5.1 Surround speaker question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Zorba922
post #1 of 8 Old 09-11-2017, 05:20 AM - Thread Starter
Liked: 0
Question 5.1 Surround speaker question
Hello all, long time unregistered forum reader here.
I'm finally(!) able to upgrade my TV & surround system. Coming from a 10+ year old LCD screen & Cambridge Soundworks 5.1 speakerset I did go for OLED and Elac Debut (B6/C5) speakers.
Sadly enough my living room is not perfect for the best setup*. For now I had to make some concessions, but i'm still blown away with the sound quality. Maybe a bit to much on the bass side, probably due boundary interference. I'm still working on that.
*I also have to consult my wife on design/placing challenges
I also want to replace the rear speakers. They are now placed near the couch on stands. I would prefer to place them on the walls. Beside the couch (A) or on the wall (B) (see attached picture).
Some challenges I have with this:
  • option A will place the speakers before the seating positions (reading from forum posts its preferable to place them just above the seating position)
  • option B will place the speakers behind of the seating positions and rather far away (~10 feet).
Now for my main question: I would like your opinion and what you see as a possible solution on my challenge with the placement of the rear speakers. As stated, I want to go for mounting and to choose rather small speakers (I used all the wifecredits with the rather large B6's ). It is possible to place te couch a bit further away from the TV (but not closer by).
Many thanks in advance!
planetcaravan is offline
post #2 of 8 Old 09-11-2017, 08:58 AM
Zorba922's Avatar
Quoted: 3696 Post(s)
Liked: 2649
If going with monopoles, Option A.
If going with bipoles, Option B.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 8 Old 09-12-2017, 03:43 AM - Thread Starter
Liked: 0
Hi Zorba922,
Thanks for your reply.
Do you maybe mean the other way around? So bipoles on the walls (option A) And monopoles on the far side of the wall (B)? Or do I misunderstand you?
Could you elaborate on your answer?
Many thanks!
post #4 of 8 Old 09-12-2017, 11:45 AM
Zorba922's Avatar
Liked: 2649
Oops, you're right.
If you do Option B make sure the monopoles are slightly angled so that they aren't pointing directly at the fronts and possibly cancelling out some of the frequencies.
planetcaravan likes this.
Zorba922 is offline
post #5 of 8 Old 09-13-2017, 08:08 PM
Quoted: 50 Post(s)
Liked: 2
Suggestion
Can't you change the position of your sofa to currently marked as rear left to negate all issues wrt to location you are facing now? I had same room dimensions some time back and this is what i did. This would help you place Front speakers, woofer, TV and rears in intended way.
Just my 2 cents.
argentum246 is offline
post #6 of 8 Old 09-14-2017, 01:10 AM - Thread Starter
Liked: 0
Just my 2 cents.
Hi argentum246,
Thanks for commenting. We are using the space behind our couch for the kids to play.. and it will be to far away from the tv in my opinion...
post #7 of 8 Old 09-14-2017, 01:11 AM - Thread Starter
Liked: 0
Oops, you're right.
Thanks, I'm thinking this is the way to go for now.
I'm worried that the sound will be off if I place the surrounds in front of the seating position.
post #8 of 8 Old 09-14-2017, 07:49 AM
Zorba922's Avatar
Liked: 2649
I think I would skip the back surrounds and only do the side surrounds, honestly. As long as you have the sides pointing back at the seating position and get your AVR to level match them you'll be fine. Maybe something like this:
https://www.amazon.com/Klipsch-4-Inc...s=klipsch+rb10
Zorba922 is offline
Reply Speakers
