Tower Speaker needs Repair - Finding a shipping box? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By bluewizard
  • 1 Post By bluewizard
post #1 of 5 Old 09-15-2017, 02:22 PM - Thread Starter
lonestarwings's Avatar
Quoted: 22 Post(s)
Hello, I have a Phase Technology PC 9.5 tower speaker that needs to go back for repair.
I of course kept the original boxes when I bought them 5 years ago, but I had some water damage in my old apartment's storage closet due to a faulty sprinkler system and they were unfortunately destroyed.
Not only do I need a suitable box, but I need to rig some kind of padding/bracing structure up inside the box so that the weight of the enclosure doesn't end up crushing the drivers.
I contacted the manufacturer to see if they would be willing to provide the shipping materials but was just told to go to wal-mart.
Does anyone have any ideas?
Dimensions are 46"x9"x15" and weight is 66 pounds. It isn't a rectangular prism, it has curved sides.
http://phasetech.mseaudio.com/series...ection/pc-9-5/
lonestarwings is offline
post #2 of 5 Old 09-15-2017, 03:00 PM
bluewizard's Avatar
Quoted: 1937 Post(s)
Liked: 1223
Uline - Minneapolis, Chicago, Toronto, New York, Atlanta, Dallas, Los Angles, Seattle -
https://www.uline.com/Cls_04/Boxes-Corrugated
https://www.uline.com/BL_417/275-Lb-...gle-Wall-Boxes
https://www.uline.com/BL_406/Long-Boxes
https://www.uline.com/Corporate/About_Locations
I'm guessing you will need a box roughly 48" H x 12" D x 16" to 18" W
https://www.uline.com/Product/Detail...rrugated-Boxes
https://www.uline.com/Product/Detail...ywords=s+14235
https://www.uline.com/Product/Detail...ywords=s+20416
They will UPS ship the boxes to you, and from my experience, no minimum order.
Steve/bluewizard
vardo and lonestarwings like this.
bluewizard is offline
post #3 of 5 Old 09-15-2017, 03:08 PM
bluewizard's Avatar
Liked: 1223
post #4 of 5 Old 09-17-2017, 11:56 AM
bluewizard's Avatar
Liked: 1223
Here are a couple of boxes that might work better. These are telescoping boxes. That is they have fixed width and depth, but the height is adjustable from 40" to 74".
That you could use, the have 16 x 16, 18 x 18, and 20 x 20. I suspect the 18" x 18" would be about right.
S-11249 = 16" x 16" x (40" to 74") - $7.42 each -
https://www.uline.com/Product/Detail...ywords=S-11249
S-20428 - 18" x 18" x (40" to 74") - $8.61 each -
https://www.uline.com/Product/Detail...ywords=s-20428
S-11250 - 20" x 20" x (40" to 74") - $9.79 each -
https://www.uline.com/Product/Detail...ywords=S-11250
Steve/bluewizard
post #5 of 5 Old 09-19-2017, 03:09 PM
Gandu's Avatar
Quoted: 73 Post(s)
Liked: 93
Might try the loading dock at local furniture stores, I was able to find plenty of packing material. Those 'Pool Noodle' soft Styrofoam flotation toys could come in handy as well, and they are relatively cheap.
Check the AudioKarma.org 'Packing and Shipping' forum for more ideas. http://audiokarma.org/forums/index.p...g-shipping.87/
Local option to get a speciality box: http://www.ecobox.com/ https://www.yelp.com/biz/1-2-price-boxes-austin
Gandu is offline
Reply Speakers
