Hello
I am completely lost in speakers world(and I am in Europe). I have Denon X1300W AVR and want to watch movies and do some gaming, I am not a big fan of loud sounds, yet if it helps me to immerse into game or movie it can be a plus. My room size is 18lenghtx13.1widthx11height (in ft). I am on very tight budget - I am willing to pay up to $500 (will pay more, I just cant imagine I can get real thing below $500 in us, so its probably 500-600euros in EU) for speakers (maybe I should buy 5.1 speakers and later upgrade my set? is it possible to go that route when you have 7.2 receiver?)
My room has 2 windows, but the light and the space of the window sills will be isolated with something that will block the daylight, so it shouldnt be a problem for sound. However my room is fully painted in white and I am not planning to carpet it as it is also my bedroom. I can do any kind of construction works (however if I could hang or attach by any other means the front speakers to sides of my screen that would be great, as well as attaching the back speakers as well, i can drill holes in the walls to put the speakers inside walls if that is economical since I am renovating my room).
Also I am interested whether it is optimal to put rear speakers in the back of the room while I am seating at distance of 2/3 or 3/4 of the room.
Regards
Regards
