Paradigm Owners Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 1055Likes
post #271 of 34900 Old 09-08-2005, 06:06 PM
JohnGZ28's Avatar
Originally Posted by Kal Rubinson View Post
When the path distance to the listener from 2 drivers reproducing the same sound is different, they will constructively and destructively interact. This is a concomitant of a horizontal array if you sit off-axis. Not the same with a vertical array.
Kal
At what point or distance does this become a problem? Assuming everything is cool sitting directly in front of the speaker, if you move one seat to the right or left or two seats, etc.
JohnG
JohnGZ28 is offline
post #272 of 34900 Old 09-08-2005, 06:07 PM
Prozakk's Avatar
As little as 1 inch can make a difference.
Anyone selling an SVS PB12 Ultra/2 in Textured Black in North Tx, Ok., La., or Ar., P.M. me please. Have truck, will travel!
My outdated HT pics
Prozakk is offline
post #273 of 34900 Old 09-08-2005, 06:45 PM
Prozakk's Avatar
I would like to clarify something...
The CC370 v.1 & v.2 were good down to 70hz. The v.3 & v.4 down to 100hz.
The CC has NO internal bracing, and uses 5/8" instead of 3/4" particleboard.
My outdated HT pics
Prozakk is offline
post #274 of 34900 Old 09-08-2005, 06:52 PM
Yung's Avatar
Wonder why Paradigm did this with the CC-370. Even the CC-170 and CC-270 in the Performance line are rated down to 70Hz.
Yung is offline
post #275 of 34900 Old 09-08-2005, 06:59 PM
Prozakk's Avatar
That's the $100,000 question!
My outdated HT pics
Prozakk is offline
post #276 of 34900 Old 09-08-2005, 08:02 PM
redline65's Avatar
Have you heard the Signature series?
No No, and I refuse to!
redline65 is offline
post #277 of 34900 Old 09-08-2005, 08:11 PM
TYBZ's Avatar
Hmm interesting point, so as Prozakk cleverly pointed it out, it's actually better to have a bookshelf speaker as a center when listening off-axis.
Anyone have some experiences to share about a Studio 20 V3 as a center channel? Since a Studio 20 is smaller then CC-470, how does it go?
TYBZ is offline
post #278 of 34900 Old 09-08-2005, 08:18 PM
Kal Rubinson's Avatar
Quoted: 804 Post(s)
Liked: 571
Nope but I found that a Studio 20 v2 was a great improvement on a Studio CC. That was temporary until I got the third Studio 60.
Kal
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #279 of 34900 Old 09-08-2005, 08:19 PM
Yung's Avatar
I didn't want to listen to the Sigs either. Went to my Paradigm dealer intending to listen to V.4 Monitors but he didn't have them out. Instead he had me listen to a pair of S4's. I was afraid to listen since I thought listening to anything else afterwards would disappoint me. However, I'll just take the listening experience (which had me smiling ear to ear) as having listened to a really great speaker and trying to get as close as that within my budget in the future.
Yung is offline
post #280 of 34900 Old 09-08-2005, 08:26 PM
TYBZ's Avatar
Originally Posted by oztech View Post
with those dimensions i would look into a large sub velodyne or paradigm with a 15 inch woofer. close to my space i had to take back the 12 get the 15 vel to fill the space won't to feel the explosions not just hear them.
I guest that the post was a reply to mine
Thanks for the input man, now I'm wondering, a 15 woofer!? It seems kinda big, remember I don't want to disturb the neighbours too much, since my living room space is about 12' X 14', I won't sit far away from the sub. Maybe there is something that I don't understand. The thing is that I don't want to spend $1200 on a sub, and use it up only to $600 worth of sound because of the neighbours, you know... but since I'll be at the basement level, will they be much affected?
Also, should I go with a Paradigm sub? In general, are they good value, or I would be better off with a more sub specific manufacturer? And witch one? Hehe
TYBZ is offline
post #281 of 34900 Old 09-08-2005, 08:58 PM
srckkmack's Avatar
Originally Posted by wrg2 View Post
srckmack, I'm curious...did you fill the J-29 stands with sand?
No, I did not fill the J-29's with sand or shot. I considered it, but the stands are already very sturdy and have pre-drilled holes and hardware for connecting to the speakers. While evaluating the ADP470's, I compared and even purchased (and since returned) some other speaker stands. None of them seemed nearly as stable as the J-29's. The stands are also out of any traffic patterns, so I'm not as concerned.
Steve
srckkmack is offline
post #282 of 34900 Old 09-09-2005, 11:43 AM
JohnDG's Avatar
Quoted: 12 Post(s)
How about experiences with a Mini-Monitor instead of a CC370 as a center channel?
jdg
JohnDG is offline
post #283 of 34900 Old 09-09-2005, 11:48 AM
Prozakk's Avatar
jdg
Do you mean other than the one I previously posted in this thread?
My outdated HT pics
Prozakk is offline
post #284 of 34900 Old 09-09-2005, 12:19 PM
s2silber's Avatar
I've got the Paradigm set-up below for all but my subwoofer, which I'm looking to upgrade for something under $1K. I welcome any suggestions for a complementary subwoofer at this price point and for a new AV Receiver (considering upper end Denons).
Front: Paradigm Reference Studio 60 V.3
Center: Paradigm CC470 V.3
Surrounds: Paradigm Reference SR15 (In ceiling)
Subwoofer: JBL PB10
AV Receiver: Onkyo TX DS 696 (100wpc)
DVD Player: Denon DVD 2900
Sony KDF 50 WE610 LCD Rear Projection TV
LG LSS 3200A DirecTV HD receiver.
s2silber is offline
post #285 of 34900 Old 09-09-2005, 12:46 PM
outlier2's Avatar
I have a CC 570 and love it. I wouldn't scrimp on the CC and I'd avoid using a conventional speaker for a center. They don't have the same dispersion characteristics and are designed to sit upright, not on their sides. Plus the CC is timbre matched to my 60's which is very important. Blanket statements like CC's aren't any good or mini's make a good center are misleading. If you don't like the 100Hz cutoff of the 370 (I don't) get a bigger better CC.
Healthy skepticism is the best component for your HT
outlier2 is offline
post #286 of 34900 Old 09-09-2005, 12:47 PM
Yuri33's Avatar
No. horizontal speakers wont sound as good, as an equally sized bookshelf speaker. Off axis problems with the tweeter being in the middle of 2 mids is the problem.
Just turn it on its side...
Yuri33 is offline
post #287 of 34900 Old 09-09-2005, 01:26 PM
Prozakk's Avatar
Nothing beats 5 or 6 or 7 identical speakers.
I NEVER said to use a bookshelf on it's side. The wave guide on Paradigm speakers is designed to be mounted vertical for bookshelf, horizontal for CC.
Identical dispersing speakers, with identical drivers/enclosures are ideal.
CC's are made for the sole purpose of being near a screen, thus horizontal. It's not better sounding, it's mounting convenience.
The larger 470 & 570 doesn't match the timber of the Monitor series, thus would be a worse purchase.
My outdated HT pics
Prozakk is offline
post #288 of 34900 Old 09-09-2005, 01:29 PM
Prozakk's Avatar
Tweeter wave guides are speaker specific. Also a bad idea.
Horizontal speakers will have negative driver interaction.
My outdated HT pics
Prozakk is offline
post #289 of 34900 Old 09-09-2005, 07:23 PM - Thread Starter
wrg2's Avatar
srckkmack, Basically like you I laughed off the filling of the J29 stands like you, I said to myself, these are great stands and have a bit of weight in structural design, most for appeal. The black oval bases standing anchored to the black bases with the metal thread adjustable pin-point spikes for feet. These stands are extremenly stable. HERES A TIP...fill those J29 stands with playground sand, and at that point run you speaker cables through the stands tp the top of stands and ready to conect to the speakers terminals. Don't cheat yourself with the stands and how to properly use them. BTW I may br crazy however but after filling the j29 stands with playground sand from home Depot, they sounded more solid, maybe, no resonance, very solid and clear....but hey, I'm ADHD, so what do I know anyway
wrg2 is offline
post #290 of 34900 Old 09-09-2005, 08:05 PM
deafgoose's Avatar
I bought Paradigm Signature speakers today.
S8, C5, ADP and Servo in piano black. It takes 2 business days to order so I will have them Monday or Tuesday.
Click Here For Picture
Paradigm Millenia 300 Fronts, Millenia 30 Center, Millenia ADP Rears, Seismic 12 Subwoofer
Pioneer Elite 74TXVi Receiver
Pioneer Elite 79AVi DVD Player
LG 42" PB4D Plasma
deafgoose is offline
post #291 of 34900 Old 09-09-2005, 08:14 PM
JohnGZ28's Avatar
Great purchase! Please post your impressions once set up. What are you driving them with?
JohnG
JohnGZ28 is offline
post #292 of 34900 Old 09-09-2005, 08:22 PM
LEVESQUE's Avatar
I know it was all an adventure... (believe me... I know!) but congrats!
You made a fine choice.
LEVESQUE is offline
post #293 of 34900 Old 09-09-2005, 08:52 PM
outlier2's Avatar
Perhaps being more clear about the system you are talking about would help. I recall that the original post indicated that the CC was not great and that minis were the way to go without mention of the Monitor series at all.
outlier2 is offline
post #294 of 34900 Old 09-09-2005, 09:43 PM
deafgoose's Avatar
I will be temporarily driving them with a Pioneer Elite VSX-74TXVi matched with the DV79AVi. Unfortunately they are not available in Canada yet so I will have to wait 5weeks for the receiver and roughly 8weeks for the DVD player.
If I notice the receiver lacking in power I will use it as a preamp and push the speakers with the Anthem Statement P5 power amp.
I am going to wait for the Anthem D2 pre/pro and sell the receiver on eBay.
LG 42" PB4D Plasma
post #295 of 34900 Old 09-09-2005, 09:45 PM
deafgoose's Avatar
HAHA!
To say it was an adventure is a HUGE understatement.
Thanks again for all your help man.
LG 42" PB4D Plasma
post #296 of 34900 Old 09-09-2005, 10:01 PM
Prozakk's Avatar
I was referring to using Minis with Monitor series. I assumed one would catch that.
Use a bookshelf speaker within the series of your other speakers.
My outdated HT pics
Prozakk is offline
post #297 of 34900 Old 09-10-2005, 05:29 AM
JohnGZ28's Avatar
Nice
JohnG
JohnGZ28 is offline
post #298 of 34900 Old 09-10-2005, 10:47 AM
gregeas's Avatar
My 5.1 system is coming together, slowly. I'm using Studio 60s (v3) as fronts, a CC470, and Studio 20s (v3) as the rears. (Actually, the 60s arrive next week, and in the interim I've been using the 20s as fronts.)
Questions:
How should I position the 20s as rears? Should I put them in the corners at 45 degree angles from the listening position? Ear level on stands?
Also, can someone suggest a mid-priced sub to go with my system?
Everything is being driven by my Arcam AVR300. Sources are the DVD3910, HD cable, and a Squeezebox2 for my PC music collection.
gregeas is offline
post #299 of 34900 Old 09-10-2005, 10:57 AM
s2silber's Avatar
I'm looking forward to the responses you get on a subwoofer as I've got practically the same set-up and had also sought suggestions on a subwoofer for $1k or less.
s2silber is offline
post #300 of 34900 Old 09-10-2005, 11:04 AM
Prozakk's Avatar
Questions:
1) Yes
2) Yes
3) Elevated, angled down, pointing toward sweet spot. If not capable, then yes (ear level on stands)
4) Define mid-priced with an actual dollar amount.
My outdated HT pics
Prozakk is offline
Reply Speakers
Paradigm , Speaker Systems
