Help for my new HT setup - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By sigpig
  • 1 Post By pinopradino
post #1 of 15 Old 08-22-2017, 01:06 PM - Thread Starter
Liked: 1
Hi guys, I need your help about my new HT setup I'm going to compose.
I'm renovating my new home, and in a room (of about 387.5ft² and high about 15ft) I'm going to build an iron mezzanine (with parquet on the floor) like in the attached picture. The mezzanine is 14.7ft x 9.85ft, and is about 7ft high from ceiling to floor. I just have two speakers, a pair of Klipsch Cornwall III (with a McIntosh MA2275 and CD, tuner, ald tunetable). I would use that speakers for the front too (using my stereo system when i want simply listen music), buying a sinto amplifier (a Yamaha RX-A3070 or a Denon avr-x6300h). Well, like in the picture, the distance between TV and couch will be about 5.7ft, and I would setup a 5.1 system. I was thinking, for the rear front, to buy a pair of Klipsch Heresy, a klipsch RP-450C for the centre and a klipsch R115SW like subwoofer. This is my idea, but I'm scared about to have too much power to manage for the little space I've for the system. What do you think about?
pinopradino is offline
post #2 of 15 Old 08-22-2017, 03:02 PM
gajCA's Avatar
Quoted: 4182 Post(s)
Liked: 2671
I'd just use the Cornwalls for left and right, an RP250c for the center and a pair of RP150m for the rears mounted about 2 feet higher than your ears when sitting on flat shelves pointed at the TV.
That is how my rears are in my system and it sounds great.
The 450c and addition of Heresy speakers would be overkill.
Even the smaller Klipsch Reference R-112SW sub would be fine...though in the US there are choices that are better for a small space for less money.
I'm assuming you are not in the US?
Geoff A. J., California
gajCA is online now
post #3 of 15 Old 08-22-2017, 03:37 PM - Thread Starter
Liked: 1
You're right, I'm from Italy.
Do you have no sun in your system? And just to know, which don't I amplifier are you using?
So, thanks for your tips, I'm going to read more about speakers you told me.
post #4 of 15 Old 08-22-2017, 04:06 PM
Quoted: 543 Post(s)
Liked: 428
Why not get a third Heresy for your centre?
Class A likes this.
sigpig is offline
post #5 of 15 Old 08-22-2017, 11:59 PM - Thread Starter
Liked: 1
I still not have heresy speakers, so I should buy 3 speakers. Anyway, I would not know where to put an heresy like a central speaker, as you can see in the attached image in the first post..
post #6 of 15 Old 08-23-2017, 10:55 AM
gajCA's Avatar
Liked: 2671
I have an older Denon, the AVR 1912 powering my front three which are Usher speakers and the rear two which are B&W speakers.
I have a Velodyne DD15 subwoofer.
I would think that Heresy's would be too much speaker for your room to be honest.
If you like the Klipsch sound the RP series would seem more appropriate for your room and leave you more money for the Reference 115sw subwoofer.
The Italian brand Sonus Faber is also well worth a look for speakers; perhaps they are cheaper in Italy than here.
gajCA is online now
post #7 of 15 Old 08-23-2017, 01:56 PM - Thread Starter
Liked: 1
I well know Sonus Faber, great speakers, but I love Klispch sound (expecially heritage line), so I believe I'll go for RP line. For the subwoofer, 112 or 115? 115 maybe too powerful for the system I have, despite my love for bass!
post #8 of 15 Old 08-23-2017, 01:58 PM
Zorba922's Avatar
Quoted: 3741 Post(s)
Liked: 2672
No such thing as "too powerful" for a sub...that's what the gain control knob on the back of it is for. If budget isn't a concern, I'd get the 115 for sure.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #9 of 15 Old 08-23-2017, 02:09 PM - Thread Starter
Liked: 1
I love sub punch, so, I just wanted another person who would tell me to take 115!
I'll go for 115!!
Zorba922 likes this.
post #10 of 15 Old 08-24-2017, 08:48 AM
gajCA's Avatar
Liked: 2671
I'll go for 115!!
Maybe make a cardboard shape of the box as it is huge for your tiny space!
gajCA is online now
post #11 of 15 Old 08-25-2017, 05:17 AM - Thread Starter
Liked: 1
This is what I was thinking before to buy the sub (115 or 112), just to have an idea of the space I need.
post #12 of 15 Old 08-25-2017, 05:30 AM
rn865's Avatar
Quoted: 40 Post(s)
Liked: 29
Not sure the RP line is a good match for the heritage sound.
That said, I have the RP-250c with Quartets for L/R and it's ok. Mainly have it because of space constraints. A Heresy or another Quartet would be ideal for the center if I had room.
rn865 is offline
post #13 of 15 Old 08-25-2017, 10:54 PM - Thread Starter
Liked: 1
It's the first time I read about Klipsch Quartet, I didn't know this speaker! Unfortunately here in Italy is impossible to find, new or used (I've seen it's been discontinued).
post #14 of 15 Old 08-25-2017, 11:05 PM
littlefoott's Avatar
Quoted: 344 Post(s)
Liked: 198
an svs subwoofer would be available in italy
http://svsound.it/subwoofer/svs-sb-sealed-cabinet/
and some paradigm speakers
and svs from here
http://xfaudio.it/prodotti/per-marchio/svs/
you won't have too much power if you have quality speakers it just get louder and still crystal clear
Audyssey is a great start, but not always a great finish.
Receiver:Marantz SR-5010, Speakers:Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
Subwoofer: SVS PB-2000
TV: 65" LG UG8700 remote: Harmony 1000
littlefoott is offline
post #15 of 15 Old 08-28-2017, 12:33 PM - Thread Starter
Liked: 1
and svs from here
Yeah, I absolutely prefer crystal sound to simple power with no quality. I'm going to give a look to this link, thank you so much littlefoott!
Reply Speakers
