Looking for speaker stand suggestions for Polk LSIM 703 bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By rr14
  • 1 Post By gajCA
  • 1 Post By Bill Shenefelt
post #1 of 3 Old 08-12-2017, 08:35 PM - Thread Starter
rr14's Avatar
Quoted: 46 Post(s)
Hi everyone. I'm trying to setup my surround speakers, polk lsim 703's. They are a decent sized bookshelf. They are pretty deep, approximately 8" wide by 14" deep. Probably around 30lbs or so. I'm ideally looking for something that is right around 2 feet tall with a solid sized base.
I have check parts express and the net for a bit but most of what I'm seeing is setup for smaller footprint speakers. Any suggestions on other places to look for pre-made ones? Worst come to worst, I guess I will diy them since I have a bit of experience with that. I'm only okay at that, so it would be preferable if I could find something professionally done to keep the wife happy with the looks.
carlthess40 likes this.
rr14 is offline
post #2 of 3 Old 08-13-2017, 09:23 AM
gajCA's Avatar
Quoted: 3755 Post(s)
Liked: 2385
Pay no attention to the "sale ends tonight" nonsense, they change the date daily.
http://www.gwizpro.com/stands/
Another option is to buy a ready made speaker like Sanus and simply make a new top plate out of MDF from Home Depot and paint it to match the rest of the stand.
Home Depot will cut to size if you want.
http://www.homedepot.com/p/1-2-in-2-...8107/205881911
http://www.homedepot.com/p/1-4-in-x-...8102/205881910
Madmax67 likes this.
Geoff A. J., California
gajCA is offline
post #3 of 3 Old 08-13-2017, 12:11 PM
Bill Shenefelt's Avatar
Quoted: 86 Post(s)
Liked: 39
If you want nice, try making what you need out of MDF or plywood and get some veneer from Homecraft Veneer in Latrobe, Pa. (https://www.homecraftveneer.com/ ) Has real nice stuff even in ready to cut in 2x8 and 4x8 sheets in quite a few woods. Has glue already on it with a peel off backing and cuts with good shears. Real easy to work with.
Bill Shenefelt
http://sheneskillies.com
william.shenefelt@verizon.net
Bill Shenefelt is offline
Reply Speakers
