New Surround sound help - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Kini62
post #1 of 7 Old 09-19-2017, 06:21 AM - Thread Starter
Quoted: 78 Post(s)
Just moved to a new house....
Time to do up the family room. 5.1 preferred...
I got the ok to buy a 75" Sony XBR 850E not sure about the 900E but...
Looking for a nice receiver subwoofer Front center and left to compliment the TV.
The room is awkward and I can up load pictures tonight...
Basically its tile floor with open floor plan on the left side of the tv if youre looking at the tv and sliders on the left.
The room is about 18 feet wide by about 20 feet deep. The wall where the tv will go is 18 feet wide.
Few years ago I was on here and got some great help with SVS sub and A Denon receiver with some bookshelf speakers but now Im looking at some larget floor speakers.
My bro in law has some martin logan motion 40s Not sure how good those are or how they compare to what you guys would recommend...
My budget is around 3000 or so....
Thanks!!
redrovermiami is offline
post #2 of 7 Old 09-19-2017, 08:35 AM
Zorba922's Avatar
Quoted: 3857 Post(s)
Liked: 2761
I would look at a pair of Emotiva T2 towers and a C2 center:
https://emotiva.com/product/airmotiv-t2/
https://emotiva.com/product/airmotiv-c2/
And for the sub, this monstrous Hsu is currently on sale:
http://www.hsuresearch.com/products/vtf-3mk5HP.html
About $2200 shipped all told.
For the receiver, look here:
https://www.accessories4less.com/mak...ceivers/1.html
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 7 Old 09-19-2017, 10:53 AM
gajCA's Avatar
Quoted: 4301 Post(s)
Liked: 2759
Thanks!!
I really like my bookshelf version of the Motion 40s but fear that in your very very bright room they might come off as too bright so I would suggest you look at a speaker with a warmer sound signature like Wharfedale.
Nice thing is their towers are available in many different finishes and they can be purchased, and returned easily, at Best Buy.
https://www.bestbuy.com/site/shop/wharfedale-speakers
For a room that large you might want to consider two Rhythmik or HSU subs though SVS is always an option with their free returns which the others don't offer.
Denon x300 receivers are on sale at the moment as they have been replaced by the newer x400 series and the nice thing is many of the x300 receivers have EQ that will EQ your subs.
In a bright room like that get the best EQ you can afford...I'd look at the $500 2300.
https://www.crutchfield.com/p_033AVX...0W.html?tp=179
Geoff A. J., California
gajCA is online now
post #4 of 7 Old 09-19-2017, 02:41 PM
Kini62's Avatar
Quoted: 1741 Post(s)
Liked: 1555
Most of the time brighter sounding speakers such as the Motions are a benefit for HT. If music at high(ish) volume is going to be a large percentage of use, perhaps something with a little high end roll off would be better.
See if you can borrow your friend's motion 40s and hear how they sound in your room. Denon/Marantz are popular choices since most like Audyssey, especially the models with sub EQ. If the Audyssey app works, it makes for a nice system since you can alter the curve and frequency response of the room correction.
The 1000 series and up Yamahas are nice. They have a pretty good auto setup and a nice PEQ for manual tweaking.
gajCA and redrovermiami like this.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 7 Old 09-19-2017, 02:52 PM
gajCA's Avatar
Liked: 2759
Great suggestion to borrow the friend's speakers.
gajCA is online now
post #6 of 7 Old 09-20-2017, 05:48 AM - Thread Starter
Quoted: 78 Post(s)
Any reason in particular you recommended the emotivas?
Why not cantons or any other brand?
post #7 of 7 Old 09-20-2017, 09:49 AM
gajCA's Avatar
Liked: 2759
A HSU HB1/HC1 package might be another "not too bright" speaker to consider for your room.
5.1 packages that play below 20hz start at $1505 and 5.2 packages start at just under $2100.
http://www.hsuresearch.com/packages.html
Many reviews of HSU systems to google or simply access off their site.
http://www.hsuresearch.com/reviews.html#speakers
gajCA is online now
Reply Speakers
