3.1 for 750$? 1250$ with AV Receiver. - AVS Forum | Home Theater Discussions And Reviews
 26Likes
  • 4 Post By audiofreak38
  • 1 Post By Doe Doe
  • 3 Post By Zorba922
  • 1 Post By MaXiMo12
  • 1 Post By zieglj01
  • 1 Post By audiofreak38
  • 1 Post By Zorba922
  • 2 Post By Roctopuss
  • 1 Post By mpk1970
  • 2 Post By mikeTRON250LM
  • 1 Post By Roctopuss
  • 5 Post By MaXiMo12
  • 1 Post By mpk1970
post #1 of 22 Old 08-23-2017, 02:05 PM - Thread Starter
Liked: 6
Smile 3.1 for 750$? 1250$ with AV Receiver.
Hi all!
I am new to this, and after reading a lot in this forum, I thought it was better to directly ask my own question.
I am looking for a 3.1 system for a no dedicated room (No space for rear speakers, I will think about them in the future).
My budget is 1250$. My living room is 12'x19' including the kitchen. The area for the speakers is then 12'x12'.
At the moment my budget is divided on:
  • 500$ for the AV receiver Denon X2300W. Might be a lot taking into account my budget, but I did not see any other with two outputs (TV and projector) on a lower price.
  • 300$ for the Emotiva BasX Sub10
  • 450$ for center and front speakers. Here I am completely lost and I ask for your recommendations.
I could go a bit higher on the budget if the difference is substantial. The problem is, the more I read, the more money I will be spending
Thank you very much!
MaXiMo12 is online now
post #2 of 22 Old 08-23-2017, 02:22 PM
audiofreak38's Avatar
Quoted: 443 Post(s)
Liked: 563
Originally Posted by MaXiMo12 View Post
Hi all!
I agree that the Emotiva is a good option as far as subs go. For $500, you can get a refurb Denon AVR-X3300 instead which is a step up both in features and /or power. As far as speakers go, I would opt for the Chanes here:
https://www.chanemusiccinema.com/a-series-speakers/A1.4
https://www.chanemusiccinema.com/a-series-speakers/A2.4
http://www.accessories4less.com/make...eceiver/1.html
The Chane A1.4's coupled with the A2.4 center would be stellar! Especially, also having a 10" BasX sub. The X3300 also can EQ dual subs should you decide to add another down the road. Also, the X3300 has a better version of Audyssey. This would make for a very nice setup inmho! I know that the Chanes are bit more than the OP budgeted, but it would be so worth it and it really is not that much more. Best wishes to the OP!
Cheers,
Phil
BTW, the OP may can find some B-stock deals on the said Chanes A1.4/A2.4 Center. Just saying...........
audiofreak38 is offline
post #3 of 22 Old 08-23-2017, 02:28 PM
Quoted: 1064 Post(s)
Liked: 354
At the moment I'd say consider the JBL Studio 580s at $259 each, figure out the rest later. I'd go cheaper with the AVR... you can save $100 going refurb with it, if you must have that exact model.
mikeTRON250LM likes this.
Doe Doe is offline
post #4 of 22 Old 08-23-2017, 02:30 PM
Zorba922's Avatar
Quoted: 3699 Post(s)
Liked: 2650
I would spend more on the sub and less on the receiver. I'd go with the $400 Emotiva S12 at minimum, and move up to the Hsu VTF-2 ($604 shipped) if at all possible.
If your main priority with the receiver is it having 2 HDMI outputs for your PJ as well as TV, accessories4less will have plenty of choices in the $200-300 range...they are currently adding an extra 20% off the Integra receivers in-cart, these are where I'd look first. Integra is the premium line of Onkyo, like Lexus is for Toyota.
For the front 3, if your usage is mostly HT/TV not music I would look at the JBL B17 with C25 center from Amazon, for $250 shipped all told. Or get two pairs of QA 2020i for $320 shipped, using the 3rd one as your center.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #5 of 22 Old 08-23-2017, 03:08 PM - Thread Starter
Liked: 6
The only reason for the AV was that I read that on entry level Denon was better than other brands. Do you have a recommendation for a receiver around $300 with two outputs? Integra DTR-40.3 maybe?
You also say spend more on the sub. Would not be better to spend a bit more on the speakers Chane1.4 and Chane 2.4 and stay with the Emotiva S10 sub?
post #6 of 22 Old 08-23-2017, 03:20 PM
zieglj01's Avatar
Quoted: 1675 Post(s)
Liked: 1569
Go a little higher for the JBL Studio 2 series
JBL Studio 230
https://www.amazon.com/JBL-Studio-23.../dp/B00GJXSWZW
JBL Studio 235
https://www.amazon.com/JBL-Studio-23...ywords=jbl+235
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #7 of 22 Old 08-23-2017, 03:41 PM - Thread Starter
Liked: 6
Cheers,
Phil
JBL Studio 230
JBL Studio 235
Thanks for your answers.
Both your speakers suggestions are more or less on the same price range. I am reading on reviews that the Chanes might be a bit better?
Roctopuss likes this.
post #8 of 22 Old 08-23-2017, 03:45 PM
zieglj01's Avatar
Liked: 1569
My post meant to go above the $450, and above the Arena series -- Chane and the Studio 2 are good options -- it is your call on which one
mpk1970 likes this.
Who AM I
post #9 of 22 Old 08-23-2017, 04:33 PM
Quoted: 443 Post(s)
Liked: 563
Honestly, I have not owned the A1.4's. But, I did own (3) of the A2.4's and I can tell you first hand that they produced the most cohesive sound that I have ever experienced. Was totally blown away. Do think that you would be well served with the A1.4's and a A2.4 center. Couple them with the BasX10 or even the BasX12 and you will have one rocking setup.
Keep in mind that the Denon X3300 will have Audyssey Multi EQ XT32 w/Sub EQ HT. That is rather significant in that it can EQ two subs independently. Provided that you eventually end up with dual subs down the road. Check to see if Jon Lane albeit Chane has any B-stocks available. Might as well save some money. In fact, he might can make you a deal on (3) A2.4's across the front! Just saying..............best wishes!
Cheers,
Phil
mpk1970 likes this.
post #10 of 22 Old 08-23-2017, 08:06 PM
Zorba922's Avatar
Liked: 2650
Yes, the 40.3 or even the 30.4 at $300 ($250 shipped after discount).
If you are sure you will one day have dual subs and want to be able to EQ them using Audyssey XT32, there's the 50.4 at $500 ($410 shipped after discount).
If your usage is all HT/TV/gaming with no critical music listening, the JBL B17/C25 setup would probably be fine, and a $600 Hsu VTF-2 over the S10 would be worth it IMO. If you do go with the Chanes I'd still spend the extra $100 to get the $400 Emotiva S12 over the S10 though.
mpk1970 likes this.
Zorba922 is offline
post #11 of 22 Old 08-23-2017, 08:12 PM
Quoted: 70 Post(s)
Liked: 61
Chane a1.4 + a2.4 $600
HSU VTF-2 $600
Craigslist reciever + HDMI splitter $100
That's how you should be prioritizing. You can always upgrade the reciever later, and easily sell it for what you paid.
mikeTRON250LM and mpk1970 like this.
Roctopuss is offline
post #12 of 22 Old 08-23-2017, 08:26 PM
Quoted: 534 Post(s)
Liked: 541
I've got the DTR 40.3 from A4L, has worked very good in the couple months I owned it.
@Zorba922 and @audiofreak38 are steering you in right direction, spend most of your budget on 1. Sub 2. Speakers 3. AVR
In that order
JBL 230 good choice if you doing more HT than music
CHane's better all around speaker that really doesn't have any performance weaknesses for the most part, works very well in HT and music.
audiofreak38 likes this.
Receiver: Integra DTR 50.3 , 7.2 ch, 135 Watt
AMP: Outlaw 5000
Subs: (2) HSU VTF2 MK5
Speakers LRC: Chane's A2.4
Rears: Chane's A1.4 Surrounds: Phil AAs
Outdoor Speakers: Definitive Technology AW 6500
mpk1970 is offline
post #13 of 22 Old 08-23-2017, 10:45 PM
mikeTRON250LM's Avatar
Quoted: 242 Post(s)
Liked: 161
Hi all!
I think spending more on your AVR than speakers or sub(s) is doing it wrong. I mean obviously the 3300 is a good receiver but the extra $150 over the 1300 wont make a $850 3.1 sound any better. than a $1k receiver.
edit: i jusy realized the original post was for the 2300. I'd say that is an unwise decision. Either get the 1300 or the 3300, where the 3300 will shine with multiple subs (that you don't have in the budget).
Ultimately I'd say the best bang for the buck is about 300 for the receiver, 500 for a sub and 750 for LCR, just for reference. Also the best way to stretch your dollar is to buy slightly used gear.
mikeTRON250LM is offline
post #14 of 22 Old 08-23-2017, 10:48 PM
Quoted: 242 Post(s)
Liked: 161
HSU VTF-2 $600
This will produce a substantially better sound than your original allocated funds to the different components.
Sent from my SM-G935P using Tapatalk
pase22 and Roctopuss like this.
post #15 of 22 Old 08-24-2017, 05:41 AM
Zorba922's Avatar
Liked: 2650
Wait, I thought you have the 50.3?
Zorba922 is offline
post #16 of 22 Old 08-24-2017, 05:58 AM
Quoted: 70 Post(s)
Liked: 61
I betting that's his sons AVR.
...I just realized I may be spending too much time on this forum
KCZ1 likes this.
post #17 of 22 Old 08-24-2017, 06:31 AM - Thread Starter
Liked: 6
HSU VTF-2 $600
Cheers,
Phil
Thank you very much guys!
I was not expecting to spend so much on the sub, but I am the noob here so I will finally go for the Hsu VTF-2.
Also, I spoke with A4L and the AVR are all 110V. I will go back to Europe in around 1 year so I will need to sell the AV before I go. I think I will get the Denon AVR-S530BT for $200 and then a HDMI splitter.
It is a new model so I think it will be easier to sell it. Also, I want Bluetooth which the Integra don't have. Unless of course you think of something else?
I just have another noob question. Is the 70W enough for the speakers? the A2.4 says 20W-200W recommended.
So finally the system would be:
  • Denon AVR-S530BT $200
  • Chane a1.4 + a2.4 $600
  • Hsu VTF-2 $600
Total $1400 which is not so far from the original budget. (Knowing that writing here usually doubles the original budget )
Of course I am open to any other suggestion.
I really appreciate your help!!
post #18 of 22 Old 08-24-2017, 06:57 AM
Quoted: 70 Post(s)
Liked: 61
Whether 70w is enough depends on multiple factors.
How loud do you like to listen?
How far will you sit from the front soundstage?
Will your sub go up front near your TV? If so, you can get away with a higher crossover (say, 120hz instead of 80hz), thereby removing more of the burden from your AVR, giving you more clean headroom.
post #19 of 22 Old 08-24-2017, 07:07 AM
Quoted: 242 Post(s)
Liked: 161
  • Hsu VTF-2 $600
Normally I would suggest the denon 1300x bu moving to europe makes for an odd situation.
You will be very glad you got a better sub.
post #20 of 22 Old 08-24-2017, 07:08 AM
zieglj01's Avatar
Liked: 1569
for your info, world wide voltage receivers
http://www.worldwidevoltage.com/receiver.html
Who AM I
post #21 of 22 Old 08-24-2017, 10:47 AM
gajCA's Avatar
Quoted: 4142 Post(s)
Liked: 2639
  • Hsu VTF-2 $600
You might want to ask HSU about using their sub in Europe with a voltage converter.
Geoff A. J., California
gajCA is online now
post #22 of 22 Old 08-24-2017, 05:51 PM
Quoted: 534 Post(s)
Liked: 541
Bingo! Lol
@Zorba922
I have the 50.3
Son 40.3
AMP: Outlaw 5000
mpk1970 is offline
Reply Speakers
3.1 system , speakers and subs , under $1000
