Near Field Monitors - Good for Home Theater? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-14-2004, 07:51 AM - Thread Starter
ace5000's Avatar
Quoted: 23 Post(s)
I am interested in the Tannoy Reveal Nearfield monitors for HT. The Reveal line has a dedicated center channel as well.
Is this type of speaker designed differently than a std. HT speaker? I know you can listen close to them 3-4 ft. for studio use but, how about 10-11ft.?
Can you guys add some insight to this? Also, how do you think the Reveals would be for HT in a small to med. sized room? Thanks.
ace5000 is offline
post #2 of 4 Old 04-14-2004, 08:18 AM
tonygeno's Avatar
Quoted: 134 Post(s)
Liked: 37
They will work. Nearfield monitors will sound a bit "softer" farther away as the treble energy falls off a bit, which will be a good thng for home theater.
I have had very good luck with pro monitors in a home theater setting, having used NHTs, Mackies and JBLs. The LSR25p JBL is an amazing value for around $250 each with built in amps.
Tony
In search of the Holy Grail.
tonygeno is offline
post #3 of 4 Old 04-14-2004, 09:11 AM - Thread Starter
ace5000's Avatar
Quoted: 23 Post(s)
Cool. Have you ever heard the Tannoy Reveals?
ace5000 is offline
post #4 of 4 Old 04-14-2004, 10:00 AM
tonygeno's Avatar
Quoted: 134 Post(s)
Liked: 37
Yes, but I haven't lived with them. I think they're a good value, but I'd go with the JBL's personally.
Tony
tonygeno is offline
Closed Thread Speakers
