Hi everyone! Looking for some advice here.
I recently moved and now I have to downsize my beloved speaker system to fit into a super small room. The room size is 7.5' x 11.25' and is 9.5' tall. It has plaster walls.
My current setup is a Rotel RSX-1550. It's a 3 speaker setup (w CM-7s and a CM-Center). In recent years, I've been mostly using them for watching movies and really like how natural the sound is (no hugely booming bass, crisp mid range making voices easy to hear, and good fidelity at the high end). Alas, the three speakers are way oversized for the new space.
I'm thinking of replacing them with 3 smaller speakers mounted on the walls high up, and a subwoofer.
Any suggestions on what brands or models to look at?
Ideally we would want the sub to be one of the thinner vertical types...but my experience is that those tend to lose too much fidelity to work out. However, I'd love to be told otherwise!
Thanks in advance!
Thanks in advance!
