5.1/5.1.2 recommendations for a 13 ft X 13 ft living room - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 92 Old 09-11-2017, 03:31 PM - Thread Starter
srikkanth.m's Avatar
Quoted: 46 Post(s)
Hello all,
Long time lurker here but haven't posted much. I used to have a pretty solid setup back in the day with a Denon AVR-1911 and a Jamo 5.1 setup. But due to some reasons I had to sell everything. Since then, I moved houses and I am currently looking to build my DIY setup. I have a 13 ft X 13 ft living room where I watch my TV. I don't have walls on all 4 sides. One side of the room leads to the dining area. So I have to put the rears on the back of the couch.
Can you recommend a 5.1 setup? Does Atmos matter in real world? If so, can you recommend a 5.1.2 setup? My budget is around $3000 max. including wiring, receiver and everything. I may have to do some magic to hide the wiring but I will take care of it.
srikkanth.m is offline
post #2 of 92 Old 09-11-2017, 08:39 PM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
Can you terminate your own speaker wire or use bare wire?
100 ft of AWG 12 bare copper speaker wire - $30
Chane A2.4 x 3 - $837
Chane A1.4 x 2 - $329
Klipsch RP-140SA - $349
Power Sound Audio 15S / 15V B-Stock - $799 / $849
Yamaha RX-A1060 / Denon AVR-X4300H - $699
Total $3043 / $3093
Add $27 for 14 pairs of Sewell Strike Banana Plugs
Don't forget the free sub crawl!
darthray likes this.
animeking is offline
post #3 of 92 Old 09-11-2017, 08:50 PM
jjackkrash's Avatar
Quoted: 1193 Post(s)
Liked: 1029
Great call. I just got turned in to Sewell Deadbolts. Man, oh man, Sewell banana plugs are the bees knees. I did not realize how bad all my other banana plugs sucked until I got these.
jjackkrash is offline
post #4 of 92 Old 09-11-2017, 08:57 PM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
I have Deadbolts......I wish I knew about Strikes earlier.
post #5 of 92 Old 09-11-2017, 08:59 PM
jjackkrash's Avatar
Liked: 1029
Originally Posted by srikkanth.m View Post
Hello all,
Got pics or a diagram? I generally think of "rears" as speakers 6 & 7, speakers 4 & 5 usually go to the sides just behind the listener.
Here's a chart for 5.1.2, can you get close to this positioning?
https://www.dolby.com/us/en/guide/do...-2-setups.html
And if you can get 2 overheads, can you get 4? 5.1.4 is awesome (IMO) if you can get the speakers in the right spot.
post #6 of 92 Old 09-11-2017, 09:01 PM
jjackkrash's Avatar
Liked: 1029
They are even better? Wow. I have a whole dedicated room to populate still, I'll keep the strikes in mind. BTW, what is better about them?
post #7 of 92 Old 09-11-2017, 09:03 PM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
Go to the Sewell website and compare the specs of both plugs. I think you can judge for yourself which one seems to be better. For me, it's the Strike, hands down for the V-Cone and the smaller size.
post #8 of 92 Old 09-11-2017, 09:04 PM
jjackkrash's Avatar
Liked: 1029
Ok, I'm sold, these look awesome.
https://sewelldirect.com/strike-bana...s-14-pair-pack
post #9 of 92 Old 09-11-2017, 09:24 PM
pase22's Avatar
Quoted: 1362 Post(s)
Liked: 1141
Hello all,
This is all you really need in a room that size.
HSU Hybrid 2 5.1 package.
http://www.hsuresearch.com/products/hybrid2mk5pkg.html
Denon AVR-X3300
https://www.accessories4less.com/mak...eceiver/1.html
jjackkrash likes this.
Kef Q100 FL/FR,SL/SR, Kef Q200C, Bic F12 sub, Denon AVR-S710W, , Panasonic 50" Plasma, cable box, Xbox One, Toshiba laptop.
Bedroom: JBL Loft 50 FL/FR , Loft 20 center, JBLSP 150 sub, Pioneer VSX-830K, PS3, 32" Insigna LED.
pase22 is online now
post #10 of 92 Old 09-11-2017, 09:30 PM
jjackkrash's Avatar
Liked: 1029
Denon AVR-X3300
Or Hybrid 3.
post #11 of 92 Old 09-11-2017, 09:36 PM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
Denon AVR-X3300
What about Atmos speakers?
post #12 of 92 Old 09-11-2017, 09:38 PM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
OP, how picky / critical are your ears?
post #13 of 92 Old 09-12-2017, 08:18 AM
Adam.C's Avatar
Quoted: 14 Post(s)
Liked: 35
Those do look awesome! Getting those next time.
OP, I agree with the suggestions of looking at the Klipsch RP line or HSU. Both should suit you very well.
Sight and Sound
Adam.C is offline
post #14 of 92 Old 09-12-2017, 09:25 AM
pase22's Avatar
Liked: 1141
Depends on what his intensions are and his room layout. Is he looking for in ceiling speakers? Maybe some up firing modules or front height channels? The OP will need to provide some information before recommendations can be made.
post #15 of 92 Old 09-12-2017, 09:29 AM
gajCA's Avatar
Quoted: 4322 Post(s)
Liked: 2780
Hello all,
I'd start by auditioning some Klipsch RP bookshelves from Best Buy with their easy returns and if happy, fill out from there.
Denon 3300 is currently a great value and it will EQ your sub(s).
Might want to consider two subs for your space as it is small but wide open.
You can always add Klipsch Atmos upfiring or wall mounted speakers later to try Atmos and simply return them if not impressed.
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
Specs are from the manufacturer unless noted otherwise.
150watts =11w18h13d= 18 lbs 8" [28hz] $199 EMOTIVA BASX S8
200watts =14w16h16d= 34 lbs 10" [27hz] $299 EMOTIVA BASX S10
300watts =17w18h18d= 49 lbs 12" [26hz] $399 EMOTIVA BASX S12, (extension from Brent Butterworth measurement)
350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
250watts =15w19h17d= 42 lbs 10" [22hz] $423 HSU VTF 1 MK3
200 watts =16w19h17d= 52 lbs 12" [22hz] $439 HTD LEVEL THREE
300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10" (coming soon)
300watts =16w22h21d= 69 lbs* 12" [19hz] $549 RHYTHMIK LV12R
350watts =15w21h22d= 62 lbs 12" [18hz] $604 HSU VTF2 MK5, (verified by Audioholics review)
* = shipping weight
SEALED SUBWOOFERS $650 AND BELOW, DELIVERED
300watts =13w14h16d= 27 lbs 12" [23hz] $499 SVS SB1000, (extension from Sound & Vision)
300watts =14w14h16d= 58 lbs* 12" [18hz] $539 RHYTHMIK L12
500watts =14w15h17d= 35 lbs 12" [19hz] $649 SVS SB2000 outlet, (extension from Sound & Vision)
* = shipping weight
Geoff A. J., California
gajCA is offline
post #16 of 92 Old 09-12-2017, 09:40 AM
NuSoardGraphite's Avatar
Quoted: 402 Post(s)
Liked: 367
This kills me too. So many people call the side surrounds "rears". To me that creates confusion. Someone tells me they have "rears" and I assume they got 7.1 but more often than not they mean 5.1, lol
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #17 of 92 Old 09-12-2017, 10:37 AM - Thread Starter
Quoted: 46 Post(s)
Hi all,
Great suggestions so far. Here is the config of the room. Image attached. This is an approximation but you get the idea. The only solid wall I have is the back of the couch and back of the TV.
Name:	Screen Shot 2017-09-12 at 10.35.12 AM.png
post #18 of 92 Old 09-12-2017, 10:39 AM - Thread Starter
Quoted: 46 Post(s)
I still hear all the frequencies in the audible spectrum, if that's what you mean. Also, I am picky in the sense that I don't like if music overpowers voice while watching a movie. I like bass but not rattling bass.
post #19 of 92 Old 09-12-2017, 10:40 AM - Thread Starter
Quoted: 46 Post(s)
I don't want to install in-ceiling speakers.
post #20 of 92 Old 09-12-2017, 10:41 AM - Thread Starter
Quoted: 46 Post(s)
Denon AVR-X3300
I haven't heard about HSU before. I will check them out.
post #21 of 92 Old 09-12-2017, 10:42 AM - Thread Starter
Quoted: 46 Post(s)
I have attached the layout of the room. I looked at the Atmos diagram you provided and I think I can get to the 1st configuration pretty easily.
post #22 of 92 Old 09-12-2017, 11:11 AM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
Do you require very critical speakers within your budget that pick out every detail or do you just want some relaxing speakers that have a decent sound?
post #23 of 92 Old 09-12-2017, 11:19 AM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
Are you going to use overheads, heights or upfiring?
post #24 of 92 Old 09-12-2017, 11:27 AM - Thread Starter
Quoted: 46 Post(s)
Ah. The speakers that pick out the detail are what I prefer. But, I am not sure if I can get those in my budget.
post #25 of 92 Old 09-12-2017, 11:28 AM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
You can get that from the kit I put together for you earlier.
post #26 of 92 Old 09-12-2017, 11:30 AM - Thread Starter
Quoted: 46 Post(s)
Overheads as in actual overhead speakers hooked to the ceiling? No. I believe you asked this question for Atmos? If so, I am not sure how much actual difference would Atmos makes. Are upfiring reflective speakers enough?
post #27 of 92 Old 09-12-2017, 11:31 AM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
You can get away with upfiring, that's what I currently use.
If you don't want to do overheads, you can try using height speakers. How high up on the wall can you mount speakers?
post #28 of 92 Old 09-12-2017, 11:32 AM - Thread Starter
Quoted: 46 Post(s)
About 10ft high.
post #29 of 92 Old 09-12-2017, 11:34 AM
animeking's Avatar
Quoted: 247 Post(s)
Liked: 80
About 10ft high.
That's plenty high. Replace the Klipsch pair in my kit with another pair of A1.4's and use 1 set of A1.4's as side surrounds and 1 set of A1.4's as front height speakers for Atmos.
post #30 of 92 Old 09-12-2017, 01:02 PM - Thread Starter
Quoted: 46 Post(s)
Got it. Will take a look. Thanks.
Reply Speakers
