Setup for JAZZ/BLUES (turntable) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-19-2017, 11:14 AM - Thread Starter
Liked: 0
Arrow Setup for JAZZ/BLUES (turntable)
Hi all – I am new to the forum, and would appreciate your help!
I’m looking for a simple set up for listening to jazz/blues through my turntable (RCA) in a mid-sized living room (16x8 feet; 5x2.5 meters). I do not plan to use for other types of music or with other sources. I’ve been looking at the audioengines A5+ which I like for their simplicity and positive reviews, but it seems some people believe they are too boomy or insufficient for use in a living room. I would rather have quality and soundstage rather than volume, if possible.
My budget is $500.
Thanks so much for your time!
jolulure is offline
post #2 of 9 Old 06-19-2017, 12:13 PM
zieglj01's Avatar
Quoted: 1708 Post(s)
Liked: 1624
Look at Emotiva Airmotiv-5s
https://emotiva.com/products/powered...rs/airmotiv-5s
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #3 of 9 Old 06-19-2017, 12:32 PM - Thread Starter
Liked: 0
Thanks for your reply zieglj01!
I guess that, unlike the Audioengines, these will require use of a DAC or an amp? Sorry if this is a silly question, I am totally new to this world!
J
jolulure is offline
post #4 of 9 Old 06-19-2017, 01:05 PM
Kini62's Avatar
Quoted: 1740 Post(s)
Liked: 1554
My budget is $500.
Over your budget, but has phono pre-amp built in, no need for a DAC or any amp. Might be worth it. They get great user reviews.
https://www.crutchfield.com/p_714SIX...sixes&skipvs=T
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 9 Old 06-19-2017, 01:21 PM - Thread Starter
Liked: 0
Thanks! Correct, my turntable has phono pre-amp. What about the ADAM AUDIO F5? they seem to be in the same price range. Would you recommend the Emotiva over the Adam? Also, would it be worth getting an external amp to bypass the phono pre-amp of my turntable? (Sony PSLX300)
Thanks again.
jolulure is offline
post #6 of 9 Old 06-19-2017, 01:39 PM
zieglj01's Avatar
Liked: 1624
The self powered Airmotive will not need an amp -- however, you will need a DAC
Now you can go passive and buy an Amp with a built in DAC
Airmotiv B1
https://emotiva.com/products/speakers/airmotiv-b1
Amp/receiver - with built in DAC
Yamaha
http://www.accessories4less.com/make...eceiver/1.html
Onkyo
https://www.amazon.com/Onkyo-TX8020-.../dp/B00EE18O7W
Who AM I
post #7 of 9 Old 06-19-2017, 02:47 PM
gajCA's Avatar
Quoted: 4297 Post(s)
Liked: 2748
J
A turntable does not need a DAC, (Digital to Analog Converter), as it outputs an analog signal.
But if you want some very nice powered speakers with a DAC for a digital source that has no internal DAC, (can't think of one other than a BluRay player to be honest), here's another option.
https://www.qacoustics.com/bookshelf...-speakers.html
Even has a subwoofer output so you could add a nice $199 sub like the Emotiva BasX S8.
Speakers
Bass unit: 100mm
Treble unit: 25mm
Connection options
Bluetooth V4.0 including aptX
Analogue 3.5 mm stereo jack socket
Analogue RCA phono sockets
Digital optical (Toslink)
Subwoofer output (RCA)
Speaker terminals
Geoff A. J., California
gajCA is offline
post #8 of 9 Old 06-19-2017, 04:01 PM
zieglj01's Avatar
Liked: 1624
Emotiva or Adam is up to you -- Info about turntables and needs for different set-ups is here
https://www.turntablelab.com/pages/b...-to-turntables
Who AM I
post #9 of 9 Old 06-19-2017, 05:09 PM
Leon O's Avatar
Quoted: 139 Post(s)
Liked: 137
I can't speak to the active (powered) emotive airmotiv speakers, but the B1 (passive) speakers combined with the emotiva BasX S8 sub are an outstanding combination for jazz/blues. The combination resulted in great imaging, separation and detail for me.
Leon O is online now
Reply Speakers
