Changing impedence on yamaha reciever doesn't change volume level..... - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 5 Post By DonH50
  • 2 Post By DonH50
  • 1 Post By DonH50
post #1 of 9 Old 09-23-2017, 05:12 PM - Thread Starter
Quoted: 410 Post(s)
Liked: 288
So , just to know for myself i checked the db level before and after changing impedence on my reciever. .. same volume from same song,using same speakers... make of it what you will , just thought it was interesting after some discussions on here...
Lp85253 is online now
post #2 of 9 Old 09-24-2017, 08:55 AM
DonH50's Avatar
Quoted: 2222 Post(s)
Liked: 1828
Changing the impedance setting on an AVR usually throttles the voltage rails and/or current. The gain structure is not changed. Unless you are clipping there would be no change in volume.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #3 of 9 Old 09-24-2017, 05:43 PM - Thread Starter
Quoted: 410 Post(s)
Liked: 288
thanks ... i was under the impression that it trimmed volume as well...at moderate volume it seemed i lost nothing(sound quality) when i changed the setting to 6 ohm...
post #4 of 9 Old 09-25-2017, 06:51 AM
DonH50's Avatar
Liked: 1828
Yup, should lose nothing. And if it was working fine at the 8-ohm setting, I would leave it there as you'll have a little more headroom (though you probably do not need it). If the AVR gets too hot and/or goes into protect mode, switch to 6 ohms; otherwise, leave it at 8 ohms and enjoy.
ALtlOff and Lp85253 like this.
post #5 of 9 Old 09-25-2017, 09:11 AM - Thread Starter
Quoted: 410 Post(s)
Liked: 288
i just found that with my Wharfdale 10.1s attached that the avr ran considerably cooler , which of course means longer expected life ... it wasn't running real hot on 8 ohm , but on 6 ohm it was hardly warm after about 30 minutes music at moderate volume.... thanks again .. i am always learning something new on here
post #6 of 9 Old 09-25-2017, 09:38 AM
DonH50's Avatar
Liked: 1828
Those speakers have low sensitivity (86 dB/W/m) and nominal 6-ohm rating but dip to 4 ohms or so for a lot of their lower range so that makes sense. No harm in leaving it set to 6 ohms if the sound is good and the AVR runs cooler.
Lp85253 likes this.
post #7 of 9 Old 09-25-2017, 10:20 AM
Liked: 0
use size 12 AWG cable for best result
Heman90210 is offline
post #8 of 9 Old 09-25-2017, 10:41 PM
jdcrox's Avatar
Quoted: 80 Post(s)
Liked: 107
Why? Unless the speakers are a considerable distance from the receiver, 14 or 16 gauge should be more than adequate, and will sound the same.
jdcrox is offline
post #9 of 9 Old 09-26-2017, 12:37 AM
Ben Tan's Avatar
Quoted: 380 Post(s)
Liked: 307
Really? 12 AWG? That's for kids.
I use industrial grade 2/0 AWG cables for the interconnects alone!
- 5.2.4 Bedroom Theater -
SVS Ultra Bookshelf + SVS Ultra Center
Prime Bookshelf Surround with Prime Elevation
Dual SVS SB2000
Yamaha RX-A3060 + Parasound Halo A31 + Emotiva A500
Ben Tan is offline
Reply Speakers
