Front Soundstage Choices - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Zorba922
Old 04-19-2017, 03:04 PM - Thread Starter
Quoted: 64 Post(s)
Klipsch R-2502-W II or Def Tech DT8LCR?
The room is rather large 16x20. In-wall is the only option I have. There will be a built in cabinet on the left side of the left speaker and another built in on the right side of the speaker (I know, not ideal). The room will be used as a family room, no dedicated theater here. Just looking for 'quality' sound.
What're you thinking? Thank you.
Denon AVR-X3300W (5.1.2) | Proficient Audio AW525 (L&R) | Proficient Audio CC550 | Proficient Audio GS10 (LFE) | Yamaha NS-IC400 (Surrounds) | Harmony Elite | Apple TV (4th Gen) | Denon BDP-1611UD | Sony BDP-S580 | Xbox One | Vizio M50-D1"
MasterAudio is online now
Old 04-19-2017, 03:48 PM
commsysman's Avatar
Quoted: 1057 Post(s)
Liked: 554
I suggest that you look at the PSB line of in-wall speakers, which IMO are much better-sounding than the above.
The W-LCR speaker is especially good. Crutchfield carries them.
Since you are looking for quality sound, you should get speakers that are fully enclosed in their own enclosure; this is the only way to avoid poor performance.
Since you are building them in, it would be a big mistake to cheap out.
commsysman is offline
Old 04-19-2017, 04:41 PM - Thread Starter
Quoted: 64 Post(s)
I wish I had the budget to look into PSB. I'm more looking for a a speaker that won't disappoint in regards to the room size and will be of some quality for TV, sports, music and the occasional movie.
Old 04-19-2017, 10:12 PM
Zorba922's Avatar
Quoted: 2616 Post(s)
Liked: 1829
This would be my recommendation:
a) Hsu in-wall speakers, $330/pair shipped
http://www.hsuresearch.com/products/hiw-1.html
The HIW-1 is simply the in-wall version of Hsu's well reviewed HB-1:
http://www.hsuresearch.com/products/hb-1.html
If at all possible, I'd try to go with a physical center that can be placed so that the tweeter is at ear level of your main listening position since the center does 70-80% of HT output, i.e. it's worth the trouble!
b) Hsu center speaker, $280 shipped
http://www.hsuresearch.com/products/hc-1.html
gajCA likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is online now
Old Yesterday, 12:20 PM - Thread Starter
Quoted: 64 Post(s)
Thank you! It seems a lot of people like these in their setups. Do you think 6½" woofers all around will be sufficient for the room? I'm gonna pair them with SVS's SB-1000.
Old Yesterday, 02:01 PM
gajCA's Avatar
Quoted: 2656 Post(s)
Liked: 1621
6.5" woofers should be ideal.
Are you set on the SB1000?
If you want a sealed sub from SVS this one is more powerful and cheaper.
https://www.amazon.com/SVS-SB12-NSD-.../dp/B009F8Y7SO
Geoff A. J., California
gajCA is online now
Old Today, 10:11 AM
Zorba922's Avatar
Liked: 1829
Absolutely, yes...it's the horn tweeter that will have the most room-filling effect.
I would recommend NOT using any sealed subwoofer in a room of that size, unless you are planning on nearfield placement.
I would go with a PB1000 or Hsu VTF-2 at minimum, though a VTF-3 would IMO be well worth the extra money.
