20 of 34 Old 03-07-2017, 08:17 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thanks again - I'll give them a look
Zorba922 likes this.
post #21 of 34 Old 03-07-2017, 12:30 PM
Kini62's Avatar
Quoted: 1501 Post(s)
Liked: 1362
Extra brightness is a positive for HT use (IMO of course). So if the main or only use is HT give the Primes a shot in your own home. They might sound quite different.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #22 of 34 Old 03-07-2017, 02:16 PM
Elihawk's Avatar
Quoted: 1079 Post(s)
Liked: 907
I have a slightly different slant on the music versus HT thought that Zorba proposed. I like as accurate and neutral of a speaker as possible for either...however, I have found that higher end speakers real shine for critical music, but sometimes that extra expense gets lost in the Umph of HT.
My own example...my EMPtek speakers are really good for HT, especially if you consider what I spent on them and compare to what i spent on my Phil- BMR speaker (this speaker pair cost me more that the 5 EMPs). For critical music listening, I prefer the Phil-BMR every day of the week and 4 times on the weekend. However, when I moved the Phil-BMRs to my theater for a quick trial, the difference in SQ wasn't as noticable. I think clarity and detail can get lost, or more accurate, overrun when listening to most modern HT soundtracks.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #23 of 34 Old 03-14-2017, 03:28 AM
Ben Tan's Avatar
Quoted: 266 Post(s)
Liked: 210
A week old thread, but I'll add something since I do currently own the SVS Ultra bookshelfs and had owned the KEF LS50s for a good 4 months. I've also done a lot of A/B testing between them in my own room, at my own space, on the volume I like.
I don't want this post to be super long so I'll try and keep it short;
Movies
I'll be extremely frank here, the tonality between the Ultra and LS50 are actually pretty damn close. Until the point where I could use one PEQ curve between them and they wouldn't sound too obviously different. It's only noticeable on some content and if I focus on the differences. Since movies are mated with a sub(s), I have my subs blend very seamlessly with either pair where it's difficult to tell the difference between Ultra and LS50 on the low-end, hell I think it's damn near impossible.
The Ultra does have a slight bit more forward presentation on the mids, I use the Ultra Center as my center for multi-channel movies so it applies generally to the bookshelf also. But on stereo content, the mids on the Ultras a little more in my face than the LS50. Neither is bad, it's just a preference thing. I personally like the Ultras more in this regard.
Tweeter wise, not much to split between them to be honest. On paper and technically speaking, the Ultras would sound brighter and more forward. But I found it wasn't the case in my room at least. The LS50 may or may not have more detail, but that's something movie content cannot really show. I'll get back to this with music...
Music
This is the only genre where I can differentiate them noticeably and even then, it's not very significant. In a 2.0 music only setup, the Ultras low-end is the definite winner in my books. It just hits harder, quicker, more accurate and it's just so, sooo clean. The LS50 lacks in this space and often times, I can hear a feint but noticeable reverb between the lowest octaves of a male voice and the mid-bass.
The tweeter, welp the KEF wins in this area. I'm fine with the Ultra's tweeter for movies, but on music... they too can sound a little too bright and yes I know what the hell bright is considering the Prime bookshelfs were my main drivers before either of these. There can be cases of sibilance on the Ultras that you know can only be remedied with a DSP to a certain extent.
The LS50 has a very detailed, smooth top end yet it doesn't lack that expressive energy that is an absolutely must have criteria in my book. I hate plain, dull tweeters that for the sake of not sounding harsh, becomes overly veiled.
Bonus: Games
Now I play A LOT of games. And games these days has gotten increasingly complex in how dynamic they can sound on the fly. Unlike a movie or a song, many parts of a game's aural experience derives proceduraly on the fly.
Both the Ultras and LS50 does fantastically well in games. The most important area to a game (audio wise) is accuracy of sound directionality. If I were to play a game in plain stereo, the LS50 would win every time in terms of the soundstage. I mentioned it earlier, its top end is just beautifully detailed and that translates into a very wide and deep gaping soundstage that effects are coming from areas from my wall and not just the screen. As an example, it's eerie to hear a train coming from the far left side of my wall and it hasn't even arrived on my screen yet.
That said, the Ultras aren't too far back either. They do have a wide soundstage as well, but it lacks some depth and instead has more width. But at the same time, the bass on the Ultras are just so forceful and fun to listen to that it makes the LS50 feel meek in comparison. I love how the Ultras always punch me in the gut, while the LS50s are more... "eh, here's some bass, I'll massage you with it."
The tldr though; I love both pair of speakers. I sold the LS50s because the Ultras to my ears are the best all-rounder (which was what I'm looking for) while the KEF LS50 is a little more focused on certain genres.
Hope that helps you out, even if it's a week old thread.
PS: One other thing, if you can get 3x LS50s and make them your LCR instead of mating the center channel to a Q600 (I loathe the Q series btw), that would be preferable instead. You can use the Q series speakers for surround if you want. But if you're set on getting a pair of LS50s, try getting a single LS50 for center. I'm sure you'll have jaw drop syndrome from the seamless blending on the front stage of your audio setup.
P/S 2: Yes. you can put the LS50 horizontally and there wouldn't be any dispersion issue (which is what I did). I know some crazy LS50 lovers actually bought 7 x LS50s just to have a seamless 7.1 setup.
Bedroom Theater
Sony KDL55-W900a | Yamaha RX-A2050 | Emotiva XPA-3 Gen 2
SVS Ultra Bookshelf L/R | SVS Ultra Center | Dual SVS SB2000
SVS Prime Bookshelf SL + SR| SVS Prime Elevations Height Presence L/R/RL/RR
Ben Tan is online now
post #24 of 34 Old 03-14-2017, 07:34 AM
Zorba922's Avatar
Liked: 1728
Whoa, from reading other people's feedback who also owned both SVS series, I thought that the Ultras use a different tweeter than the Primes, and do not suffer from brightness at all?
I auditioned the Prime bookshelves and found them downright unlistenable for certain types of music (jazz horns and female vocals), but was told the Ultras had fixed those weird treble peaks.
Zorba922 is offline
post #25 of 34 Old 03-14-2017, 08:02 AM
ProblemHouston's Avatar
Quoted: 13 Post(s)
Would someone please tell me where I can get a pair of LS50's for $500?
I never argue with fools cause from a distance you canÂt tell who is who....
ProblemHouston is offline
post #26 of 34 Old 03-14-2017, 09:47 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Movies
Music
Bonus: Games
Thanks a million. VERY helpful.
post #27 of 34 Old 03-14-2017, 11:53 PM
Ben Tan's Avatar
Quoted: 266 Post(s)
Liked: 210
The Ultras came out before the Prime. So if anything, the Ultra's tweeters were the "best" version of the aluminium dome SVS uses. The Prime's tweeter is identical on the outside, downright to the diffuser. But the internal components are different.
Going from the Primes to the Ultra, with no DSP or PEQ applied - the difference in the tweeter is instantly noticeable. At first I thought the Ultras were perfect, side by side to the Primes. But upon months of listening to more content, I found some content - particularly Jazz to still present a slight sibilance to the overall sound. It's by no means as fatiguing as the Primes, but I can still hear it. Thankfully, it's slight enough that some bit of EQing the top-end (5khz to 8khz) tames it out almost entirely.
I'm sure you remember how the Primes would also be obnoxiously fatiguing for female vocals right? I found that there's cone break up at around the 2-3khz area and that's the main issue causing the fatiguing female vocals to stand out like a sore thumb, at least that's what it sounds like to me. The Ultras do not suffer from this area so I found that voices for all kinds of content (even the 90s stereo TV shows like Friends) would sound pleasant to listen to.
Bedroom Theater
post #28 of 34 Old 03-15-2017, 09:15 AM
Zorba922's Avatar
Liked: 1728
Never knew that...but it explains everything! SVS wouldn't want to undercut the Ultras by offering a speaker that performed equal or close to the Ultras yet sold for half the price. Makes perfect sense now.
I wonder how the Ultras compare to speakers in the $700-800/pair range, like the Ascend Sierra 1, Focal Aria 905, etc.
Zorba922 is offline
post #29 of 34 Old 03-15-2017, 01:35 PM
Kini62's Avatar
Liked: 1362
Seems you have found your next "project".
Def Tech SC8000
Kini62 is offline
post #30 of 34 Old 03-16-2017, 02:21 AM
Ben Tan's Avatar
Quoted: 266 Post(s)
Liked: 210
Well FWIW, SVS did advertise the Primes to be "closer than we'd like to admit" to the Ultras. It's a blunder on their part, they're not close at all. But at the same time, the Primes certainly don't sound twice worse either.
I remember months ago I told you I was going to get an Ascend Sierra (either 1 or 2) for demo. Unfortunately that plan didn't turn out too well, since I don't live in the US. Shipping and import tax was a problem, where the Sierra 1 would end up costing more than the SVS Ultra in the end.
Maybe you can do an audition?
Bedroom Theater
Reply Speakers
